Question about Euro-Pro Ultra Steam SharkTM II Hard Surface Steam Cleaner Vacuum
Can't get the cork to open....and can't find the booklet...also...how much water goes in?
The pro is blue...doesn't say how much it holds...nice looking..black cork on back
  • daddyg111 Sep 26, 2008
    i have the euro-pro x...delux portable steam cleaner...cant open the black cap to put water in, it keeps turning, i press down and turn , i rease the steam, cant do, need help
  • Anonymous Apr 30, 2009
    I did what you've tried and even used pipe pliers, no success. I believe it is a common issue for many users of this Shark steamer.
Request operating instruction for model no. sc 618
Posted on Jul 01, 2008
My Bissell pro heat 2x 9200 won't put out water HELP!!!
Hey Brenda! I can understand how frustrating it can be when you're ready to clean your carpets and no spray.
Here's a link to troubleshooting steps to assist you.
http://www.bissell.com/FAQDetail.aspx?id=1122&cid=ccsocial
Jan 15, 2013 | Vacuums
What to do when blue light is on and water wont come out the steam penguin
Blue light comes on top of penguin gets hot but the water tank stays cold no steam
Oct 28, 2012 | Euro-Pro Steam Penguin Hard Surface Steam...
How to fix shark vac then steam that doesn't emit steam
Replacement parts can be found on amazon, take a look: Amazon com shark vac parts . Have a nice day
May 08, 2012 | Vacuums
O-Cedar Pro-Mist trigger doesn't work
This person is asking about an O'Cedar Pro Mist Mop. Not a vacuum or steam mop...
I too have problems with the pro mist handle not working... I called the customer care line at 1800-543-8105 and they are replacing my mop for free. You can also try to take it apart and fix it yourself, but I did that and I cant remember how it goes back together! lol Basically a spring comes loose from the pole inside of the mop handle, and that is why there is no tension in the trigger.
Feb 19, 2012 | Vacuums
Shark S3101 Steam Mop won't produce steam
You have to use distilled water in the steam mop. regular water clogs it up and causes it not to work.
Nov 27, 2011 | Euro-Pro Shark Steam Mop - Gray/ Purple...
While using, steam stopped coming out in force at the port levels in the head. Suddenly started high pitch whining, pressed button just above connection site and end flew off with great force pouring...
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it may not be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the Shark Manuals that you need.
heatman101
Nov 15, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Whare does the dirty water go in the bissel 12 amp pro heat carpet cleaner
the clean water goes into a "Bladder Bag" that is located inside the tank. The way it is designed to work, as the clean water dispenses from the bladder bag, the outer part around the bladder bag fills with the dirty water. It never touches the clean water. Seems wierd, but it works! I hope this helps, if it does, please give feedback, as it helps me to gain ratings. Thank you! Remember to have your cleaners serviced every year by a qualified tech! Rene (The Vacuum Doctor)
Nov 06, 2009 | Bissell Carpet Cleaner Powerbrush Deep...
Replace bel
There are 6 screws on the hood, remove them. Unscrew the cap which holds the red x in place and remove. Gently pull up on the top housing and it will come off. Remove the 4 screws which are on the pump and slide the pump out, install belt and reinstall
Aug 25, 2009 | Bissell 1697-7 Powersteamer Pro Deluxe...
Euro-Pro Ultra Steam SharkTM II Hard Surface Steam Cleaner Vacuum Logo
146 people viewed this question
Top Euro-Pro Vacuums Experts
Dennis Key
Dennis Key
Are you an Euro-Pro Vacuum Expert? Answer questions, earn points and help others
