Question about Danby DKC645BLS Compact Beverage Cooler
Danby DKC645BLS Tap is Jammed
Any ideas on unjamming the tap on a Danby DKC645BLS? It won't move.
Thanks!
The sugars in the beer are causing it to stick, if you don't use it regularly it dries stuck. You can sometimes gently force it, but it would probably be better to disassemble and soak the tap.
Posted on Aug 17, 2008
DKC645BLS replace control
I hope you are talking about this kit=> 645.05-6-KIT Main Control Board
Click HERE for a crude drawing of the part location. Let me know if I can help you answer any more questions, Thanks Sea Breeze
Dec 12, 2012 | Danby DKC645BLS Compact Beverage Cooler
Danby wine cooler
Hi There,
I would like to help you however I cant seem to see your question.
Can you please respond with the question?
Thanks!!
Jul 19, 2012 | Danby DKC645BLS Compact Beverage Cooler
Where do I get replacement parts for a Danby Kegerator Model DKC645BLS ?
I have Danby keg cooler touch pads in stock, the touch pads are the most common failing part on the coolers, I also have access to many more parts as well as technical assistance, please ask for Erin (509) 928-7176
Feb 04, 2010 | Danby DKC645BLS Compact Beverage Cooler
Danby dkc645bls cools once, then wont kick back on when it starts getting warm.
Your compressor is not starting and in your case you have a thermal induced problem.
I looked for about an hour for parts below on-line with little success. (Danby sourced)
You have 3 possibilites as far as what is causing your problem.
1. PTC start relay / Klixon (2 parts as an assy)
2. Run capacitor
These are not expensive parts even if you ordered all of them.
The sad thing about it is the parts are probably available at your "local" appliance parts store.
If you can look at your compressors' label and copy down the
Manufacturer (i.e Embraco, Mitsubishi Elec, Panasonic etc) and ALL numbers (including LRA)
you can take that info to the local appliance parts supply and walk out with the parts in hand.
Otherwise your looking at calling Danby (number below) and telling them you need a PTC Start relay / Overload and run capacitor.
1-800-263-2629 (US)
Thanks for using FixYa
Oct 16, 2009 | Danby DKC645BLS Compact Beverage Cooler
Danby Kegerator is beeping and flashing EE and won't cool
I am having the same problem seeing if you found a fix??
Aug 26, 2009 | Danby DKC645BLS Compact Beverage Cooler
Temperature - Is fan supposed to constantly run or is it controlled by thermostat
You said ,Top half of Danby DKC645BLS refrigerator 10 degrees warmer than bottom half. Bottom half cooling to approx. 34 degrees.
Is it running all the time without cycling off and on as it should be doing?
Sorry to have to tell you this news.
But this would mean a bad thermostat or insufficient freon in the cooling system.
The same issue with the fact that one compartment is warm and the other is cool!
Let me know that service tells you!
Thank You
Huuum
Please remember toleave a rating
Oct 19, 2008 | Danby DKC645BLS Compact Beverage Cooler
Buzzing noise from DKC645BLS
It's the fan that moves the air around inside to aid in circulation. Call danby and ask to buy it. It shpuldn't be very expensive at all.
1-800-263-2629
Jul 11, 2008 | Danby DKC645BLS Compact Beverage Cooler
Danby DKC645BLS Kegerator
i had the same problem with mine. i fixed it by removing the guts from the faucet and reversing the seal on the closing part. the seal was on backwards, flipped it and no more leak.
Jun 14, 2008 | Danby DKC645BLS Compact Beverage Cooler
Danby DKC645BLS Compact Beverage Cooler Logo
102 people viewed this question
Top Danby Refrigerators Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
jason
Are you a Danby Refrigerator Expert? Answer questions, earn points and help others
