-   I have the same problem, and this sounds like the right solution.... However, I have NO IDEA how to find this sensor flag, nor where to place the lubricant
-   trippstadt
Jun 30, 2008
-   Same problem, I cleaned the rollers and still the paper feeds skewed, we're just going to buy a new one! We have two of these and the other is still fine.-   bguyll
Normal
0
I suggest you get a sheet of Card Stock (Heavy
paper) and place it in the feed way. Then press the print
button applying a slight amount of pressure on the Card Stock so it
will feed through the printer. The reason for this is in some cases I
have been able to clear the paper track of debris that was deposited there
over time.
Worth a try, as I have fixed a number of printers this
way, saving costly repairs.
Hope this helps.Bud
the type of print head is incorrect comes up on my printer. Original print head is on printer. How...
(More)
the type of print head is incorrect comes up on my printer. Original print head is on printer. How can I fix this
My printer MP600 present three discontinuous line in mine of letter at every copy page. what...
(More)
My printer MP600 present three discontinuous line in mine of letter at every copy page. what is the problem.
When I turn on the computer the system does not startup due to a problem with the usb printer cable...
(More)
When I turn on the computer the system does not startup due to a problem with the usb printer cable connected to the computer. What should I do?
