Question about Samsung HCM4216W 42" Rear Projection Television
Set shuts itself off
My set shuts itself off after a period ranging from minutes to hours. No normal "deedle deedle" shut-down sound----it just goes completely off. It will always turn back on, but it may take several attempts. Any ideas?
  • Alanapea Jul 24, 2008
    My tv keep turning itself off!! I will be watching a show and then all of a sudden it turns off. I have to unplug it from the wall and then turn it back on. It's been happening more often lately.. Any ideas on how to fix it??
  • Samsung Master
  • 8,617 Answers
Sounds like a solder issue on the main deflection board. Check for signs of cracked or dull solder on that board. Its the large board on the right looking in from the back
Posted on Jun 30, 2008
My Maytag Bravos dryer is shutting off after running 10-20 minutes. Will not restart for an hour. Feels very warm
Have you considered calling a repairman .. sounds like you have a thermal overload malfunction .
Mar 16, 2016 | Maytag Dryers
Chest freezer suddenly stops working then will start again later
This is normal if your freezer is in good working condition. If your compressor runs constantly then there is a problem. Once the unit reaches the set temperature the compressor shuts down. The set temperature should be between -2 & +2 degree F. The set temperature also depends on how full the freezer is. There will be a time when the freezer like refrigerators will shut down. This is relative to the term, "Frost Free". The unit will shut down for about 10 minutes. This occurs ever 8-10 hours. The heater turns on to defrost your freezer coil. It sounds like you are in good shape.
Apr 18, 2014 | Westinghouse Freezers
It will work for an hour ...maybe 2, then it shuts itself off. like it gets too hot or somenthing.
  • Do not block rear Fan exhaust port. A minimum of a 2 inch clearance is necessary.
  • If the Fan Exhaust port is blocked, the temperature will rise in the Engine assembly and cause a thermal switch to activate, shutting off the unit.
  • After a cool down period and the set is unplugged for greater than 30 seconds, the set will return to normal operation.
  • Upgrade to New Style bottom Filter to avoid premature clogging and over heating.
Feb 24, 2011 | Hitachi 50V500 50 in. HD-Ready LCD...
Set won't stay on, won't turn on
Sounds like a capacitor on the power supply is bad. Easy fix.
Sep 24, 2009 | Hitachi 50UX57B 50" Rear Projection...
TV goes to green, sound stays on a few seconds then TV shuts off.
Sounds like you have a bad picture tube. More than likely the CRT could be shorted, which would cause the set to shut down.
My first advise would be to power up the set with an isolation transformer with the voltage about 60% approx. 72 Volts AC, and monitor what happens when you increase the voltage slowly.
If the set remains on at 60 -70 %, then when increased to 90 - 100% it shuts down, you have something drawing too much current ( which could be the CRT )
Sep 14, 2009 | Sony FD Trinitron WEGA KV-30HS420 30" TV
RICOH FT 7650 shuts itself off when not in use after 45 minutes
Enter in the user mode:
1.Press the Clear mode key.
2. Press the Clear/Stop key more 4 sec untill the user tool menu appears on the touch panel.
3.This copiers has more 12 user tools.You can see 5 user tools on the display at the same time.Use these keys to see the rest .
4.AUTO RESET: the copier return to the initial condition autommatically after your job is finished.(after 60 sec)
5.SCREEN SAVER :when the copier does not detect anyone operating it for selected time the display turns OFF.(60 sec).
6AUTO OFF:Whwn the machine is used after weekly timer has turned it OFF the copier will turn itself back OFF after the selected time.The auto OFF time can be set from 1 to 999 minute or the function can be turned.(I recomanded setting level OFF).
Aug 31, 2009 | Ricoh Aficio 450 Copier
Tv keeps shutting off
Check that you have not set the sleep timer on so that it goes off after 1 hour
Aug 17, 2009 | Televison & Video
Want oven to shut off by itself after two hours
I would simply push the buttons finding the mode where the hours flash. At this point the hours can be set and I would experiment til I found the correct button and sequence to make them advance the hours then go to the minutes and do the same thing.
DId this answer your question about setting the timer? Or have I misunderstood your post?
May 08, 2009 | Hotpoint RB757 Electric Kitchen Range
Axim wont automatically shut off
I would guess your light should dim after 5 minutes. But I bet your axim wont shut off for 2,3, or 4 hours. My battery is wonderful so I have it shutting off after 2 hours.
Sep 14, 2005 | Dell Axim X5 Pocket PC
Samsung HCM4216W 42" Rear Projection Television Logo
66 people viewed this question
Jerry Greenberg
Jerry Greenberg
