Question about KitchenAid 24 in. KUDS02FRSS Stainless Steel Built-in Dishwasher
KitchenAid Dishwasher KUDSO2FRSS
The gadget in my dishwasher door that keeps it from falling open very heavily seems to be broken. Now my door just slams open unless I help it down gently and I have to always lock the dishwasher door, otherwise it falls open again. Is there anything I can do to fix this myself or do I need to call a repairperson? Thanks so much. Joan J.
  • chan47 Jan 31, 2009
    Same thing - upon opening the heavy door, it slams down hard.
  • Anonymous Mar 29, 2014
    Our Smeg dishwasher door won't open. The handle has broken and it won't open. Please help. I have the relevant spares and need to replace them?
I recently had the same problem. One of the cords that attaches the door to a spring had snapped. I purchased cord replacments at the following URL and completed the repair myself. http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=1059756&PPStack=1
Good Luck, Tim K.
Posted on Jul 07, 2008
Falls open when? This unit wom't operate unless the door is secure so I assume you mean the door assist springs are disconnected or broken and the door just falls heavily to the open position after you unlatch it from the closed position. Try these, part 18 here
http://www.searspartsdirect.com/partsdirect/part-model/Kitchenaid-Parts/Dishwasher-Parts/Model-KUDI01FLSS3/0593/0130000/W0503111/00007
should attach to frame in an easy to distinguish hole or slot and to door hinges, number 2 here
http://c.searspartsdirect.com/lis_png/PLDM/W0503111-00001.png
Aug 27, 2012 | KitchenAid 24 in. KUDI01FLSS Stainless...
Something has happened to the door of my dishwasher when you open it it falls down heavily and now when I put the dishwasher on the door keeps opening
The door springs or ropes have broken...
That is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Mar 16, 2011 | Dishwashers
The door spring is broken and the door falls open
there is springs on left and right side held by string and spring. one is broken.letme know how it turned out.
Feb 26, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
Kitchenaid dishwasher KUDR24SE...cannot open door
did anyone have a solution? i have the same problem.
May 16, 2009 | KitchenAid KUDR24SE Built-in Dishwasher
Dishwasher door won't open, latch seems broken
Hello, I read your comment. If the latch is broken, then I suggest first of all disconect the electricity from the dishwasher. You may want to try using a small screwdriver and insert it where the latch is to activate the opening mechanism. If it doesnt open, then there are two options, I suggest to call the technical service to replace the door with a new latch.
Hope I have been of help.
Regards Nevd ´ll fixya.
Feb 15, 2009 | KitchenAid KUDR25 Dishwasher
Where can I buy the cable repair kit for my Kitchenaid dishwasher
OK, pretty easy fix. Look at diagram 10 here: http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5164885
The link (#24) probably broke and the spring (#18) probably shot off and is lying somewhere behind the dishwasher. Just pull out the dishwasher (careful not to disconnect or crimp any of the hoses) and check to see if both springs (one on each side) can be located. Just replace the old links and re-hook the springs and all should be well.
You can order the link replacement (part #8194001) from kitchenaid at 1-800-422-1230.
Jan 19, 2009 | KitchenAid 24 in. KUDP01DLBS Free-standing...
Kitchenaid Dishwasher Latch Broken
GET A FLAT HEAD SCREWDRIVER TRY TO PUSH THE LATCH TO OPEN THE DOOR...
Nov 02, 2008 | KitchenAid KUDS24SE Built-in Dishwasher
Kitchaide Dishwash Door
There is normally 2 heavy springs & cables that control the "falling" of the door located in the bottom of the machine or it the door itself. Sounds like one (or both) have snapped.
Jul 25, 2007 | KitchenAid KUDC25CH Dishwasher
KitchenAid 24 in. KUDS02FRSS Stainless Steel Built-in Dishwasher Logo
2,072 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
