Question about Panasonic Home Theater System System
SC-PT750 Wireless speaker don't work - receiver powers up but won't receive signals from transmitter on a ebay Panasonic SC-PT750 System I bought - but noticed that the receiver has a different id # than the transmitter. I was told there was a reset button on the back of the receiver unit but I couldn't get it to make any difference...also I can't seem to find any help at Panasonic.com/support to answer any of my questions....said they would answer by email within 48 hours - never happened. Also tried to find out if a transmitter can be purchased separately to match with the receiver...no reply or answers there either. Any help out there?
  • 3 more comments
  • duy817 Aug 01, 2008
    mine was green but no sound.. what's going on? i'm a different user from the person who started this post btw. thanks. I have a SA-PT750
  • Anonymous Aug 11, 2008
    They just wont seem to sinc.
  • badazdad Jan 10, 2009
    Panasonic sc-pt 750 can you interchange the tx card and wireless receiver. other words can you buy a wireless rear amp that did not come with the receiver and card? Thanks
  • bigbrad123 Feb 02, 2009
    I have the same problem. My light on my wireless unit is red. I have gone through the manuel, removed all wireless things from around the unit, unplugged the wireless card two or three times, etc. The "W1" is flashing on the main player. I have done everything I can think of to get it working and it won't. Any other ideas?
  • WarioHussein May 11, 2010
    Is the light on the receiver green or red? If it is green then they are working, and I can tell you why you aren't hearing it. If it is red, then tell me everything written on the wireless transmitter and the wireless receiver and I may be able to give you a work around.
Hi...I found your post while searching for the answer to the same question!  I thought I'd let you know what the tech support person told me, which worked immediately.  There is a button on your remote that says MUSIC with SRD above it.  Push this button, while surround sound speakers are on, and they should work instantly.  They are quieter than the regular speakers, so you might have to turn up the sound.  Hope this works for you (if you are still having troubles, that is).  The manual was no help with this subject.  So frustrating!
Posted on Sep 07, 2008
PT750 5 disc player is frozen reset to default?
There not like a computer, Or after market car deck. There is no reset on them.
Sep 04, 2014 | Panasonic Sa-pt750 5.1 Channel Home...
Scpt950k wireless speakers don't work
there may be some loose connections or connections may get lost inside the speakers or it may blown due to high voltage so check that
Jun 30, 2008 | Panasonic Home Theater System System
Weak Signal
You can buy antenna's that will extend the range of your wifi signal. Go to www.ebay.com Type: wifi extender, wifi antenna, and wifi range one of these should give you what you need.
Apr 23, 2012 | Panasonic SH-FX50
My parents are getting rid of their Panasonic SC-HT700. The receiver is shot. The speakers and sub work perfectly fine. I was wondering if I could purchase a used receiver (found the SC-HT930 on ebay) to...
the speakers are 6 ohms, and it will be very difficult to find a receiver that is 6 ohm compatible. most home amps are 8 ohm, and will overheat and burn up when used with 6 ohm speakers.
the subowoofer is 4 ohms, but i am unsure as to whether it is self-powered, or if it is powered by the receiver.
4 ohms is the standard for car audio, and 8 ohms for home audio.
Oct 27, 2010 | Panasonic sa-ht930 Home Theater Audio...
Just purchased SBHS100AE-K rear speakers to connect to my SC-BT100. I want to connect them wired rather than purchase the wireless transmitter, but I can't figure out how to connect the wired rear speakers...
This unit is not as flexible as traditional receivers are as far as speakers are concerned. Speakers are labeled and *must* be connected to the correct speaker terminals.
Upon reading the manual - it is quite apparent that the only provisions for rear surround speaker connections is <i>only</i> via the optional wireless transmitter / receiver hardware. The optional digital transmitter is connected via a proprietary plug on the rear of the SC-BT100. The optional receiver amplifies the received signal and passes it to the connected surround speakers. I would bet that there are no provisions for amplifying a surround L and R speaker channel inside the SC-BT100, and that it only provides a low level (like a "tape out") or un-amplified signal to the transmitter plug. Even if you were to manage to get the surround speaker connections made up there - you would not be able to hear anything from them - as there is no amplifier. The amplifier is contained in the wireless receiver, and is largely why it requires a connection to house current.
Unfortunately, I doubt you'll find a way to listen the surround channel audio from the SC-BT100 without the optional transmitter / receiver and the integrated amplifier.
You can review the manual like I did here:
http://service.us.panasonic.com/OPERMANPDF/SCBT100.PDF
I hope this answered your question.
Jun 11, 2010 | Panasonic SC-BT100 Theater System
How to make my rear speakers wireless wat do i need
If you are considering using bluetooth for this, you will need a transmitter and receiver for each speaker pair. Each speaker pair will need to be driven by an amplifyer which interprets the bluetooth signal and drives the speakers. So for a 5.1 sysem, you will require 3 amps, 3 transmitters and 3 receivers. Also the power packs for charging the transmitters & receivers. Jabra make a very nice transmitter which I use, Its an AS 120S;. The 'S' is for stereo. For receivers I use a simple cheap unit I got off eBay. Item number 320519321206, which is a better unit than the Jabra. You have to have all signal through bluetooth (or none) because of the few milliseconds delay this technology produces.
Apr 18, 2010 | Samsung Audio Players & Recorders
Wireless digital transmitter doesn't work
I'm having this same problem; it worked all ok in the beginning then one day it didn't and no matter what I try it doesn't seem to connect. Similarly im getting the W1 flashing and even when I take the receiver and move it closer (even within a few feet) it still wont pick it up. I've removed the wireless home phone and baby monitor from within the room without any result. I cannot think of anything else that could be interfering. Any advice or resolution would be much appreciated.
Oct 06, 2009 | Panasonic Audio Players & Recorders
Connecting rear Wireless Speakers on Panasonic Home Theatre Kit
Hi
Just push and hold the fast forward button on your receiver and push the button number 3 on your remote simultanously
your unit cames in pairing mode a P appear in the display
after, goes to your wireless receiver and push the reset button on the back
normally after that the unit must connect with your receiver
Dec 29, 2008 | Televison & Video
Sc-pt750
As far as I know there isn't any composite IN ports on the back of the SC-pt750 so that would mean you would have to directly hook it up to the TV. I have an SA-pt750, which has an S/PDIF port on the receiver so I would run a cable from the TV to the receiver, from there if the SC-pt750 is set to AUX then it should output the sound from the TV to the speakers. Hope that helps, if you don't have that S/PDIF port I think you might be out of luck!!
Nov 12, 2007 | Panasonic Home Theater System System
Panasonic Home Theater System System Logo
540 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
