Question about Linksys Wireless-G WRT54G Router
Low id by amule
Hej,
i am getting the warning low id bei amule, reason iam behind a router or firewall how can i change this, my betreibs system is linux.
thanks in advance
brite60
  • david May 11, 2010
    I am no longer active on this site. I hope someone else here can assist you.
    Genius:
  • 1,269 Answers
The router has a built-in firewall (NAT) and it can't be disabled. By the way, what is the model # or brand of your router? You'll just need to disable the 3rd party firewall on your system.
Posted on Jul 14, 2008
Not able to browse the sites using Netgear DGN2000 router...
May be good to disable all additional settings. e.g. firewall or Port forwarding. I am assuming that you are able to authenticate (connect with user id + password) as you mentioned youtube works fine. So in that case, there shouldnt be a basic issue but more of a port forwarding or nat. Also check your laptop for any setting changes or personal firewalls.
Try pinging local gateway, then DNS then any international website. Based on that you can focus on the problematic area.
Apr 07, 2014 | NetGear DGN2000-100NAS Router
How do I change the firewall settings to low so I can connect to Xbox LIVE?
PS3 And XBOX :: BELKIN
Step 1:Connect Modem - Router - Computer (Wired)
Step 2:Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3:On the Left click firewall
Step 4:Leave the Password blank and click submit
Step 5:Disable it and click apply changes
Step 6:Scan and connect in the Xbox/PS3/Wii
Step 7: Get the IP Address of the Xbox/PS3/Wii
Step 8:Open Router Setup in the Computer
Step 9:On the left under Firewall Click DMZ
Step 10:Enable the IP Address of the Xbox/PS3/Wii in it
Step 11:Click Apply Changes
Step 13:On the left Under Utilities click System settings
Step 14:Scroll down to the bottom
Step 15:Enable UPnP
Step 16:Click apply changes
Step 17:Test the connection ,Check the NAT
If working then let me know
If it is still not working
Open Router setup
At the middle Under internet settings check the WAN IP
IF it starts with 192.168. or 172.16 Then you will have to contact your internet service and ask them to bridge the modem
Nov 29, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Hej. Er der nogen her som taler dansk
Hej Trille,
måske du også ville give mig "FixYa her :-)
Tak
/Teis
Dec 03, 2008 | Linksys Wireless-G Broadband Router
Emule lowid
I am sorry, but I would not listen to advice that you need to disable your Firewall for it to work!?!
Obviously as the response shows, even with the Firewall disabled it did not work [and would be vulnerable to attack]
There are two possibilities off hand:
  1. You have not taken into account forwarding ports in your Router as well as Software Firewall [if applies to you]
  2. Your ISP may be aware of using the ed2k protocol and try to stop you from using eMule
Remember to use the OBFUSCATION option.
This option in eMule allows you to connect to a server in a way
that masks or 'hides' the ed2k (eMule) protocol
Go To Options > Security
Here you'll tick the "Enable Protocol Obfuscation" box
Remember to only tick the first box under "Protocol Obfuscation"
You should be able to see your 'hidden' status on the right side
of the server window in eMule
If your ISP was in fact interfering, this should help you gain back your ability to use eMule without restriction
Oct 06, 2007 | D-Link DI-707P Router (DSDLDI707P)
How to port forward using Dlink DI-524 for Emule?
DMZ is a feature that is included on some routers but is not in Internet sharing software. A DMZ allows a single computer on your LAN to expose ALL of its ports to the Internet. When doing this, the exposed computer is no longer ?behind? the firewall. Port Forwarding vs DMZ A DMZ is far easier to set up than port forwarding but exposes your entire computer to the Internet. Sometimes TCP/IP applications require very specialized IP configurations that are difficult to set up or are not supported by your router. In this case, placing your computer in the DMZ is the only way to get the application working. Placing a computer in the DMZ should be considered ?temporary? because your firewall is no longer able to provide any security to it.
Oct 03, 2007 | D-Link AirPlus DI-524 Wireless Router
Low ID on emule when am using Belkin F5D7230-4 router
You need to find out what port Emule uses for sharing, then enter the port number in you routers Firewall Virtual Servers menu in the settings and enable your pc's ip address to accept inbound connections.
Jan 20, 2007 | Belkin F5D7230-4 Kit (F5D7230V4SNPDQ)
Low ID on eMule
One more thing re low id on emule - try to choose ports between 10000 and 60000 - many isps block the standard ports that emule users choose, and you will see people saying to choose one over 5000, but I'd chosen ports between 5000 and 10000, and still had no luck until I went over10000.
Most isps don't monitor ports over 10000, so if you still have low id problems even after port forwarding and setting up your firewall, this may be the answer to your problem! (I got this info off portforward.com, and it worked for me)
Feb 16, 2006 | D-Link DI-707P Router (DSDLDI707P)
Configure for emule
You must open ports on your router to allow incoming traffic while using eMule. eMule uses three ports*: 4662 (TCP) 4672 (UDP) 4711 (TCP) Visit eMule here. * To prevent getting a low ID (Firewalled), open additional TCP ports between 4661 and 4665. Also, limit the number of connections in the eMule software. You may need to change the TCP Clientport to something other than 4662.
Emule
There are several reasons why this is happening. Most likely the reason is simply because you are behind a router or firewall and the correct ports are not open.
Feb 16, 2006 | D-Link Express EtherNetwork DI-604 Router
Linksys Wireless-G WRT54G Router Logo
252 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
