Question about Canon DC210 DVD Camcorder
Finalizing disc cannot finalise disc on cannon 201 - done everything right
  • Anonymous Nov 17, 2008
    i can't get the pictures to go on to my computer so annoying
You have to be using dvd-rw not +rw and your canon has to be plugged into a charger when you try to finalize you cant be playing the video you have to be in the menu to do it
Posted on Sep 24, 2008
My disks are DVD-RW and want tp use them over gain and don't know how. Also when do I finalise then and what for
For RW discs, you need to reformat them to reuse them. For your laptop, you should see a format option if you right click on the DVD icon when you have the File Explorer open to Computer (My Computer). (This assumes that the computer has a DVD writer.)
Finalizing the disc enables the contents of the disc to be read on other DVD players. (This isn't always an issue. For example, a disc burned with WinXP should be readable for a computer with Windows 7 without finalizing. However, if the disc was burned by a DVD player, the contents will not be accessible on any other units without being finalized.)
If the disc has been finalized, you need to take another step before reformatting the RW disc. Put the disc in the unit that initially finalized it. Then look for an Unfinalize option. Then format the disc again. (I've never used this feature on my computer. It's easily accessed on my DVD recorder in the same section of the submenu as finalizing the disc.)
I hope this helps.
Sep 12, 2011 | Computers & Internet
The disc won't finalise
Here are the steps (please consider that these are the directions to the Movie Factory, so if you get the Ulead Studio Studio, expect it to vary slightly, probably not too much though)
1) First, it is best to finalize the DVD before editing. This can be done on any type (-R, RW, even RAM I believ, but I have never tried it on RAMs).
-in order to finalize, you must put the DVD into the camcorder and hook it up to its A/C adapter (the wall plug). Find the finalizing but and set your camcorder down (shaking it while finalize may disrupt the process)
2) Eject the DVD from the camcorder and put it into the E-Drive of the computer (the CD/DVD drive)
3) launch Ulead. Creating a new project
4) Once the program opens and you have your basic editing window (with a timeline and all), look for a button that says something like, "import from video DVD", which will allow you to transfer your footage from the DVD to the program, where you can edit.
5) Once you are finished editing, you'll want to export your movie, creating an .avi file, which turns the project file into a standard video file
Hope that wasn't too confusing. I know it seems like a hassel, but its not too bad. Ulead is quite a good program, and its very inexpensive. You can explore other options, but the only one I have found so far to support DVD formats is the Ulead systems.
Hope that helps
Jun 30, 2008 | Panasonic VDR-D100 DVD Camcorder
HOW TO FINALIZE THE DVD CASSETE AND CONNECT TO T.V SET?
Finalising a disc enables the disc to be played on any other compatible machine. By doing this it changes the disc format so that you can no longer record to it turning it into a Play Only disc. On your Panasonic DVD Recorder you can record to many (if not all depending on the model) of the following DVD Disc formats to the limit of their capacity over multiple occasions. The disc in question can be played back and recorded to on the DVD Recorder during this time but until it is finalised it will not work on any other machine.
DVD Formats: DVD-R, DVD-RW, DVD-RAM, DVD+R, DVD+RW.
How do I Finalise my disc?
  1. When you have finished the initial recording stop the disc and press the ~FUNCTIONS~button.
  2. Using the ~UP, DOWN, LEFT, RIGHT arrows~ on the keypad select "To Others" and press~ENTER~.
  3. Using the ~UP, DOWN, LEFT, RIGHT arrows~ on the keypad Scroll down to "DISC MANAGEMENT" and press ~ENTER~.
  4. When the disc management screen opens you need to use the ~UP, DOWN, LEFT, RIGHT arrows~ on the keypad to scroll down to "FINALIZE" and press ~ENTER~.
  5. Using the ~UP, DOWN, LEFT, RIGHT arrows~ on the keypad select "YES" and press~ENTER~.
  6. Using the ~UP, DOWN, LEFT, RIGHT arrows~ on the keypad select "START" to begin finalizing the disc, please note by pressing start here you will no longer be able to record or edit the disc being finalized.
Finalizing may take up to 15 minutes.
Do not disconnect the mains power in this time. A message appears when finalizing is finished, press the enter button when this appears. It will now play on other compatible machines.
Apr 23, 2010 | Panasonic SDR-H40 HDD Camcorder
Dvd does not show what was recorded from my sony camcorder error message C13:02 flashing
This is Disc Access Error, Disk Access Error, Check disc error, Check disk, C error unreadable, disc error code 13, disk error code c1302, c:13:O2 DISC ERROR, Disc Error C:13:02 message Sony mini dvd finalize error code C1302 DVD not finalised, Rec Disabled Record Disable after dropping the camera, DVD not finalized, DVD Disc not finalized, DVD Disk not finalized, DVD Disc not finalised, DVD Disk not finalised, Disc won't finalize, Disk won't finalise DVD Disc Error, DVD Disk Error, DVD Disc Format Error, DVD Disk Format Error, Rec. Disable, not correct disk, the disk in drive is not formatted do you want to format it now.
Nov 15, 2009 | Motorcycles
How to finalise dvd recording
Press the menu button on your remote - go to finalize disc - follow instructions. Note that VR discs can be played with many if not most DVD-players without finalizing. In fact I have had problems finalizing and unfinalizing discs back and forth. If the disc manager displays only unfinalize disc, the disc is already finalized.
Feb 05, 2009 | Samsung DVDR120 DVD Recorder
Cannot Finalize my DVD
We had the same problem, and had the camera exchanged and same thing happened with that one.
I called Canon, JVC, and Memorex, because those are the discs that we used.
Everyone just blamed each other, for either, bad discs, or bad camera.
What we finally came up with was, we have a recordable DVD player that was fairly cheap, under $100. We hooked up the camera to the DVD and copied it to a full size disc. It somehow finalized the disc.
We were also told that we could bring our disc to a video place to have them do it, finalize it. I would cost us $85 per disc.
I hope this helps. I can tell you though, I am returning this camera and getting a different one. We are very disappointed in that finalization step. We almost lost everything!
Dec 04, 2007 | Canon DC210 DVD Camcorder
"FInalize" menu option greyed out on my Canon HR10
works!  Cannon FAQ stinks and never mentioned it.  Thanks for posting the solution!
Nov 11, 2007 | Canon HR10 Camcorder
Unable to finalise
For some reason one of the discs that i have recorded on will not let me finalise. When i put the disc in it says recording disabled and then i go to the finalise menu and the finalise selection is unhighlighted. How can i fix this so i can finalise the disc and use it on my computer?
thanks
Oct 28, 2007 | Sony DCR-DVD602E DVD Camcorder
Finalizing disc
You're doing the right thing and you also have the manual. You are also able to see 'finalise' in the menu, so the camcorder is ready to perform the finalise function.
There are no 'hidden' steps. With your wall adapter plugged in and switched on you should be able to finalise.
Make sure you do not move the camcorder or switch off the wall adapter during finalisation - this could cause problems.
Sep 15, 2007 | Canon DC210 DVD Camcorder
Canon DC210 DVD Camcorder Logo
209 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
