Question about Braun Tassimo Espresso Machine/Coffee Maker
All lights are blinking on my tassimo coffee maker
  • bevg8 Feb 05, 2009
    when I put a new disc in my tassimo all the lights start blinking and it does not work.
I also had this problem, it was caused by the bar code reader being steamed up. Just wipe the cover of the reader (where you put the disks in) and it shoud stop.
Posted on Jul 30, 2010
  • 4 Answers
One of four things possible here 1: Low water level in container. 2: no disc inserted. 3: disc incorectly inserted. or 4: unit has an internal malfunction, before you send it back, descale unit with scaler and flush clean. All lights still flashing call Tassimo and send it back for repair.
Jim.
Posted on Jul 07, 2008
Check the low water level magnetic sensor. Easier said than done. :) I had the same problem. Mine was blinking. Figured out it was the magnet in the reservoIr or the magnetic sensor in the machine had weakened or broken. To fix the problem some handy work is involved... Dissemble the grey outside covers by removing several screws. Once exposed you can see where the low level magnetic sensor is on the inside. A white rectangular piece with two white wires coming from it. Follow these two wires up until you find where they plug into the circuit board. Unplug the connector the two white wires are attached to. Now the tricky part. You have to bend the two prongs, that the two white wires were connected to, on the board so that they touch each other and 'short out'. Any way you can get the two prongs to touch will work as well. Essentially your tricking the machine into thinking there's always water in the reservoir. Just make sure to always have water in it, as it will run dry like this now. You should be able to turn it back on and everything's back to normal. Hope this helps out.
Posted on Jun 18, 2012
  • Keek Vaughan Nov 11, 2012
    Hey this works great- I just cut and stripped the two white wires and twisted them together (leading to the circuit board), now it works like a champ. Thanks man
  • 36 Answers
Unplug coffee maker and wait 5 minutes plug in and reset timer
Posted on Jun 30, 2008
  • Bayside May 28, 2013
    Good advise - thanks to you I am enjoyingmy mornig coffee :)
SOURCE: manual for Braun Tassimo TA1400 CoffeeMaker.
I found a website under Braun that had the operating manual in pdf.
Posted on Jul 02, 2008
SOURCE: manual instructions bosch tassimo coffee maker
hi, this morning I was making a capuccino, and the first part was fine, the expresso was fine, I waited for the light to change colors, open the lid, put disc with the cream in the machine and the green light won't come on, only the yellow on the left hand side and is not working<br /><br />
Posted on Aug 23, 2010
  • 3 Answers
SOURCE: NOT SO GREAT COFFEE GROUNDS!
Might there be some stuff crusting the dispanser vent? Did you clean it regularly? If you've not done that, this is what you do:
1) Open up the lid where the T-Disc is supposed to go.
2) Take out any moveable (not breakable) object, for instance the thing that punctuates the T-Disc(its made of two parts stuck together) and the T-Disc holder.
3) Take 'em apart and put 'em into your dishwasher or wash it by hand.
4) Wipe the entire T-disc area with a damp cloth, make sure nothing stays there that isn't supposed to be there.
5) Put the removed and cleaned parts back very carefully and watch out that they are exactly in place, if in doubt wheter they are fitted correctly, just shake them a little. There should be no movement other than up and down.
6) Enjoy your coffee!
Posted on Jan 23, 2009
  • 5 Answers
SOURCE: Braun Tassimo Coffee maker quit working
Hmm if not in covered try
http://rapidshare.com/files/238159116/Braun_Tassimo_3107_Disassembly.pdf.html?killcode=397312781122638452
Posted on May 28, 2009
  • 92 Answers
SOURCE: Tassimo Coffee Maker: Tell me
• All lights will blink the first time you turn on your
machine. This is your cue to prepare your machine for use by
following the quick instructions in Step 1 on separate insert.
• If the water level runs low while you are preparing a
beverage, all lights will flash. Simply remove and refill the
water container, and brewing will continue automatically
where it left off. It should not be necessary to discard the T-DISC
and start over.
• The AUTO light will blink throughout the brewing process.
Some drinks require a pause in brewing as part of the recipe
for brewing your perfect cup - this is to allow the optimal flavors
to unfold and is a normal part of the brewing process. The AUTO
light will continue to blink throughout this process.
HOW TO MAKE A DRINK
• Place the mug of your choice on the cup stand.
• When the STANDBY light illuminates, insert the T-DISC® of your choice
and close the clamp.
• The HEATING light will blink as the brewer heats the water to the
optimal temperature for your drink.
• Once the proper temperature is reached, the AUTO light will
illuminate. When it lights up, press the start/stop button to begin
the brew cycle.
• The AUTO light will continue to flash throughout the brewing cycle.
