How do you hook up a Power amp to a XR8600 peavey power head to run monitors or mains
Hook the power amp into the actual main and monitor input, and then hook your main and monitor speakers into the power amp.
Posted on Jul 01, 2008
Hi , i need a service manual for the peavey xr 8600 powered mixer . Not the xr 8600D . THANKS
http://music.manualsonline.com/manuals/mfg/peavey_electronics/powered_mixers_model_xr_8300_xr_8600.html
Dec 07, 2014 | Peavey Audio Players & Recorders
I'm a guitar player, never had to mess with the PA system. I needed to come up with a monitor system to work with a non powered mixer used for powered mains. I can't afford good powered speakers, so I...
This mixer will run 2 8 ohm cabinets per side, if this is an older unit, it has only one NL2/combo jack per channel....with the button on the front panel in the Main Monitor position you can run 2 main cabinets and 2 monitor cabinets, you will have to daisy chain your speakers.All speakers powered from the back of the unit must be passive, no powered speakers.....if you want to use this head just to run moitors and run a pair of powered mains then connect the jack on the front that says main out to input of your powered speakers, hopefully your powered speakers can be daisy chained at low level, then if you want to use the 8600 to power only monitors, get a 1/4 in y cable and plug it into monitor out on the front of the mixer and then plug it into PA 1 and PA 2 to the right there and both sides will now be the monitor mix from this mixer and it will run 2 speakers per side, as long as the cabinets are 8 ohms.
Oct 09, 2013 | Peavey XR Series XR8600 Powered Mixer
How do i hook a peavey fx24 mixer to a Peavey xr8600 with out going through the 8600's mixer? I am wanting to use the 8600 to power my mains and use another amp to power my monitors. can i do this?
You CAN drive the power amps from the main amp inout jacks BUT the rest of the inout of the 8600 would be dead then. You can connect the L and R from the FX24 to either the media RCA jacks or into the channel9/10 jacks. FOr the latter, use TRS cables. Leave the two selection buttons in the up position.
Sep 21, 2011 | Peavey Xr 8600 8 Channel Powered Mixer
I have an XR8600 - I am using it without Monitors. The Main/Monitor Send is sending a stonger signal to one speaker than the Main/Main send is to the other. have checked leads and speakers and know it has...
Check the pan cotrols are at 12 o;clock.
Verify your speakers are identical and speaker cord length is about the same.
Swap speakers to make sure it is not the speaker,
Feb 17, 2011 | Peavey Xr 8600 8 Channel Powered Mixer
Hello, What is the proper way to connect an Ashly XR1000 Crossover and a Pyle Pro PTA1400 power amp to my Peavey XR8600 so I can use 2 subs? The subs are not powered, but do have a passive crossover...
Here is a link to the manual:http://www.peavey.com/assets/literature/manuals/00513220_7.pdf I didn't look at the manual for the crossover but this is probably the way I would do it. Look at page 13 in the manual : Come out of the Main out (31 in the diagram) into the main in of your crossover. Go out of your crossover Hi and Mid out setting back into Power amp In 1 (labelled 32 in the diagram). Hook your speakers that you normally use to the output jacks on the back of the Peavey. Make sure you match the output impedances. Go out of your crossover low output into the Pyle power amp and out of the Pyle into your subs. Make sure the impedance ratings of all your speakers match the output impedances of your amps. You will only be running in Mono mode as that is the signal output of the Peavey mixer. You can run faux stereo by using the Main monitor Out as 1/2 the pair and the Main Out as the other 1/2 to both channels of the crossover but you won't be getting a true stereo pan mode.
Aug 22, 2010 | Peavey Xr 8600 8 Channel Powered Mixer
Wish to run sm450v2 Mackie powered speakers thru a Peavey XR8600
The Peavey XR8600 is NOT just an amp, but a powered mixer.
To SAFELY use this with your powered speakers, connect those speakers to the MAIN and MONITOR outputs on the front of the unit with 1/4 inch INSTRUMENT rated cables (NOT speaker cables).
To safely leave the power amps in the XR8600 with no output loads, plug GROUNDING plugs into the POWER AMP 1 and 2 input jacks on the front. This will prevent the power amps in the XR8600 from running with no load which COULD damage them.
Make the grounding plugs from 1/4 inch mono plugs by jumpering the centr aand sleeve terminals of the plug.
Jul 09, 2010 | Peavey Audio Players & Recorders
Finding a way to hook this up
Send main 1 out to your Crown. Jump Mon send to PWR am insert.
Mar 11, 2009 | Behringer Pmp3000 16 Channel Audio Mixer
I have a xenyx 2442fx mixer and ep2500 power amp hooked up to 2 1800x subwoofers and 2 1520 pro speakers. i am using a peavey xr 684f powered mixer to power my monitors. i would like to add another power...
You would need a 2 or 3 way crossover, depending on whether or not you biamp your tops. Simply go out of your main outs on the mixer into the input of the crossover. Go from the low output of your crossover to your low power amp input (subs), and the high output of the crossover to the high power amp input (tops). Then go from your outputs of your amps into the speakers themselves.
Jan 04, 2009 | Behringer B1520 Pro Eurolive 15" 2-Way...
105 people viewed this question
 Grubhead
Grubhead
