Panasonic SA-AK57 stereo system, volume issues
Stereo is on for a while, then when I change the volume the sound cuts off completely. Everything else looks operational, no error message.
The stereo can play forever on one volume setting, but if it's been on for a while and I change the volume the sound stops. I have to turn the unit off and on again for it to work.
Could it have something to do with humidity? dust? heat? I took the cover off the unit and vacuumed the inside, as much as I could - but I didn't get close enough to break off any parts.
  • Anonymous Feb 02, 2009
    i have one problem a power supply a model sa-ak57 panasonic i need help
SOURCE: error f-61 on SA-AK640
F61 Power Amp IC output abnormal
Upon power on,
PCONT=HIGH,
DCDET=L after checking
LSI.
For power.
Press [STOP] on main unit for
next error.
Posted on Oct 20, 2008
  • 18 Answers
SOURCE: I lost a power cord
yes i belive it is. if possible go back to the store you bought it from. they should be able to order a replacment if they dont have it. if not possible most electronic stores should be able to order it for you. this happens alot so if they a store cant help you they should be able to point you to one that will be able to
Posted on Jan 09, 2009
SOURCE: Remote malfunction - panasonic dvd stereo system
The remote control and main unit are factory-set to “REMOTE 1”
mode.
If your remote control affects other equipment during operation, you
can switch to operate in “REMOTE 2” mode.
To switch to “REMOTE 2” mode
1 While pressing and holding [AUX] on the main unit
Press and hold [2] until “REMOTE 2” appears on the
main unit display.
2 Press and hold [ENTER] and [2] for at least 2
seconds.
The main unit and remote control are now set to operate in
“REMOTE 2” mode.
To return to “REMOTE 1” mode
Do steps 1 and 2 above but use [1] instead of [2] for both steps.
(“REMOTE 1” appears on the main unit during step 1.)
The remote control cannot work with the main unit if their
modes are different.
“REMOTE 1” or “REMOTE 2” appears on the main unit display when
you operate the remote control.
If “REMOTE 1” appears (The main unit is in “REMOTE 1” mode.)
Press and hold [ENTER] and [1] on the remote control for at least
2 seconds.
If “REMOTE 2” appears (The main unit is in “REMOTE 2” mode.)
Press and hold [ENTER] and [2] on the remote control for at least
2 seconds.
Posted on Mar 11, 2009
  • 5 Answers
SOURCE: my panasonic SA-AK57 it is displaying error code F61
you need a code 234634
it is wary simple to fix
if the code dosent work the there is
Posted on Jun 22, 2009
ravichetty
  • 158 Answers
SOURCE: Panasonic DVD Stereo System (SA-PM91D) REMOTE MODE 1
press the enter and number 1 button on remote simultanously
Posted on Jul 31, 2009
The volume gets noisy, cracking sounds and fades out
Your volume control is dirty. Apply some deoxit or wd40 directly onto the module.
Mar 22, 2014 | Panasonic Technics SA-G76 AV Control...
I have a sa-ak320 stereo that was left at my gf's
The 6 ohm speaker would make it slightly louder but won't solve the problem, you are right the stereo has bad audio output ic, and there is trouble with the cd player. I would use it until it goes, and get a brand new unit, not cost effective to repair.
Apr 15, 2012 | Panasonic Audio Players & Recorders
I would like to connect my computer to my panasonic sa-ht800v unit and hear the sound thru the surround sound speakers
In general, your PC's sound card (and its controlling software) will determine what it can connect to.
Even the most basic PC would have stereo analog output via the typical green 1/8" connector or a headphone jack that easily adapts to RCA pair for analog audio connection. Any Line Level input EXCEPT PHONO would accept the PC's output. The output level would be controlled by the sound card software and settings.
The SA-HT800's single LINE Input would accept the Green stereo audio or speaker output from a standard PC, once adapted. Select VCR.
Find your PC's Sound Controls and enable the applicable input. make sure the volumes of both Inputs and Outputs are turned up.
Though not applicable to theGemini, more-advanced sound cards and audio hardware would have similar adaptable 5.1 or 7.1 (paired) analog outputs and / or digital audio outputs that conform to the s/pdif or Dolby Digital standards.
Mar 26, 2011 | Panasonic sa-ht800V Home Theater Audio...
Just wondering if there is any way to hook an iPod (actually my iPhone 3GS) to my stereo (SA-AK57) somehow to play my songs??
only in stereo, there is not digital interface for this sound system, you need a 3.5mm jack to RCA lead (Head phone connector on end and a red and white phono connectors on the other) these connect to the Aux 1 or Aux 2 inputs on the rear of your stereo.
Jun 20, 2010 | Panasonic Audio Players & Recorders
Technics SA-DV290 Amp. Sound cuts out as volume is increased
hello it sound like the output ic may be in trouble you may have just dry joint on the ic which just resolder it . or there could be a capacitor leaking or they may have swelled up in which you will have to replace. it's best to do some visual checks first i'e look for any burnt parts any capacitor with bulging tops
regards
shaun
Apr 04, 2010 | Technics SC-DV290 System
Home theater hooked up volume sounds low
Check your different settings either in your t.v. or your amp. In your menu settings you can change your audio. Bass trebile etc. and even sometimes switching it from stereo,mono, dolby digital will increase your volume. Dolby digital is very quiet if your not running and exteranal amp system. so try changing it to stereo and your volume should increase.
Aug 31, 2009 | Panasonic Audio Players & Recorders
My panasonic SA-AK57 it is displaying error code F61
Jun 22, 2009 | Panasonic sa-ht930 Home Theater Audio...
I have a panasonic sa-ak630 and it works and everything i just dont have any sound at all
I had the same stereo, I found that the issue you describe happens often under heavy use especially with the subwooferon max. Simply unplug the stereo unit from its power source for about a minute and plug it in and it should work again. Hope this helps.
Apr 01, 2008 | Panasonic Audio Players & Recorders
F-61 error,dead panasonic model#sa-ak78
Need to know how to get rid of F-61, cause my stereo is completely dead...model# SA-AK78
Dec 03, 2007 | Panasonic SC-AK78 CD Shelf System
Panasonic SA-AK66 Sound Problems
I have a Panasonic SA-AK66 5 disc changer stereo system. At first I was getting a no disc. I inserted my cd disc cleaner, now it won't play the disc or open (the drawer). What happened?
Nov 26, 2007 | Panasonic Audio Players & Recorders
352 people viewed this question
 Grubhead
Grubhead
