Question about Indesit 18 in. D41 Slim-Line Free-standing Dishwasher
Indesit Dishwasher- Flashing Lights 1 and 3
When the dishwasher is switched on water appears to be going in but after a short while the dishwasher drains water and the green lights at the top left of the unit flash.When the door is opened the interior is quite dry.
I would be grateful for any help.
Regards, David
SOURCE: Mouse inside dishwasher
I have put steel mesh over the plastic mesh which I got at the hardware srore, and it fixed the problem. the mice are getting in through an exterior hole in your house. Use coarse steel wool to plug any holes or cracks larger than 3/8 of an inch around your house. How much did you pay for your dishwasher unit?
Posted on Feb 17, 2007
  • 27 Answers
SOURCE: indesit dishwasher DV62
You have a blockage in your drain pump. Remove all filters and scoop out as much water as you can from the unit. Check in the bottom for any objects stuck there. Some models have a cover on the bottom inside the unit, which once removed, will expose the drain pump impeller. If yours does, remove the cover(usually 1 screw only) and free the drain pump impeller. NB: DO NOT REMOVE THE SCREWS WHICH HOLD THE BASE TUB IN PLACE! These are the screws on the edge of the white plastic "bowl" inside the unit. The drain pump cover will be INSIDE this bowl and will be quite small, no more than 5cm dia.... If this does not work, you will have to remove the drain pump from the bottom or front of the unit to get the blockage out. Oshie
Posted on Jun 26, 2007
  • 236 Answers
SOURCE: Lights flashing on dishwasher and not working!
put some towels dowm and tip the d/w over to one side about 45 degrees if water pours out of the base it means that the d/w is in "flood mode" and you have a leak into the base that will need resolving.
Posted on Feb 16, 2008
SOURCE: Broken door handle Indesit dishwasher DG 6100
broken door handle solution
Posted on Mar 07, 2008
mosesclive
  • 191 Answers
SOURCE: Indesit DI620UK Dishwasher fault
If the dry cycle has a problem, check these:
Heating element
Drying fan
Thermostat
Heating element Your dishwasher has an electrical heating element that helps to dry the dishes. If the element is burned out, the dishes won't dry properly, and you need to replace the element.
Drying fan Many high-priced dishwashers have a small fan that blows air or heated air into the dishwasher to speed up the drying process. If the fan is defective, you need to replace it.
Thermostat Some dishwashers have a thermostat that monitors the drying temperature. If the thermostat is defective, the heating element may not cycle on or off properly. If that's the problem, you need to replace the thermostat
Posted on Jul 19, 2008
Indesit dishwasher idl40 s I have lights 1 and 3 flashing after shortly staring it's cycle. Then it empties and stops but there is no water hardly when I open the door. Any ideas please??
It would appear that the washer is not getting water, though it could be aborting the cycle early for some reason.
Try to google "Indesit dishwasher idl40s lights 1 & 3 flashing", and various permutations to see what others have said. At the least you need to understand what that pattern of lights flashing means.
There is an electric valve that the washer controls to allow it to fill with water when needed. This may be clogged or may have failed.
Pursue the flashing light issue first so you understand what the washer is complaining about.
Pete
Aug 30, 2015 | Indesit Dishwashers
Why my AEG F55080vi stops after drain cycle (program beginning) and then it stops and I hear 2 beeps and 2 flash continuously?
Definitely, water drain time-out. Error code i20.
The pressure switch doesn't return to EMPTY (1-2) after two drain phases lasting 120 seconds.
Possible causes:
Drain circuit obstructed/blocked; drain pump
interrupted or jammed (foreign bodies); level
pressure switch blocked on FULL (1-3); hydraulic
circuit of pressure switch obstructed; wiring faulty;
circuit board faulty.
Thanks to your detailed description of failure I conclude that in drain phase (after starts drain pump) leaks water and causing a short circuit. I would thoroughly reviewed drain hydraulic circuit. If is alarm displayed and there is no water inside dishwasher then check heater and anti-interference suppressor.
Dado
Jul 12, 2014 | AEG Dishwashers
Moyer Diebel 301 always draining
what I can tell you is that if the water temp is not high enough say 120 deg, the dishwasher washing cycle will extend.chk your drain hose and float valve for fill drain issue.
Feb 12, 2014 | Moyer Diebel 24 in. 301HT-40 Built-in...
Our dishwasher idl 40 indesit has 1 and 3 flashing lights on the panel seems to be a problem
I have had this problem also and no longer take anything apart take out the filter plate pour boiling water into the well leave for 20 mins put on a 25 min fast wash and hey presto works every time. Mine seems to block up about every 4 weeks and the lights come on but this solution always works
Mar 06, 2012 | Indesit 18 in. D41 Slim-Line Free-standing...
N01 light is flashing? Not working
"First green light flashing"... that meant the float cut off switch which is right at the bottom of the machine, was being activated by a water leak filling up the bottom tray where the float switch lives. The water inlet valve was closed to prevent any more flooding, and green light No 1 shows "no water entering machine".
In some cases, the leak was due to a burst in the short black rubber hose between the main pump and the water trap under the main filter and drain assembly. Need a new hose cured the whole sorry mess. To get at the relevant bits turn machine on its side and remove the bottom tray (six screws, three each side.
Good luck.
Apr 16, 2011 | Indesit 24 in. IDL500 Built-In Dishwasher
DWF 415 Ikea Whirlpool Dishwasher has constant green blinking light. Drain pump works ok (as it will pump out a jug of water if I tip it into it!) but no water comes in. Cycle stops about 30 seconds after...
Anyone got an answer to this, as I have exactly the same fault.
Dishwasher appears to switch on OK, then after a short time (20 secs?) the pump noise stops and the green light flashes - it seems to e a sequence of 7 flashes, then stop... 7 flashed then stop.
The sequence could indicate a fault detected?
Anyone know anything about these units from IKEA, made by Whirlpool?
Thanks!
S
Feb 12, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
Not draining and check water light on
you have a blockage in drain pump consult manual for cleaning process when water drained away check water light will go out.
May 27, 2010 | Bosch 24 in. SGS43C12 Classixx...
Indesit 18 in. D41 Slim-Line Free-standing Dishwasher Logo
193 people viewed this question
Top Indesit Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Eric Taylor
Are you an Indesit Dishwasher Expert? Answer questions, earn points and help others
