Question about HP Compaq Presario V2000 Notebook
Ethernet port I have a HP COMPAC PRESARIO V2000 LAPTOP. We have had problems from day 1 with conection to network. It has gotten worse in past months. we have even changed modems, filters, and cords. It seems that the ethernet connection is not being detected. when I plug it into the computer sometimes the lights go on at the port and sometimes it flashes and sometimes it just doesn't go on at all. even when the light is on it still doesn't connect to the internet. PLEASE HELP!!!!
  • 2,028 Answers
Try reloading the ethernet drivers from the device manager. Uninstall the drivers then reboot. It will find the hardware and reinstall the drivers. Then update the drivers from HP's support site. If you still have the issues, then it may be a faulty port. Take it in and have it checked out.
Posted on Jun 30, 2008
I was able to connect to my HP Compaq Presario V2000 Laptop to my WiFi Network using NetGear. When I reconfigured the network I could connect to all other network like Dell Lptop , Nokia Smart Phone and HP...
Your Compaq V2000 has an Intel Pro Wireless 2200 BG wireles adapter. (doesn't support N, but that's not the point I think)
If your new network configuration is based on WPA/WPA2 encyption, this adapter has some known problems to establish a connection. It works great with WEP, but not so well with WPA.
Sometimes the issue can be solved by installing the latest versions of drivers and software for the wireless adapter.
If it still doesn't work, a known workaround is to disable via device manager all other network adapters in the computer (ethernet adapter), leaving active only the Intel Pro 2200 wireless adapter.
Hope it helped,
Sep 25, 2011 | HP Compaq Presario V2000 Notebook
My computer will conect to the internet on wireless but not on hardwire conection what should i do
It can be several problems.
1. Driver of wired network adapter is not properly installed. Try reinstalling the driver. 2. Your LAN wire is defective. Try a different wire. 3. If you are using a router or switch. There might be a problem with it. Check that. 4. Your wired network settings is not properly setup. Try resetting it to default.
Feb 13, 2011 | HP Compaq Presario V2000 Notebook
How to have a bluethooth connection for my compac presario laptop
this model does not feature blue toooth by default, you will need to buy an extermal usb bluetooth dongle.
Jan 28, 2011 | HP Compaq Presario V2000 Notebook
My compaq presario V2000 will only connect to dialup
To connect to your DSL internet you will need an ethernet port or wireless card on your laptop. Your laptop should have an ethernet port, it will look like a phone jack but a little bigger. In the off chance that you don't have an ethernet port on your laptop you can also purchase an ethernet to usb adpater. You may have a wireless card installed on your laptop, but if not you can purchase a usb wireless adapter. To use your internet wirelessly in your home you'll also need a wireless router. All of these things can be purchased at your local electronics store (walmart, best buy, kmart, frys) and usually are fairly easy to setup with the included instructions.
Feb 15, 2010 | HP Compaq Presario V2000 Notebook
My ethernet won't work
if it is intel ethernet go to
Mar 19, 2009 | HP Compaq Presario V2000 Notebook
Anyone has a complete compac HP OS
**NOTE: Even though your computer may SAY that it is a Presario V2000, it may have an entirely different product number for downloading drivers specific to your particular configuration.**
1) Look at the serial code on the back/bottom of your computer: there is a number starting with p/n (ex. p/nEX664UA#APL) This code identifies your computer beyond the V2000 label.
2) Go to the compaq/hp website:
3) select "Download Drivers and software(and firmware)"
4) THEN, enter your P/N Instead of "Presario V2000" into the product name/number box, and hit enter.
Select your operating system, and you will be redirected to a page listing all the necessary drivers for your model.
5) Scroll down the screen, and you will see a section where you can order free copies of the recovery cd. just enter your serial number from the bottom of your laptop.
Dec 13, 2008 | HP Compaq Presario V2000 Notebook
Missing drivers for compaq presario v2000 machine
Please let me know from where i can download the following drivers for my Compaq Presario v2000 machine: 1. Multimedia Audio Controller 2. Network Controller 3. PCI Modem 4. Video Controller 5. Video Controller (VGA Compatible)
May 07, 2008 | HP Compaq Presario V2000 Notebook
Compac V2000
i need to reformat my presario v2000 to factory settings. I put in the xp disk, and went the install xp option, then installed it all and still it did nothing. I have some NETUPGRD.DLL problem, it says. I thought reformat would fix?? can anyone help??
Apr 14, 2008 | HP Compaq Presario V2000 Notebook
Ethernet not working! Help!
im assuming its not dissabled, if not then go to control panel, network connections and right click on your network card and go to properties then driver and see if there is a code 9 meaning it's faulty or the device is working. if it is faulty then it's part of the motherboard anyway and you will have to buy a pcmcia network card and connect through that instead
Sep 04, 2007 | HP Compaq Presario V2000 Notebook
HP Compaq Presario V2000 Notebook Logo
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
