Question about Apple iPhone Smartphone
1994 saturn key jammed
1994 satyurn sc2 Key stuck in the acc. position.How can I remove the ignition cylinder while the key is in this position seeing it will not budge either way.
  • 52 Answers
What does this have o do with the Apple iPhone
Thank you,  Apple Care Tech Support
Posted on Jul 03, 2008
2006 Saturn Ion - Key gets stuck in ACC position when turning off vehicle. Was told it's possible my keys are too heavy and have damaged the ignition cylinder. At what weight (in American pounds...
They do say that just a few keys on the ring is too much weight for the ignition to support, the vibration will , over time, eat away at the inside of the cylinder and the key will fall out and wear out. You see a lot of people with 50 keys dangling out of their ignition, bad idea, as you have found out. It doesn't need to even hit 1 pound, 8 oz. is too much. Get an 8 oz. piece of steel and put it in your pocket and see how long you can go with it, not long. Hope this helps.
Jun 29, 2011 | Saturn Ion Cars & Trucks
1994 z71 truck key stuck in acc position will not turn to be removed can turn key to start, truck runs ok remove ignition fuse to turn off is the key lock Solenoid on the coloum the issue
The ignition lock cylinder is worn out. after so much use, the brass key and tublers inside the lock wears due to filings that build up inside of the lock. When too much filings builds up, it makes the tumbler pins hang up inside. the upper portion needs to be disassembled to replace the lock cylinder. And of course, you will have a different key overall for your new ignition lock Good luck..
Feb 10, 2011 | Chevrolet 1500 Cars & Trucks
Key locks in the ignition in the ACC position. can't take key out
when you turn key to acc pos that is telling the ignition to go into a accessory mode which runs the radio,wipers etc... but it doesnt allow the ignition circuit to run, and the key in most vehicles will not be able to come out,this is a security protection so that you do not leave accessories on that will drain the battery. The ignition key should only be able to be removed in the OFF position.
Jan 21, 2011 | 2001 Saturn L-Series
I just got a 1994 saturn sl2 and when i try to pull the key out of the ignition, the key gets jammed and i have to shake it hard to get it out. is this common with other saturns?
lock cylinder come apart on inside(tumblers) you will need to replace lock cylinder code the ignition lock cylinder and get a new key
Aug 21, 2010 | Saturn SL2 Cars & Trucks
How do I remove the ignition lock cylinder from a 2003 Saturn Vue for rekeying?
REMOVAL
  1. Disable SIR system. (Refer to "SIR Disable/Enable Procedure (For Frontal and Curtain Inflators)".
  2. Disconnect negative battery cable.
  3. Remove lock cylinder bezel from steering column shroud by carefully prying with thin blade screwdriver.
  4. Remove shroud fasteners and remove steering column upper and lower shroud panels.
  5. Insert key into ignition lock cylinder and rotate to RUN position. Then rotate ignition cylinder back to ACC position.
  6. Depress locking button on side of ignition module assembly with a thin pick-type tool. Slide lock cylinder assembly from ignition module.
INSTALLATION
IMPORTANT: Actuator blade within ignition module housing must be in ACC position to install lock cylinder assembly. If rotated, replace it to ACC position, using needle nose pliers.
  1. Insert key into ignition lock cylinder and install into ignition module.
  2. Install steering column upper and lower shrouds and shroud fasteners.
  3. Install lock cylinder bezel.
  4. Connect negative battery cable.
  5. Enable the SIR system. (Refer to "SIR Disable/Enable Procedure (For Frontal and Curtain Inflators)".
Apr 07, 2010 | 2003 Saturn VUE
1994 Saturn SL2 Key stuck in ignition cylinder
Put some pressure on the steering wheel in one direction or the other this may take the pressure off the cylinder itself and allow you to do what is needed...hope this works.
Nov 16, 2009 | Saturn SL2 Cars & Trucks
Key stuck in ignition halfway to ACC position and will not turn
try wd40 and shaking the key, what happens is one of the tumblers get stuck and wont let the key turn if that dosnt work let me know worst case you will have to replace the ignition its about $35 to $40 and a few hours.
May 31, 2009 | 2003 Saturn VUE
Car was stolen broke the ignition
REMOVAL
  1. On models equipped with airbag, disarm airbag as described under MAINTENANCE PROCEDURES/AIRBAG SYSTEM DISARMING.
  2. On all models, disconnect battery ground cable.
  3. Remove ignition switch as described under STARTING AND CHARGING SYSTEMS/COMPONENT REPLACEMENT AND REPAIR PROCEDURES/IGNITION SWITCH.
  4. Remove key light case from lock body, if equipped.
  5. On 1989 Accord models, place ignition lock cylinder in the ACC position.
  6. On except 1989 Accord, place ignition lock in the I position.
  7. On all models, position suitable punch into hole on lock cylinder housing and depress pin, then remove lock cylinder from housing.
INSTALLATION
  1. On 1989 Accord models, install ignition lock cylinder as follows:
    1. Place ignition lock cylinder in the LOCK position.
    2. Rotate key until it is almost at the ACC position, then insert lock cylinder until pin contacts housing.
    3. Rotate key to ACC position, then push pin in and insert lock cylinder into housing until pin clicks into place.
  1. On except 1989 Accord, install ignition lock cylinder as follows:
    1. Place ignition lock cylinder in the O position.
    2. Rotate key until it is almost at the I position, then insert lock cylinder until pin contacts housing.
    3. Rotate key to I position, then push pin in and insert lock cylinder into housing until pin clicks into place.
  1. Install ignition switch and connect battery ground cable.
SRS wire harness is routed near the ignition switch.
CAUTION:
  • All SRS electrical wiring harnesses are covered with yellow outer insulation.
  • Before disconnecting the SRS wire harness, install the short connector on the airbag.
  • Replace the entire affected SRS harness assembly if it has an open circuit or damaged wiring.
IGNITION SWITCH
  1. Remove the steering wheel, then remove the steering column covers.
  2. Disconnect the 7-P connector from the under-dash fuse box.
  3. Insert the key and turn it to "0."
  4. Remove the 2 screws and replace the base of the switch.
Feb 13, 2009 | 1992 Honda Accord
Ignition switch won't turn on!
In the same boat and Saturn just plain sucks. Glad they are shutting their doors. You ignition lock cylinder is bad. Good thing is that its stupid simple to fix bad news is the ignition has to be the ACC position to pull it out. Another real smart move these idiots decided to do. If you have a bad ignition lock you have a 50-50 chance it will seize in the freakin lock position making it impossible to get it to the ACC position. Anyway here is the link to a utude exact video on how to pull it out in 2 minutes to replace if your lucky and can get it to the ACC position.
http://www.youtube.com/watch?v=TJ6EJhuaT5s
Jan 06, 2009 | 2001 Saturn S-Series
Key stuck and jammed in acc. mode in ignition "1994 Saturn SC2"
What does this issue have to do with the Apple iPhone.
Thank you, Apple Care Technical Support
Jun 30, 2008 | Apple iPhone Smartphone
Apple iPhone Smartphone Logo
99 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
