Question about Panasonic Microwave Ovens
F82 code - Panasonic Microwave Ovens
  • 100 Answers
If it's a Panasonic commercial model (NE1757,NE2157), check the two fuses first. If one is blown, first take a look at the upper door switch to be sure it's activating. If that and the bracket look ok, you most likely have one of the following parts that need to be replaced...
Fan motor, HV Transformer, or Magnetron tube (or a combination of). Also look at the two white wires going to the middle relay on the lower relay board. If they're burned, you'll need this board and possibly one of the above parts as well.
Posted on Jun 30, 2008
We have a may tag convection oven tat is displaying error code F5E2
This is a door lock error code. The same error code is also used on top loader laundry washers.
Whirlpool Fault Codes
Oct 04, 2016 | Microwave Ovens
Mod.KHMS155LSS-1 Getting F-6 Fault code ????
Search Results
    Combination Microwave Wall Oven - Error Code/Message ...
    www.kitchenaid.com/...microwave...error-code...f6-error-cod...
    KitchenAidQuestion: Combination Microwave Wall Oven - Error Code/Message - F6 Error Code -F6 E8. Answer. Product Symptom: Combination Microwave Wall Oven ...
    Over-the-Range Microwave - Error Code - Starts with F ...
    www.kitchenaid.com/...microwave-error-code...f...f6...code/P...
    KitchenAidKitchenAid's product help articles give answers to your frequently asked questions (FAQs). ... Microwave - Error Code - Starts with F - Starts with F6 - F6E0 Code.
    Kitchen Aid Oven Model # KEMS308SSS02 error msg - Lost ...
    www.shopyourway.com > Manage My Life > Questions
    I have a Kitchen Aid Model # KEMS308SSS02 and I getting the follow error message... is working and was always working but the top microwave/oven does not work. ...Kitchen Aid Oven Model # KEMS308SSS02 error msg - Lost Err/ F6 E0/ ... Most "F6/E0" fault codes is usually because of a loose wire connections, loss of ...
Feb 05, 2016 | KitchenAid Microwave Ovens
Error Code F9.Q (Touch Communication).
KitchenAid Appliance Fault Codes - PartSelect
www.partselect.com/JustForFun/Kitchen-Aid-Appliance-Fault-Codes.aspx
Fault codes for a number of KitchenAid appliances, including two and four digit codesfor ... F9 - Oven Door Lock Failure - Check door lock switches and wiring.
Jul 27, 2015 | KitchenAid KHMS2050SSS Microwave Oven
Code f 82
F81, F82, F83 and F84 all mean that there's no voltage supply to the oven.
Apr 25, 2013 | Panasonic Microwave Ovens
When turned off after cooling for 5hr. The outside unit buzzers as if a motor is running. it has gone on for 3hr. if I turn the unit back on it works OK just the outside unit seems to keep going.the out...
Do you mean after cooking for 5 hours? If so, yes. This is normal behavior. The microwave is running an internal fan to cool the components inside of the microwave. The fact that it has done so for 3 hours is a bit strange, but I doubt there is any issue with the inverter. Watch for errors. Error F33 or F34 mean an excessive heat build up in the microwave. Errors F81, F82, F83 and F84 mean that there is an issue with power delivery, such as inverter failure. While F86, F87, F88 and F89 represent shorted contacts within the microwave's boards and power supply.
Hope this helps,
~KenjiFox
Jan 07, 2011 | Panasonic F606Y6G00CP F606Y6G00CP Inverter
My kitchenaide convection oven is displaying the E1 F4 error.
KitchenAid ovens are popular for their classic design and simple user interface. When a problem occurs in the function of a KitchenAid oven, an error code will display on the clock as soon as the malfunction registers in the oven's memory. Each code corresponds to a particular type of malfunction. Most can be corrected by disconnecting the power supply for one minute and then restarting. If the code persists, either replace the indicated part or contact a service center. F0/F1
  • The F0 and F1 codes refer to electrical issues. If the code appears as only two digits, the problem is a transistor failure, so you must replace the electronic range control (ERC). If the code displays four digits, it will read F0-E0, which indicates a failure switching from analog to digital, or F1-E1, which refers to a safety flip-flop. Both problems require the replacement of the ERC.
  • F2/F3/F4
  • The F2, F3 and F4 codes refer to problems with the oven temperature sensor or the keypad. If you see the two-digit F2 code, it means your keypad has shorted and the ERC must be replaced. The four-digit F2-E0 code means that the oven temperature is too high. Test the door lock and the relay operation, and correct as necessary. A two-digit F3 code means an open temperature sensor or thermal fuse, so those parts must be replaced. A four-digit F3-E0, F3-E1, F3-E2 or F3-E3 code or a two-digit F4 code means that either the oven is registering as too hot or the temperature sensor has shorted. Either way, the oven temperature sensor must be replaced.
  • Nov 22, 2010 | Microwave Ovens
    My phone block ask puk code
    PUK code and PIN Code:
    Please dont try more than 3 times.If you try more than 3 times the Sim will get locked.And it will ask for PIN code.Both these PUK and PIN code can be given only by the network service provider. Please call the network service provider of your mobile.And ask him to provide the PUK code or PIN code.He will ask you some basic details like name,date of birth for his verification.And he will provide you the PUK and PIN code.This is done for free of cost.
    Please do rate the solution if the issue is resolved or post a comment for further assistance.
    Thank you for using fixya have a nice day:-)
    Nov 07, 2010 | Samsung MT1066SS Convection/Microwave Oven
    What does F-82 mean?. it is flashing on the display and the Microwave is not working. Thanks
    F82 means there is no power being supplied to the lower high voltage transformer. It may be due to:
    - failure of relay RY-4 on the circuit board
    - 10A fuse open
    - controller failure
    We have the service manual and have uploaded it to our site here to help you.
    You can order parts from Encompass here or you can call them toll-free at 866-779-5835.
    Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more free information & help.
    William E. Miller, AS-EET
    prototech@usa.net
    http://www.microwavedisplay.com
    Microwave Oven Control Panel Repair Nationwide
    Jun 17, 2010 | Panasonic Pro NE1757 Microwave Oven
    Code
    i looked in an online manual and it said it is a child protection code but i cannot get it off. Anytime i put in instruction, example pop corn, when i press enter i see the word code at the top of the screen,but i dont know how to get it off.
    Aug 28, 2008 | Danby DMW1153 Microwave Oven
    Microwave Ovens Logo
    769 people viewed this question
    Top Panasonic Microwave Ovens Experts
    William Miller
    William Miller
    Devabhakthuni...
    Devabhakthuni...
    Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
