Question about Zenith E44W46LCD 44" Rear Projection HDTV-Ready Television
TROUBLESHOOT E44W46LCD NO PICTURE OR SOUND. THE 1ST LIGHT IS RED, THE 2ND LIGHT IS YELLOW.
    Novelist:
    Champion:
  • 203 Answers
Suspect small thermistor mounted on light engine or check first to see if lamp is shattered. Either one causes this symptom. Good luck, Russmann.
Posted on Jul 01, 2008
I trying to connect my SFC-4160 (security first color ccd camera) the wiring has been cut n there is 5 wires black,red,yellow,white and a bare wire ???? help
Inside the camera is a 4 pin connector connected to the LED Board, with the connector in hand, turn it till you see the pins inside the connector, from left to right wires 1st-white, 2nd-black, 3rd- bare wire or shield, 4th-red, yellow is not connected, the RJ45 end, face the latch away from you, wires are 1st-red, 2nd-white, 3rd-yellow, 4th-shield(bare wire), 5th-black, the LED Board has the wire positioning marked,,,,,
Nov 27, 2012 | Car Audio & Video
How do i plug a game conlone to a direct tv box?
skate,
are you reffering to a game console connecting direct to a TV screen?
1st try to check if your TV screen have a terminal jack indicating "A/V INPUT" A/V stands for Audio/video. if the screen doesn't have this, you'll be needing A/V to RF converter
2nd if your screen does have a terminal jack indicating A/V INPUT the next step you need to do is: check your game consul cable it should have a 3 RCA cable having RED/WHITE and yellow marking.
RED and WHITE cable marking stands for "AUDIO"
YELLOW cable marking stannds for "VIDEO"
connect this cable to A/V input of your screen following the color code ( yellow to yello/ red to red/ white to white) then from the screen press a button indicating "A/V" or "INPUT"
cheers,
mark
Jan 29, 2009 | Toshiba 36A50 36" TV
Zenith 44" LCD TV
The yellow spot is due to the BLUE LCD and/or lens assy cracked, reason, to much HEAT! The blue is the darkest color and hold the most heat, so it goes first, always! In some cases it’s only the lens, however most of the time LCD is damage to. Parts are available, however install and alignment is timely. Quick fix is the complete light engine, which for model# E44W46LCD is part# 3141VSN916C, which customer cost is $1,449.27, wholesale for about $1,065.21. Rebuilt, if you can find it around 850.00 to 950.00. However the rebuilt does not always look as good as factory. My advice, TRASH set. This part will fail again in about 3 to 4 years, unless you watch a lot of white video. Remember, on a black or dark picture, all three LCD are blocking 100% of the light, causing extreme heat within the light engine. It’s a bad design.
TV Tech
Jul 13, 2008 | Zenith E44W46LCD 44" Rear Projection...
Yellow circle
The huge yellow circle is either your blue filter is burnt out (very common in Zenith DLP) or you LCD cube is bad. I would bet it is the blue filter. Zeniths DLPs have 3 color filters one blue (a pinkish color), one green (a grayish brown)and one red (it is red). For the bulb indicator I would check and make sure your lamp is seated to the ballast correctly. Just take it out and put it back in.
Mar 24, 2008 | Zenith E44W46LCD 44" Rear Projection...
Yellow haze
The blue filter is burnt out. A very common problem in Zenith DLPs. There are 3 color filters, 1 blue (a pinkish color), 1 green (a grayish brown) and 1 red (it is red) they give you your colors for you picture. This is a simple fix.
Mar 23, 2008 | Zenith E44W46LCD 44" Rear Projection...
Yellow Haze Center Screen
Mar 19, 2008 | Zenith E44W46LCD 44" Rear Projection...
Seeing Red in pictrue
bad light engine. get in touch with PTScorp.com to rebuild it. after that make sure you get lots of air flow to back of cabinet.
Mar 16, 2008 | Zenith E44W46LCD 44" Rear Projection...
Zenith E44W46LCD 44" Rear Projection HDTV-Ready Television Logo
75 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
