Question about Dryers
Need to replace belt - Dryers
  • Anonymous May 11, 2009
    does the whole front have to come off
    Scholar:
  • 170 Answers
Remove the front panel. you may need to remove a kick panel below the front panel. the top panel connects to the front panel by some plastic push in retainers (you can loosen them with a screwdriver) You need to prop the top panel up. the belt goes over the top of the drum down to a drive wheel that is located at the bottom of the dryer.
Posted on Jul 07, 2008
Need diagram to replace belt on cub cadet mower
Hi there r photos on how to fit the belt. Type in Google. cub cadet mower photo of belt. There r also movies on YouTube how to fit belt. Type in how to change the PTO belt on ? cub cadet , good luck
Apr 20, 2016 | Cub Cadet Street Sign- tractor lawn riding...
How can you tell if a timing belt, A/T belt,P/S belt & A/C belt all need to be replaced?
The mileage is a good indication of age and need for replacement.
Mar 22, 2015 | 2011 Hyundai Accent
If I replace timing belt 97 quest van do I need to replace camshaft belt tensioner
any time a vehicle has a hydraulic tensioner it should be replaced. most parts stores have a timing belt replacement kit. some have the idler pullies and the tensioner and belt. you should replace the water pump while you are in their.
Sep 08, 2014 | Vehicle Parts & Accessories
Noisy fan belt
with a noisy belt its caused by a worn belt,belt not tight enough,a pulley in poor condition or grease/oil on the belt.check the condition of the belt,make sure the belt is tight enough.if it has an auto belt tensioner it may not be any good and need replacing.if the noisy belt doesn`t use an auto tensioner then the belt will need tightening.if its grease/oil then the belt will need to be replaced and the pulley`s cleaned off.
Jul 25, 2011 | 1998 Land Rover Discovery
My serpentine belt went how do i change the belt do i need a special tool
Identify which belts need to be replaced. If you are replacing the air conditioner belt, you may need to remove the alternator belt because of the way the belts are shared on the crankshaft pulley. As a result, some mechanics recommend replacing both belts together.
  • Step 2 Loosen the lock bolt for the belt you are replacing using owner's documentation. The lock bolt will be near the belt tensioner component.
  • Step 3 Turn the adjustment bolt to change tension on the belt. When the belt is loose enough, slip it off.
  • Step 4 Use your memory or a belt routing diagram to install the new belt on all pulleys.
  • Step 5 Adjust the adjustment bolt to replace tension on the belt. Tighten the lock bolt.
  • Step 6 Make sure the belt is correctly seated on all pulleys and that the ribs fit into grooves on the pulleys.
  • Step 7 Run the engine and check for any flapping or looseness that could indicate incorrect installation.
  • This was copied from the service manual.
  • Jan 24, 2010 | 1995 Dodge Intrepid
    How often should you get engine belts replaced and what belts need to be replaced?
    Replace belts as needed, check for cracks on the sides of the belts or pieces missing from belt. A good belt should last 100,000 miles. and it is a good practice to replace at 100,000 even if it looks good. REPLACE ALL BELTS as needed.
    Jan 18, 2010 | 1996 Nissan Pickup
    Belts need replacing how do i do it?
    Pull washer out a couple of feet and tilt it back, lifting the front. Rest against the wall. The belts are on the bottom. Remove the drain pump belt, and you'll get to the drive belt. The motor is installed on a plate and held by a spring. To install the belts easier, push motor towards the transmission pulley when installing new belts. Part numbers: 211124 for the pump belt, and 211125 for the drive belt. Set of both belts: 12112425.
    The set of both belts includes an instruction sheet also.
    Coupon "New10" takes 10% off.
    Good luck
    Oct 31, 2009 | Maytag Dependable Care LAT9416
    Need to replace vacuum belt
    how do i change belt on morphy richards ultralight cyclone cleaner?
    Jan 04, 2009 | Vacuums
    Serpentine belt replacement
    2.0L Engines
    See Figures 11, 12 and 13
    The accessory drive belt for 2.0L engines has no provision for manual belt adjustment, since these engines use an automatic belt tensioner. Drive belt slack is taken up by the automatic tensioner.
    Movement of the automatic tensioner assembly during engine operation is not a sign of a malfunctioning tensioner. This movement is the tensioner self-adjusting and is required to maintain constant belt tension.
    The belt tensioner has a belt length indicator. If the indicator marks are not between the MIN and MAX marks, the belt must be replaced.
    0900c1528008d836.jpgFig. 11: Drive belt routing-2.0L SOHC engine with A/C 0900c1528008d837.jpgFig. 12: Drive belt routing-2.0L SOHC engine without A/C 0900c1528008d838.jpgFig. 13: Drive belt routing-2.0L DOHC engine
    Jul 24, 2008 | 1999 Ford Escort
    Dryers Logo
    286 people viewed this question
    Top Dryers Experts
