Question about Singer 2517 Mechanical Sewing Machine
I dont know how to thread the singer 2517c sewing machine
  • Anonymous Apr 25, 2009
    threading a 2517c sewing machine
  • Anonymous Mar 17, 2014
    Broken 2517c bobbin holder for Singer sewing machine
  • 323 Answers
All machines thread the same. TTN tension, take up, needle.
Beginning with the spool, guide the thread through the thread guides to the tension assembly. Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test, adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.) If it passes this test, continue up through the take up lever,then down through the thread guides to the needle. Make sure your needle is fully inserted and turned the correct way.( If you load your bobbin case from the left side,the needle rule is normally FLAT to the RIGHT is RIGHT. There are some exceptions. If you have a newer style drop in bobbin or your bobbin case loads in the front then the rule is FLAT to the BACK.
sewman7
Posted on Jun 30, 2008
Sewing bobbin
Found several answers at this site, mostly addressing the tensioner.
Singer Sewing Machine Bobbin thread is bunching up Yahoo Answers
Jan 14, 2015 | Singer Sewing Machines
My bobbin casing came out of my singer 2517c how do you install it
try singer for a manual
Go to the singer website
Go to the home page
Go to customer service--click on it--it will show a small menu--click on instruction manual
In the box put the model number (example 2517) DO NOT A THE C IN THE BOX WITH THE NUMBERS & click search
if search comes up with nothing, contact singer customer service
or try these sites
sewingpartsonline.com
sewusa.com
sew4less.com
ebay
premiersewing.com
Apr 13, 2012 | Singer Sewing Machines
I have a 2517C machine and i can't get it to the proper tention
Very fussy Singer machines, make sure you have a good mercerised thread and you may need to work at the tensions, top should be about 4 or 5
Aug 07, 2011 | Singer 2517 Mechanical Sewing Machine
I do not know how to adjust the tension on my singer sewing machine model # 2517C. please assist.
it should be right in front on the left of the machine small round knob or dail... going from 0123or 0-1-2-3 what is your problem not sewing good on top of material or bottom of material.... take out bobbin put back in change needle... re-thread the machine... sometimes it isnt the tension but just a odd thread in the bobbin case or too much lint from the fabric.... do you use it alot.... hope this helps...
Oct 26, 2010 | Singer 2517 Mechanical Sewing Machine
My daughter has a singer 2517c model machine and i think she is missing a cap to hold the spool of thread on , that model does have that cap right
You can call Singer at 1-800-4singer and order from them, or go to www.sewingpartsonline.com and order one for $3.99. Myself, I would take a prescription medicine bottle cap and cut a hole in it for free, it would do the same thing.
Oct 05, 2010 | Singer 2517 Mechanical Sewing Machine
Singer 2517 Mechanical Sewing Machine Logo
684 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
