Question about Toshiba Satellite M45-S359 Notebook
How to calibrate battery laptop toshiba satellite m45-s359
  • Toshiba Master
  • 7,733 Answers
Calibrate laptop battery pack under the following conditions:
? When the battery status display seems inaccurate.
? When you observe a significant change in normal batteryrun time.
? When the battery pack has not been used for one monthor more.
How to Calibrate laptop battery
To Calibrate laptop battery pack, you must fully charge, fullydischarge, and then fully recharge the battery pack.
Discharging the Battery Pack Disabling Hibernation
To fully discharge the battery pack, disable Hibernation temporarily.
To disable Hibernation:
? Select the Power Meter icon on the taskbar or access Power Options > Hibernate, and clear the Enable Hibernate support check box.
    To fully discharge the battery pack:
  1. Select the Power Meter icon on the taskbar, or select Start > Control Panel > Performance and Maintenance > Power Options > Power Schemes.
  2. Write down the 3 settings in the Plugged In column and the
  3. settings in the Running on Batteries column, so you can reset them after calibration.
  4. Select the drop-down lists and set all 6 options in both columns to Never.
  5. Select the OK button.
  6. Disconnect the notebook from the external power source, but do not turn off the notebook.
  7. Run the notebook on battery power until the battery pack is fully discharged. The battery light begins to blink when the battery pack has discharged to a low-battery condition. When the battery pack is fully discharged, the power/Standby light turns off and the notebook shuts down.
Posted on Dec 13, 2010
SOURCE:
How do you take back your laptop factory settings?
Get a reinstall driver,they are free,call Toshiba tech.service center.
Oct 27, 2012 | Toshiba Satellite M45-S359 Notebook
Toshiba Satellite M45 S359.
The actual switch is rare to go, the DC jack in the laptop is more likely the issue and will require a complete tear down to access.
May 29, 2012 | Toshiba Satellite M45-S359 Notebook
How old could a toshiba model PSM42U-017006 be?
At least 2005. The drivers on Toshiba's website show the earliest date of 2005.
Jan 10, 2011 | Toshiba Satellite M45-S359 Notebook
Computer went out will not come back on
Are you unable to see windows scree?. Also let me know if you have disk fo operating systme
Jul 29, 2010 | Toshiba Satellite M45-S359 Notebook
I have a Toshiba Satellite M45-S359, Power Supply Problem.
It could be the motherboard as it is what is powered initially and distributes power to all other parts.
such a problem can only be diagnosed by checking physically but if you are asking whether a motherboard can be the cause, then yes it can
Mar 02, 2009 | Toshiba Satellite M45-S359 PC Notebook
Internal Hard Disk Upgrade
Yes, there is. Match the type of drive (Serial ATA or Parallel ATA) you get with what you have. Make sure your Satellite sees the drive in the BIOS. For drives larger than 120 GB, recommend operating systems Windows XP (Service Pack 2 or higher) or Vista. Older OS's have a 137 GB limitation (they only see the first 137 GB of the hard drive despite its size).
Mar 01, 2009 | Toshiba Satellite M45-S359: M45-S359...
My toshebia satellite M45-S359 scren only displays the toshiba
Thanks for that.
Ok the onlything that springs to mind is:
1. The bios needs to be reset asit has lost settings. This could happen IF you have installedsomething OR if it has become corrupt. Just access your Biosand reload the standard default settings.
2. Your hard drivehas a fault. The best thing you can do is to boot up from youremergency floppy (if you made one) or from your original windows CD. Once done, simply run scandisk/chkdisk/defrag and let it do what itneeds.
Sorry I could not help you more, but that is the onlything I can think of that would be stopping you booting further. Personally it sounds like the bios has lost settings and may betrying to boot from another drive ... but of cause it may be thatyour hard drive has become "sticky" or has errors that arecausing the problems.
Good luck with it.
Nov 20, 2008 | Toshiba Satellite M45-S359 Notebook
Password lock out
Is this a Windows log on password or a bios password?
Jul 25, 2008 | Toshiba Satellite M45-S355 Notebook
Toshiba Satellite M45-S359 Laptop Power Jack Issues
well the adapter for toshiba laptop is weak, and the most common method is to use a multimeter with the electroprobes connect to the anode and cathode.if it is normal, the pointer will fix in a short time.
May 31, 2008 | Toshiba Satellite M45-S359 Notebook
Toshiba Satellite M45-S359 Notebook Logo
1,535 people viewed this question
Top Toshiba Computers & Internet Experts
Alun Cox
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
