Back to:
Tags:
Samsung AW0603B Air Conditioner
Trips when plugged in
posted by texasmissy on Jun 30, 2008
The unit has two buttons on the end that u plug in,when plugged in it trips the switch..why?
Comment by texasmissy, posted on Jun 30, 2008
it trips any outlet its plugged into. It is something internal,where can i get a control panel for this,also is it worth it?
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
Thanks for Trying (70)
HellaNice
Rank:Wiz Wiz
Rating: 82%, 127 votes
AC pulling to much power from outlet. Thus tripping the switch.
try to remove all that is plugged into this outlet and have only the AC plug into the outlet.
If you live in an apartment, there might be a dedicated plug for AC. Ask the super.
Comment by HellaNice, posted on Jun 30, 2008
not worth it since you can buy new AC for like 100.00.
The only thing that would trip the switch would be something that's pulling too much power then the outlet can handle.
Rating Locked! (?) texasmissy has rated this solution as Thanks for Trying
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Trips when plugged in:
I don't want to Accept this solution
Can you Help with these Air Conditioners problems?
Air Conditioners
I have a Dyna Glo unvented gas fired wall hung...
Air Conditioners
I am trying to locate a gas valve for fagor boiler in...
Air Conditioners
we have hydronic heating and the heaters keep leaking.Is...
Unit came on for about two minutes, then shut down,...
when i turn unit on the digital display comes on but...
Loading problems.
Repair Service
Find Air Conditioner Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
