Question about byD sign d:4222 42 in. EDTV-Ready Plasma Television
Byd:sign 42 t.v.
I cannot get past te menu screen. Everything is in spanish too. Is the company out of business? I am in Long Island N.Y. Can I get somebody to fix T.V.? Ted Zucker
4 Suggested Answers
Ryd66
  • 65 Answers
SOURCE: have a byd:sign television that
If the company no longer exists or has gone out of business then your warranty is void. So if you want to get it working again, you will have to find a company that can repair televisions.
Posted on Jan 20, 2009
  • 3 Answers
SOURCE: Power Adapter
I have a new OEM power supply for this tv.
If interested, email me your contact info.
Thanks,
Art
Posted on Mar 19, 2009
  • 5223 Answers
SOURCE: The picture on my BYD:sign 3032 has been going out, sound is OK
It's a backlight or backlight inverter issue. (The backlight itself usually fades or makes the on-screen image change to pink/red.) For an out-of-warranty TV, open up the back of the TV and remove the shielding. Look for any scorch marks or bulging or damaged capacitors. (Sometimes other parts will fail on this part but these can be spotted easily. Capacitors look like cylinders on a tripod.)
If you borrow (or have a) high-end multimeter (able to measure high frequencies - 50 kHz) or an oscilloscope, hold the multimeter probes a fraction of an inch apart about an inch above the board and power up the TV. If you see a 1 or an actual value, you have a good inverter. If you see a reading near 0, the board is bad or the multimeter can't resolve the frequency.
In either case, you can buy a replacement inverter for $50-150 and just do a simple swap. Disconnect all of the wires (connections are similar to molex and ribbon cables in a computer) and remove board (a few screws usually). Connect the cables to the new inverter. (If you google backlight inverter replacement, you'll find videos and text descriptions.) Note the part number on the board, including the Rev number, and order the exact one (shopjimmy.com or lcdparts.net are good starting points). Universal inverters do exist but can result in reversed controls (up to lower the brightness). Replacing individual parts on the board is cheaper but more prone to not tracking down all of the bad parts.
If the inverter is good, then it's probably backlights themselves (several in most TVs). These are sandwiched on the perimeter of the TV (usually under some tape that holds the lamp, reflector and other parts together. You need to order by length and width and get ones for your TV size. Remove the tape, and separate the reflector (make a note of how things are put together) then you have to Dremel (or use another rotary tool) to remove the plastic to get the backlight out. (They are often molded into the frame.) Then put in the new backlight and reassemble everything.
With a good spare backlight, you can test an inverter for condition (plug together and turn on the tv while the box is open). Similarly a good inverter can test the backlight.
I hope this helps.
Posted on Jul 08, 2010
Testimonial: "Thanks for the detailed explanation and diagnosis!"
Need manual
It seems that no one can help with these problems, with byd:sign, as the company has gone broke. There is no info to be found for them....Sorry I couldnt help here.
Apr 12, 2011 | byD sign d:5032 50 in. HD-Ready Plasma...
Have a byd:sign television that needs work. What is the contact information for warranty work since the company no longer exists?
Jan 20, 2009 | byD sign 2012 20 in. HDTV-Ready LCD...
Need to get parts for byD:sign lcd m#D:4242m
I bought 40 byd:sign 23" LCD screens from them about 1 year ago and installed them in a hospital enviorment. The sets are starting to fail. Do you have an address or phone number for them? I would be greatful for any help.
Respectfully
John Liljeblad
Amerisat, Inc.
858-505-1122
Jun 21, 2008 | byD sign d:4222 42 in. EDTV-Ready Plasma...
Power Adapter
I NEED a new power adapter ttttttttttoo.. can you HELP please,, I allready had a so called TV repaire Man try to fix it he said he cant get a new power adapter for it to be fixed .... I stupidly PAYED him waited 9 months later, and still no TV fixed..Im taking him to smalls claimes court.....Very un happy persone ,I just want a new power adapter,....please some one out there...peascorn...I have d:sign TV 3032- ad-13d-2...
May 25, 2008 | byD sign 3032 30 in. HD-Ready LCD...
ByD sign d:5032 50 in. HDTV-Ready Plasma
If you purchased from a major retailer, could you try going to another store?
Also try contacting the manufacturer. Hopefully you are still under some kind of warranty, even if the place of purchase is no longer there.
Just to be sure, have you tried a different source - like a video camera, still camera with video output, laptop, or a different DVD player?
Good luck, I hope you can get it fixed!
Apr 07, 2008 | byD sign d:5032 50 in. HD-Ready Plasma...
Cannot access alternate video inputs
There is a place in the menu where you have to tell it /define what the inputs are to be. they will have a sub menu,
I don't have the manual to show you exactly.
Mar 04, 2008 | byD sign d:4222 42 in. EDTV-Ready Plasma...
No picture
btw for anyone experiencing these problems with the infamous "is-lcdtv32" byd:sign is the same manufacuterer as insignia, its the same company with a different sticker. i know this isnt a solution, but parts for all discontinued insignia';s can be purchased thru byd:sigh(by design). hope this helps .
Oct 06, 2007 | byD sign d:4232 42 in. HD-Ready Plasma...
byD sign d:4222 42 in. EDTV-Ready Plasma Television Logo
Top byD sign Televison & Video Experts
Jaime Hernandez
Elise Lacoursiere
Elise Lacoursiere
Are you a byD sign Televison and Video Expert? Answer questions, earn points and help others
