Question about LG enV VX9900 Cellular Phone
Takin apart my phones charger input has been disconnected from my phone somehow. and i want to take apart the back and maybe connect it again? how do i take apart the back. or should i just take it the vzw store?
  • 20 Answers
Do not, do not, do NOT take it apart !! :) that will void ur warranty. as it is, if u are within ur first year, take it into a store or call tech support for a replacement. if ur past a year, use ur insurance or upgrade options. charging ports really cant be fixed. but if u take it into a store with a tech, they may try to fix it, but dont get ur hopes up
Posted on Jul 06, 2008
How to disconnect the charger port in my phone step by step
Take phone apart, desolder the four connections with a micro-soldering iron, use a solder sucker to safely remove the molten solder. However I'd recommend not doing this and taking your phone to a professional to have any such work done.
Jan 09, 2015 | Alcatel T-Mobile ONETOUCH EVOLVE 3G...
My phone keeps saying it's charging when its not even plugged in. But although it says its charging the percent of the battery goes down real quick what can it be. And if I connect the phone to the...
check the input and spray compressed air to clean.. do not blow into it cause moisture is expelled when blowing. turn of device and remove battery. spray again. wait 15 minutes. place battery back in power on
Oct 04, 2017 | Cell Phones
My phone will not charge, I have a feeling that it is a problem with the phone charger itself, beacuse it will connect my car charger. This is really annoying, I have to play around with the wire until it...
The problem actually is not from the charger, it is from the charging port of the phone.
The pins that are in the charging port are wearing out that is why you have to adjust the charger before it will stay in.
The only solution to that is for you to replace the charging port.
To replace the charging port, get the appropriate screwdrivers, then you remove the phone cover, the sim and the battery, then you unscrew the phone, try to separate it apart to locate the charging port, then you replace it with a new one, after replacing it, reassemble the phone back together and it will be in good condition once again.
Take care and good luck.
Oct 19, 2010 | Samsung SCH-u740 Cellular Phone
Lg Cookie wont turn on
You need to re-update (FLASH) Bios. It must have got corrupted. The worst part is that there is no support from LG
Sep 03, 2009 | LG KP500 Cookie black on T-Mobile U-Fix...
My iPAQ 5555 won't charge.
well that's really the problem when u go ur phone stocked for a weeks or two. i have my advice.. try charging yout battery manually. how is that? modification is needed. remove your battery from ur phone. and connect it to your charger directly.. (how is that? create a wire that can connect your charger to your battery. make sure u connect the right polarity) in this way your battery will charge for a moment and will give enough power to turn on your phone. because showing up that orange thing when charging up needs an initial power. so that is why. but still u can charge your phone. just live it maybe for an hour. it may work!
Aug 16, 2009 | HP iPAQ H5555 Pocket PC
Can't turn on samsung m620
have you ever figured out what happened???
the same thing happened to me over the weekend and it's annoying that there's no information at all about anything.
I can't figure out what's wrong and your description is EXACTLY what happened to me. One moment everything was great - the next it's dead.
Please let me know if you figured it out somehow ??? Thanks
Geni
dyna_bella@hotmail.com
Aug 05, 2009 | Samsung UpStage SPH-m620 Cellular Phone
Usb connection on by itself and stuck on
Son's was doing the same thing. Read on another site that this means the USB is making a connection somehow, usually from getting a little moisture in there where the USB (or battery charger) plugs in. Wrapped a tissue around a toothpick and wiped it out good. Phone is now ok.
Jan 01, 2009 | LG RUMOR Cellular Phone
Phone does not charge
When my phone is connected to the charger, it says fully charged. But as soon as I disconnect the charger, the battery shows empty. When I connect the phone to the charger, it starts charging but after 10 seconds it says fully charged.
Aug 08, 2008 | Sony Ericsson K600i Cellular Phone
Front side and back side of my phone got separated
looks to me you need a new flex cable and maybe a lcd screen if it cracked. i have repaired these before. flex cable on ebay is about 15-17 bucks, and the lcd is about 180 and up.
Sep 06, 2007 | Samsung SGH-t629 Cellular Phone
LG enV VX9900 Cellular Phone Logo
136 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
