Question about Brother IntelliFAX 4750 Plain Paper Laser Fax
Check paper reload paper
The fax machine sends faxes but does not recieve them,
it will say on the screen; check paper, reload paper
when i check the paper it seems to be fixed but then changes back to check paper, reload paper... circle
  • 2 more comments
  • genekrug Feb 28, 2009
    I get the same error. Can't print anything. I've checked and reloaded the paper many times. Nothing seems to work.
  • genekrug May 11, 2010
    Have you fixed your problem yet?
    How can I make sure the paper is not binding and lifting up OK? I can't see inside the tray when it is inserted. And everything seems fine when it's outside the fax machine. The paper is fine and flat.
  • Anonymous Mar 26, 2014
    says check paper reload paper, but there is paper we have to manual feed
    Genius:
  • 2,120 Answers
Remove the paper tray completely and make sure paper is not binding and lifting up OK.
Posted on Nov 26, 2008
We are not receiving faxes..we keep getting error code 407..Please help? Thank you.
The message means:
407 No confirmation from the receiving station for the
previous page sent.
Wait a few minutes and send again.
This can mean 2 things
1) you have not set your fax machine to recieve faxes
2) you need to have your fax machine serviced because the part that makes it pickup a fax has malfuctioned
Clean all paper paths with paper path cleaner.
Unplug and then after 10 seconds replug the fax machine and do a test recieve for it
If all else fails, you may need to call a service person to repair or replace the broken or defective part that recieves faxes.
Hope this helps :)
Mar 16, 2010 | Panasonic Panafax UF-890 Plain Paper Laser...
Cannot recieve or send faxes. Machine can still copy though. says "change paper size"
Unplug the fax from power for a minute or two.Check the paper size under fax sett., clean rollers,...
Feb 16, 2010 | Canon FAX-L380 Plain Paper Laser
It will send faxes but not recieve them. it is on
Be sure the fax is on the proper phone line. You can send on any line but you can only recieve on the line for your number.
DickyO
Sep 01, 2009 | Sharp UX B700 Plain Paper Inkjet Fax
Fax can not recieve. It sends okay. Hp fax 1010
Most likely the machine has been set to "manual receive" from either "fax/tel" or "automatic" receive. check your manual to check/ change the setting.
May 26, 2009 | HP 1010 Plain Paper Inkjet Fax
Paper is not "picked up" to print.
TRY CLEANING THE PAPER ROLLER WITH DENATUYRED ALCAHOL OR MAY BE THERE IS SOME THING STUCK IN THE MACHINE GO AHEAD AND LOOK GOOD LUCK BROTHER TECH
Jan 28, 2009 | Brother IntelliFAX 2800 Laser Fax
How to send and recieve faxes
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_IntelliFax_775_EN_86.PDF
Aug 01, 2008 | Brother IntelliFAX 775 Plain Paper Thermal...
Fax will not recieve
DR mode means that Distinctive Ring is set to on which will force your fax machine to manual receive. Turn DR off and you can set it to whatever mode you want.
Nov 03, 2007 | Brother FAX-575 Plain Paper Thermal
Can't recieve a fax
i have fax L100 ,i can send a fax but i cant recevie a fax error is communication error (003F)
Oct 24, 2007 | Canon FAX L-120 Plain Paper Laser
Brother IntelliFAX 4750 Plain Paper Laser Fax Logo
520 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
