Question about Dell UltraSharp 1800FP 18.1" LCD Flat Panel Monitor
Dell Ultrasharp 1800FP Power Saving Mode
After couple min in the computer the monitor goes to power saving mode and turns off the computer. it didn't do this before... the psm message is not from the computer is from the monitor
  • djones50 Jul 16, 2008
    Can I adjust the Power Saving Mode? I can't find how to make it longer.
  • Anonymous Nov 13, 2008
    I can't get my flatscreen out of Power Saving Mode. It's a Dell Ultrasharp 1800FP. I push delete but nothing happens. What do I have to do to see anything but that on my screen? Please help.
    Genius:
  • 1,605 Answers
Go to control panel>power option>power scheme.
adjust the hard drive to 30 mins and everthing else 20 minutes.
also, go to display and adjust the screen saver to be longer. up to 9999min.
Posted on Oct 22, 2008
My dell monitor is on power saving mode I am using the monitor with cameras so do not have a pc I cant turn the saving power mode off
Without a PC you have no control over the power saving mode. You can't turn it off without one, that comes right from Dell.
Nov 20, 2016 | Dell Computers & Internet
Power Saving Mode problem using the DVI input. VGA input Ok.
try the display on another computer, if the display does the same thing on another machine, then its definitely a problem in the display not in the computer drivers or bios.
Sep 21, 2008 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
CAN'T GET THE MONITOR OUT OF POWER SAVING MODE
If you have a blinking power light and no display even when you first power up the unit then its not in power saving mode. The blinking power light indicates a failure of the filter capacitors on the power supply board. This is a very common problem with LCD monitors after a few years of service. The power supply can be repaired by just replacing the defective filter capacitors. Here is a picture of the power supply board with the bad caps circled in yellow and below that is a link to a full repair guide showing how to open the unit and what to replace including a full parts list.
http://www.ccl-la.com/blog/index.php/repairing-a-dell-1905fp-1907fp-lcd-monitor/
I hope this helps you out,
BuddyMc
Feb 11, 2011 | Dell UltraSharp 1905FP 19" LCD Monitor
LG Flatron L177WSB-how would I use my newly purchased unit after switching it on, LG logo appears followed by the Power Saving Mode it all goes black on the screen.
Hi, the Power Saving Mode, turns the screen off to conserve energy. On the remote, press Menu, and scan to Power Saving Mode. You can change the amount of time, when the Screen turn-off, the TV shut-off etc. You can set the time to (5 min) to, (never, turn-off). This should help with your problem. Thanks paul7of9
Jan 14, 2010 | LG Flatron L1750S 17" LCD Monitor
I only get power saving mode on my screen then screen goes black
inside the power pack is a pulse IC chip they fail and cause all kinds of havoc also caps can cause issues unaccounted for, I would start at replacement of the IC about 2 dollars on E bay, and replace any bad capacitors you can see, they look domed or are leaking color from the top creases. after that get back with me and we can either proceed or you can rate me fixya, have a great weekend
Mar 13, 2009 | Dell UltraSharp 1800FP 18.1" LCD Flat...
Dell ultrasharp blinks on and off
It could be a setting problem, power saver setting, or a mode that the monitor does not really support - things like refresh rate - or actual hardware.
Easiest way is to borrow another like monitor, and say another video cord and see if the problem remains, or if a newer monitor says 'out of range' or similar.
Then, if you have a fancy video card,remove it and use something primitive. Not reading instructions is a big cause.
If its not a setting issue, and as the inverter board is ok; if the above description is correct, reseat the inner board connecting cables.(wood fires and seaside locations) If not that, a lucky guess might be the electros on the logic board.
Aug 20, 2008 | Dell UltraSharp 1800FP 18.1" LCD Flat...
My dell ultrasharp 1800fp monitor keeps flashing on and off, its not a power problem as the power button stays on and when i disconnect the the monitor cable from my pc the no signal message stays on the...
Inside there is a IC chip on the power pack that goes bad, replacement is called for also look for bad capacitors when you are inside looking around, those need to be replaced as well
hope this clears things up. dells third party who built these units did a rotten job on this model. that chip always fails.
Aug 19, 2008 | Dell UltraSharp 1800FP 18.1" LCD Flat...
Monitor automatically clicks into power saving mode
check the primary settings for your default video card.
Jun 08, 2008 | Dell Dimension 4600 PC Desktop
Dell UltraSharp 1800FP - display leak - blue craziness
That one is going to take component level troubleshooting. It could be the power suply, but I might first suspect the video board.
Jan 02, 2007 | Dell UltraSharp 1800FP 18.1" LCD Flat...
Dell UltraSharp 1800FP 18.1" LCD Flat Panel Monitor Logo
344 people viewed this question
Alun Cox
