1992 Oldsmobile Cutlass Ciera Logo
Posted on Dec 13, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Ice storm caused the doors to be frozen shut. When I finally got one of the rear doors open, I crawled into the front and kicked open the driver's side and passenger's doors. Now the latches are broken. Not sure if it's broken from the inside, outside or both. Since the latch won't work to keep the door closed, the interior lights stayed on. Pulled out the lightbulbs to break the circuit and hopefully not drain my battery. Any chance there's an (semi)easy fix to either the door latches or the interior lights? I've called an auto repair place but haven't heard back yet.
Anonymous
Level 2:
New Friend:
  • Expert 152 Answers
  • Posted on Dec 13, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
152
Questions
0
Helped
39440
Points
462
Ok open the door and look at the latch now while you are looking at it pull the handle as if you were going to open the door the latch should move if it doesnt it is stuck all you have to do is take a screw driver or something and manually move the latch and free it up hope this helps and next time youre doors freeze shut try a warm water in a bucket pour on all edge of door and it should open a lot easier good luck
  • Anonymous Jan 18, 2011
    I have this problem every winter, it's not that your latch is broken, it is probably the fact that your latch is now frozen open as some of the cutlass cieras do not have just one latch on the door. If you take a look at your door when you open it, there may be two latches at the top, and your main latch at the bottom. Those two on the top are what keep the door secured, and that is the clicking sound you hear every time you close the door. I would suggest just letting it warm up, seems to work with mine, but I also found not locking the doors in the winter completely fixes that issue.
Specifically I'm trying to identify the wire on the spark plug coil assembly to which I should connect the signal wire of a Tachometer to. The wire colours are, red, yellow, green/white, and blue.
It says the tachometer wire is Yellow/Green, you do not have that listed. You will find it in the list below, it is highlighted..
WIRING INFORMATION 2001 Subaru Legacy
WIREWIRE COLOR LOCATION
12V CONSTANT WIRE WHITE Ignition Harness
12V IGNITION WIRE GREEN Ignition Harness
12V ACCESSORY WIRE YELLOW Ignition Harness
STARTER WIRE WHITE/BLACK Ignition Harness
POWER DOOR LOCK (-) WHITE Harness In Driver's Kick Panel
POWER DOOR UNLOCK (-) GREEN/RED Harness In Driver's Kick Panel
PARKING LIGHTS (+) ORANGE At Light Switch
DOOR TRIGGER (-) PINK/BLACK In White Connector Behind Fuse Box
TRUNK TRIGGER (-) YELLOW/BLUE In White Connector Behind Fuse Box
TRUNK RELEASE (5-wire) LT.GREEN/YELLOW At Motor In Tail Gate
FACTORY ALARM ARM (-) Factory remote only
FACTORY ALARM DISARM (-) Factory remote only
TACHOMETER YELLOW/GREEN At Ignition Coil
BRAKE WIRE (+) WHITE/BLACK At Brake Pedal Switch
HORN TRIGGER (-) RED/GREEN Harness At Steering Column
LEFT FRONT WINDOW UP BLUE/RED At Driver Window Motor Inside Door
LEFT FRONT WINDOW DOWN BLUE At Driver Window Motor Inside Door
RIGHT FRONT WINDOW UP BLUE/RED Harness In Driver's Kick From Driver Door
RIGHT FRONT WINDOW DOWN BLUE Harness In Driver's Kick From Driver Door
LEFT REAR WINDOW UP BLUE/RED Harness In Driver's Kick From Driver Door
LEFT REAR WINDOW DOWN BLUE Harness In Driver's Kick From Driver Door
RIGHT REAR WINDOW UP BLUE/RED Harness In Driver's Kick From Driver Door
RIGHT REAR WINDOW DOWN BLUE Harness In Driver's Kick From Driver Door
2answers
Doors wont open from outside
Broken exterior handles
My front doors won't open on 1997 toyota avalon
The door gaskets could be frozen to the body, or you could have ice in the door latches.
Can you drive the car into a warm garage ?
1helpful
2004 honda accord driver side lock won't open remote
driver side has most use and breaks down quickest.
Typically, the lock wears, and should be oiled using graphite powder, not oil, as with most outdoor locks.
However, in winter moisture turns to ice and freezes lock.
In this case, try to squirt lock de-icer (usually this is methyl alcohol or some other type).
Don't use an alcohol (such as from drugstore) that also contains water.
that would make matters worse.
If you spray enough lock deicer or even a high-quality penetrating oil, you may be able to work key and lock to a point where you can turn it.
Don't force key rapidly or too strongly, as it will bend, and may break off in lock.
You can spray some alcohol or penetrating fluid on the key to work it into the lock better.
Sometimes, you can get at a frozen lock mechanism by spraying down into **** between window and metal door from above lock.
Sometimes, you might find that the door itself is frozen,
or the lock latch is frozen, and not the key-tumbler.
In this case, you can try body-checking (not kicking) the door,
to loosen the frozen edges around door and window.
If you can get into car from other side, you can sometimes open it from inside to break ice-jam.
If this is an electrical problem
(only remote doesn't work)
The likely cause is broken wire in wire-harness from car body to door.
There will usually be a group of wires either inside a cable or bundled in a rubber tubing, going from car to door at front between hinges.
Here is where the electrical connection will be broken,
because the wires break eventually as they get flexed over and over.
IN this case, the only permanent fix is to find the wire (it will be color-coded), and replace at least 6 inches of that wire (it will probably be broken inside insulating sheath.)
Alternately, there may be an open-circuit at connector to door-latch solonoid. Here you might get lucky if you get inside door-cover off and wiggle or re-insert the plug connector.
Also possible that solenoid is just burnt out or open-circuit.
In that case it must be replaced, for the remote signal to effectively open door lock.
2answers
My windows are both frozen shut. the drivers side used to open with a key from the outside. the only way I can get in is to crawl through the moon roof.???
try to pour hot water on it and get it open then clean window very well exspeciaally the rubbers or channels put a little prestone on a rag and go all around the rubbers and channel not on the glass then open and close and as well the doors you can do the same they shouldnt freeze tight
After ice storm cannot get doors to close
get a hair dryer or heat gun on the locks. WD40 will work eventually depends how deep the freeze is.
25helpful
2answers
BMW X5 2001 -DRIVER OUTSIDE DOOR HANDLE WILL NOT OPEN DOOR.
DRIVER OUTSIDE DOOR HANDLE WILL NOT OPEN DOOR. FROZE UP IN ICE STORM AND APPEARED TO BREAK WHEN TRIED TO OPEN DOOR. INSIDE HANDLE STILL WORKS. IS DIY REPAIR FEASIBLE?
5helpful
Both manual sliding doors on my Toyota Sienna will not open
If you can remove the inner door panel you will see a maze of cables running to the various locking points on the sliding door. If the cable going to the FRONT latch on the sliding door is broken (or in my case, simply dislodged inside the door) the door acts as if it is frozen shut.
The front cable is short, and easily replaced even by a newbie mechanic.
Top Oldsmobile Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you an Oldsmobile Expert? Answer questions, earn points and help others
