Just a few days ago, I lost my windows vista admin passwords. I solved the trouble with the help of windows password reset tool. It not only support XP/Vista/2000/NT, but also compatible with windows 7, I tested it on my computer installed with Windows 7 and remove the local user and admin accounts password successfully. It's worth trying. You can download it from: http://www.reset-windows-password.com/reset-windows-7-password.html
In this situation, you can reset the administrator password with a USB flash drive. Go to download a windows password tool. I recommend a program called Windows Password Seeker. An burn this file on the USB, then you can reset the password with the USB flash drive. You can open this site www.passwordseeker.com/howtouse.html
I ever forgot my windows password and try to search for help on google. I've tried a couple of free password recovery utilities. The free software can help you, but you have to learn some computer skills and waste a lot time on learning. If you want to save more time, Google third party password recovery tool or Google Windows Password Reset 9.0 can help you.
http://www.reset-windows-password.com/how-to-reset-windows-password.html
I believe probably the easiest and safest way for you is remove your Windows OS Passwords with Windows Password Recovery tools. I found a good one at http://www.reset-windows-password.com last week, and then I downloaded it and used it to remove the lost password within only few minutes. Furthermore, the powerful tool didn't cause a little data lose. It's worth an attempt.
Use Windows Login Recovery and bypass Windows 7 password.
1: Start Windows Login Recovery software, select Reset local account password for Windows 7/Vista/XP/2008/2003/2000, and then click Next.
2: Insert the CD/DVD or USB flash drive into the computer. Select CD/DVD or USB, click on Burn to start burning a password reset disk.
3: The password reset disk will be successfully burned automatically then. Then click Quit when finishing burning.
Then you can use the password reset disk for windows 7 password recovery. It worked great for me. Hope it works for you as well.
A Windows Password Reset Disk could do all the job for you, it can reset your lost or unknown Windows password safely and quickly without login, you can create a Windows password reset disk with the tool Windows Password Breaker, then use it to reset your password.
Forgot Your Windows Password? Many people think that after having lost their Windows admin password, they absolutely must reinstall their OS. Let me tell you something: There are other ways can solve the problem without data loss.Windows Password Seeker may help you. The program that I recommend is the first one, it is very easy to create a recovery disk that you can use on any Windows PC. This recovery program only cost about 19.95 USD. Windows Password Recovery Software. Reset Administrator Password. Win2000,Win7 x32,Win7 x64,Win98,WinVista,WinVista x64,WinXP:http://www.passwordseeker.com