PLEASE NOTE: Some beverages have a pause in brewing
after the initial influx of water into the T-DISC®.
• The MANUAL light will illuminate when your drink is ready.
Posted on Jan 14, 2011
The lid won't open to get the used coffee pod out. It seems to be stuck.
Customer questions and answers for Bosch TASSIMO T10
answers.tassimodirect.com/answers/.../bosch-tassimo.../questions.htm?...
The TASSIMO T10 Single Cup Brewing System by Bosch brings the artistry ... the machine made some funny noises and now I cant open the lid to remove pod. ... When I went to remove the T-disc, the tassimo won't open so I cannot get it out.Missing: tas5542gb
Bosch Tassimo TAS4511UC Coffee Maker Open ... - Fixya
www.fixya.com > ... > Bosch Tassimo TAS4511UC Coffee Maker
Question about Bosch TASSIMO Coffee Makers & Espresso Machines ... colors, openthe lid, put disc with the cream in the machine and the green light won't come on, only the . ... Bosch Tassimo Tas5542gb Multi Hot Drinks Machine, Black.
Why has my Tassimo brewer stopped working?
www.coffeedetective.com/why-has-my-tassimo-brewer-stopped-working...
QUESTION: I have a problem with my Bosch Tassimo brewer. ... Now when I close the machine, I open it and remove that litte tin foil circle. ... Opened my new Tassimobrewer and won't brew and water dispenser leaking all over... an ... I have a problem with my tassimo coffee maker the lid wont lift up seems stuck any ideas ...Missing: tas5542gb
Jan 19, 2016 | Bosch Tassimo Tas5542gb Multi Hot Drinks...
Water sat in the bottom tray of my tassimo t65 and now it has two red lights flashing can I fix it
Bosch Tassimo T65 Repair Questions,... - Fixya
www.fixya.com > ... > Coffee Makers & Espresso... > Bosch > TASSIMO
0 Answers. Water sat in the bottom tray of my tassimo t65 and now it has two red lights flashing can I fix it · Bosch Tassimo... ' Posted on Aug 23, 2014 ' Be the ...
Bosch TASSIMO red light water full Unsolved Problems - Fixya
www.fixya.com/unsolved_problems/red_light_water.../tassimo
0 Answers. Water sat in the bottom tray of my tassimo t65 and now it has two red lights flashing can I fix it. Aug 23, 2014 ' Coffee Makers & Espresso Machines.
Bosch TASSIMO cleaning condensation tray Unsolved ...
www.fixya.com/unsolved_problems/...condensation_tray/.../tassimo
Aug 23, 2014 | Bosch Tassimo T65
Why standby light active and water tank fill light is blinking ?
It shouldn't harm it plus if the scale is affecting the switch for the watertank then it should sort it out....
Jul 25, 2014 | Bosch Tassimo TAS4011GB Coffee Maker
Braun Tassimo - plug it in and no lights
have you switched it on on the back of the tassimo
Jan 13, 2010 | Braun Tassimo Espresso Machine/Coffee...
All light blink same time
Water empty or water container not sat properly in its mount at the back of the machine
Jan 04, 2010 | Braun Tassimo Espresso Machine/Coffee...
All the lights come on. There is water, and
4 lights blinking can also mean that the barcode reader window, right under where the barcode falls, has coffee, milk, etc on it. Wipe, re-close on the t-disc, and lights go out.
Dec 14, 2009 | Braun Tassimo Espresso Machine/Coffee...
Wont heat or make coffee lights keep blinking
All lights flashing -
The machine is not prepared for use. Check water level, T-DISC.
Also try this link for the user manual:
http://www.scribd.com/doc/2421389/Braun-Tassimo-User-Guide
Another thing, try unplugging the machine; wait 5 minutes and plug back in.
Refer to the user guide for further diagnostics.
If you're still having problems contact customer support - number in user guide.
Thanks for trying Fixya.com
Mike...
Nov 29, 2009 | Braun Tassimo Coffee Maker
Every light blinks and it won't heat water a braun tassimo coffee maker
just posted this solution to another problem. there is something on the glass bar code reader up where you insert the t-disc - or the water vessel is not properly seated in the base of the coffee maker.
Check both.
Nov 04, 2009 | Braun Tassimo Coffee Maker
Braun Tassimo Type 3107
I found that most problems around the tassimo relate to the peircing mechanism being clean and properly in place (it moves sometimes when you open the lid), or that the "window" that reads the barcode needs to be kept clean. When i've gotten all lights blinking or going right to manual, I have found cleaning the window seems to fix the problem more often than not.
hope that helps
Jan 19, 2008 | Braun Tassimo Espresso Machine/Coffee...
Braun Tassimo Espresso Machine/Coffee Maker Logo
4,790 people viewed this question
Top Braun Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Are you a Braun Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
