Question about Ruud UBHC Air Conditioner
Coleman mobile home air conditioner not working.
  1. when I turn thermostat to cool position and then lower temp control on the thermostat the motor does not turn on.I am wondering if there is a problem with thermostat, because the furnase does not work either when switched to heat.
  • 230 Answers
It sounds to me as if the problem is in the furnace itself. It is probably in a system lock out. You can reset it by turning off the furnace breaker and then turn it back on. If that does not work chances are that the circuit board is bad. This is usually caused by normal wear and tear. You should probably call a technician in at this point.
Posted on Jun 30, 2008
Coleman 8000 fan works not cooling or heating
sounds like the compressor is not running. the controller (thermostat) may be at fault, or there may be a wiring problem, either in the lower unit or probably in the upper section.
May 13, 2014 | Coleman Mach 15 Air Conditioner
Furnace in mobile home has a few problems
Sounds like fan & limit control
If temp on limit reaches max temp what happens gas valve deenergized,as MTR continues to run begins to lower temp. Thus reenergizing valve
Check filters,MTR speed for heating
Feb 03, 2014 | Coleman Heating & Cooling
One day my RV Coleman ac just quit running on low cool but every other setting works fine. Any ideas?
Is your Air Conditioner run with a wall mounted thermostat or the ceiling pack controls? If it is the ceiling pack controls, then your selector switch has gone bad and needs to be replaced. This is located in the ceiling pack itself and is relatively easy to do. You can easily test it with an Ohmmeter, going through these steps:
To check the selector switch, remove wires from the terminals
and rotate the switch to the proper position and read
continuity as follows:
Terminals Switch Position
L-1-3 Lo Heat
L-1 Lo Fan
L-2 Hi Fan
L-1-4 Lo Cool
L-2-4 Hi Cool
* If you do not wish to remove the wires from each terminal,
disconnect the 9 pin plug from the a/c unit.
Hope this helps,
Jun 27, 2009 | Coleman Mach 15 Air Conditioner
I have a 13,500 btu coleman on our 1989 avion camper. It was making a very loud noise for some time, and vibrating then the motor locked up on it. My husband thinks the blower went out on it. It was...
You should be able to turn the fan motor freely by hand. If there is any resistance or the noise turning it by hand, then the fan motor is definitely bad. Is it a wall thermostat unit or manual controls? Wall thermostat, you can use a jumper wire from the 12+ terminal of the thermostat to the HG terminal and the fan should come on, if not, then the motor is bad.
Jun 24, 2009 | Coleman Mach III Air Conditioner
Coleman mobile home furnace Model #7966-756 will not turn on. The pilot light is lit, there is power coming to the step-down transformer inside the furnace. The reset switch is in the right position. It...
I had a similier problem, Check your neutral ground? also alot of power companies will come out and do a basic check of the voltages going to the furnace, and can offer advice for free.
Sep 17, 2008 | Coleman Heating & Cooling
Ruud UBHC Air Conditioner Logo
88 people viewed this question
Top Ruud Heating & Cooling Experts
Bill Long
Tim Whalen
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
