Question about Philips 170B4MG 17" LCD Monitor
No Image but power
I have a Philips 170B LCD monitor.
When I switch the monitor on, I shortly get the message NO VIDEO SIGNAL. This message is on for about 1 second.
The monitor goes black, but the power led stays green.
When I shine with on the monitor with a flashlight, I can see what should be on the screen.
What can it be? The backlight?
Ro.
  • quatermaine Jul 29, 2008
    Almost same prob but I get a display for about 1/2 second then the display vanishes
  • eminemlover1 May 01, 2009
    I am trying to connect my toshiba satelitte to a philips 170b computer monitor. there is power to it but it has a pop up that says "attention: no video imput" how do i fix it!!!!?
    Problem Solver:
  • 8 Answers
The problem is with the Backlight inverter. For some reason the overcurrent trips after a few seconds. I got around it by hacking the inverter to prevent the overcurrent from tripping, but if you aren't familiar with electronics, I can only suggest a new screen.
Posted on Aug 24, 2009
It is not the videocard. ;-)
Tried the monitor on different computers.
And even when it's not connected to a computer, he should give image like "Check cable".
Even that appairs for about a split second.
Posted on Nov 05, 2008
On another question related to LCD monitors turning on and off within a few seconds, people suggested that aged/burnt out capacitors on the powerboard inside the monitor needed replacing. A relatively easy job for any technician to do.
Posted on Sep 19, 2009
    Genius:
  • 1,605 Answers
Find the manufature of the video card, use the old monitor and go to the video card manufacture and download the video driver.
Hello, I have a Philips 170 B monitor and I am having problems with it. Even after my computer is switched on- I see nothing on the screen - it's blank- but the monitor's power light is on. I've tried...
mcdevito75 here, Sounds like your moitor is burned out, I would take the monitor to a Staples, Radio shack and have it tested. Monitors are just like a light bulb and do go bad or burn out.
Aug 12, 2010 | Philips Business 170B 17" Flat Panel LCD...
NO video input philips 180p1
Hello there:
This normally means that the cable that goes to the computer from the monitor is not getting any signal from the video card
This is due to a couple of possible problems
the graphics card is not compatible with the monitor
Or the graphics card is faulty or dirty and needs to be removed and cleaned with rubbing alcohol and than reinstalled
I would first try this on a different computer to see if the monitor now works if so han you know you have a graphis card problem but if it does not work than you know that the monitor is the one with the problem
It may have a faulty controle circuit on it and needs to be serviced or jut simply replaced ok
If you do take the video card out of the computer Unplug the power supply to the computer than remove the power supply cord to the mother board and press in on the power button for 1 minute this will release any esd (electrical static dicharge) that is built up during operation than attach it back on the mother board and continue to remove the graphics card and make the replace ment or repairs needed ok
I hope this is very helpful for you
Best regards michael
Dec 18, 2009 | Philips Business 170B 17" Flat Panel LCD...
No video image on LCD but OSD works
Sounds like you may have a bad video cale or a dmaged or bentpin in the connector, remove the cable from the monitor and look at the pins on the connector
Dec 14, 2009 | Philips 170S4FG 17" LCD Monitor
I have a left-right blur on my Philips 170B monitor. Tried resetting several times, but no joy. Can you help? Thanks :-)
if u'r eng. change the crt base in video board or u'can set u'r defocusing prob by EHT focusing section
Dec 12, 2009 | Philips 170B4MG 17" LCD Monitor
Screen message reads "no video input",blue scart is connected at both ends,what have i missed? Pillips 170b monitor
Try another monitor with your computer if this still doesenty work then your graphics card is at fault
Nov 26, 2009 | Philips 170B4MG 17" LCD Monitor
Monitor problem garbled after an hour or so
The frequency of the Monitor must be the same with the settings that you choose in the Control panel of your monitors driver. Try changing the this frequency in the monitor's settings.
Mar 27, 2009 | Philips Business 170B 17" Flat Panel LCD...
Volume Control Bar does not go away
IN THE SETTING OF THE COMPUTER SOME WHERE IN THE SETUP OF THE COMPUTER YOU CHECK A BOX NO ON PERPOSE JUST BY ACCENDLY PICKING IT AND NOT UNDERSTANDING WHAT THEY MENT IN THE BOIS, INTER NET OPTIONS OR YOU MAY HAVE TO GO INTO THE BOOT LOG AND UNCHECK THE BOX FOR BOOT SEQUENCE SETTINGS,SYSTEM CONFIGURATION, BOOT OR STARTUP FILES
REBOOT SYSTEM YOU MAY HAVE TO DO THIS SEVERILY TIMES
ROD
YOU MAY HAVE REGEDIT
IF YOU NEED THAT TYPE OF ASSISTANCE I MAYBE ABLE TO HELP YOU BUT I PERFER YOU GO TO SOMEONE THAT DOES COMPUTER PROGRAMMING
ROD
Feb 09, 2009 | Philips Business 170B 17" Flat Panel LCD...
Monitor
sound like the power supply or the monitor bulb is going.
try the monitor on another PC if you can get one, if it works, then you have to find ou the manufature of the video card and get the driver.
Nov 05, 2008 | Philips 170B4MG 17" LCD Monitor
Philips 170B4MG 17" LCD Monitor Logo
596 people viewed this question
Top Philips Computers & Internet Experts
Computer Repairing
Computer Repairing
micky dee
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
