Question about Kenwood KDC-X590 CD Player
Display on Kenwood Out
What a wonderful thing to see posted, when I saw your solution. I have opened my headunit in the past suspecting the problem was internal. Do you know if the KDC-MP532U is basically the same in regards to the bad solder joints?
  • Scott Chew Jul 01, 2008
    Dave
    Yes I am sorry about the vague reference, seems I get confused navigating the FIX-YA site, but yes it was in regards to the Kenwood displays going dark. I was also wrong about the model I have which is the KDC-MP632U and not the 532U, but the resistors were in fact where you said they were.
    Funny that when I was fixing mine and my wife's identical head unit that there was one resistor that had one side loose. When I touched the hot iron to one side the resistor moved meaning the opposite side was loose. They both had this exact problem.
    In Kenwood's defense they offered to fix both out of warranty, but driving around without a radio for even a week would lead to insanity. It took a while, but finally you offeren a solution to this problem. I guess mine failed early, middle of last summer and my wife's about 3 months ago, which meant I had to wait for other owners to experience the same display problem and start posting.
    Thanks again. I really get a lot of satisfaction when I can fix something myself with a little direction from someone like yourself. I fixed them both yesterday, but I was still smiling when I turned the key this morning and watched the display scroll on.
    Scott
    President:
  • 624 Answers
I am not sure exactly what solution you are reffering to, but the KDC-MP532U has a problem with the display going out that is the result of heat stressed solder on the main board. The surface mount resistors that are located on the right side near the front of the unit, as you look into it with the display facing you, are the culprits. This is common in about 3 or 4 Kenwood models. These surface mount resistors are on the top of the board, so the board doesn't need to be taken out to fix it. Just the CD mech does. The surface mount resistors just need the solder reflowed, an easy enough job if you know how to solder. They are all lined up connected to each other, I don't remember the reference numbers, but if you can recognize what a surface mount resistor looks like, you should be able to find them very easy.
Thanks for the compliment on the other post, it is appreciated. A good rating would also be appreciated.
Thanks and good luck,
Dave
Posted on Jun 30, 2008
  • Dave DeGain
    Dave DeGain Jul 01, 2008
    Hi Scott,
    That's great, even I get satisfaction when I can help somebody else. It's the only reason for me to be on this site. You would have gotten that answer much sooner had I known this site was here. I just started here less than 2 weeks ago.
    By the way, the resistor that moved when you touched it with the hot iron, actually was connected on both sides. The heat from the side you touched transfered to the other side and melted that solder also. It happens to me on occasion as well. It is something that you must be careful about when soldering. Too much heat can damage a component if the iron is left the lead too long. The surface mount resistors are not as prone to this type of damage, but IC's are, so if you solder them, only use the amount of heat needed to melt the solder and don't leave the iron on it any longer than needed to get the job done.
    Congrats on fixing this yourself, you are one step ahead of most people. Soldering may seem very easy to you, but you would be surprised at how many technicians I run into that have really bad soldering skills. Having the right "touch" really helps!!!
    I am happy to help, so if you ever need me you know where to find me.
    Thanks for the "FixYa" rating, it was appreciated.
    Dave
Thanks tech48! I had the same problem, fixed it today on my kdc-mp532u. As you described, I just had to resolder the five resistors on the front right of the headunit (not the faceplate/display part). There are five surface-mount resistors connected in series, each resistor 2.7kOhms in value. You can use an ohmeter in the two vias that the resistor-network is connected to, and make sure it adds up to about 14kOhms.
Posted on Jun 04, 2009
BLAUPUNKT radio mute and volume haywire
yea the got a short somewhere. Horn fuse might or might not work something with the radio. I would say start with the horn. The horn is a controlled short sometimes shorts it self out. Open your steering wheel and work from there. For your radio look at all the fuses that you know work the radio and go from there. What kinda car is it year things like that would help because if it older wires, fuses, fusible links things like that go bad over the years. Especially if you run a lot of power through the wires that was made for that kinda power like upgraded speakers, headunit (radio) amps things like that. Older cars and trucks are make with cheap radio wires. hope this helps
Mar 14, 2014 | Kenwood 2005 KDC-MP5028 CD/MP3...
Can not fine the parking brake wire on the vir6500 midstream syst
Hello robert!
Some headunits (kenwood for example) you can simply just ground the green wire and all is well. Some other headunits (clarion for example) have to see a change in the status of the wire and need to be on a switch to work. A simple toggle will work. You need to go from open to closed (to ground) on the switch for this to work.
There is usually a green wire on the deck. And you usually have to ground that green wire, and usually have to use a switch due to everytime you turn the car off the units brake switch thing has to be reset. regards
Feb 20, 2011 | Soundstream VIR6500 Car DVD Player
How do I set the time on my Kenwood KDC-MP238 cd player
You will find the manual to your Kenwood KDC-MP238 at this link. The clock settings are found on page 10/11. However for a quick try on your own. Put the headunit on STANDBY then press B. Boost button for 1 second, that will take you into the menu. Select CLK ADJ, press the Control button on the right hand side of the headunit for 1 second. The clock display should start blinking. Now use: Control button up/down changes the hours. Control button left/right changes the minutes. When you set the time, press B.Boost button to exit.
http://www.kenwoodusa.com/Support/Car_Entertainment_Owners_Manuals/ select model from drop down list.
Good Luck
dreamsystems
Feb 06, 2011 | Kenwood KDC-MP238 CD Player
I have a kenwood gourmet fp505 - how do I use the whisk attachments? Also where can I get a manual for this product?
I was wondering too how to assemble the Whisk, saw your post, searched again for the manual and happily found it buried in a drawer! Here is a copy of section on the Whisk attachment.
Nov 18, 2010 | Kenwood Food Processors
When i power up my kenwood ka 893 amp/reciver it does nothing i have replaced all 3 fuses but it does flash bars on the panel
Can you elaborate on this, "I'm wondering if it has to do with a speaker not being in correct post./negitave place"? --- What did you see or do that makes you wonder?
You didn't answer if the fuses were blown or if you just changed them for lack of anything better to try, like checking the manual, which says to suspect shorted speaker wires if "- - - - - - -" is blinking on the display.
Disconnect the speaker wires and see if that helps the receiver boot up, then diagnose the short.
If it doesn't come back to life I'd suspect it got fried by a power surge or static. I hope not.
Apr 01, 2010 | Audio Players & Recorders
Which wire is my amp power wire on a kenwood kdc-x617
hey mate,
You will need to run independent power and ground wires for the amp, then run your RCA leads from your headunit to your amp, the trigger wire to turn your amp on and off with the headunit is the pink and black wire in the kenwood wiring harness...
Hope this helps
Brad:)
Sep 22, 2009 | Kenwood KDC-X617 CD Player
Kenwood kdc-x491 wiring diagram
red, yellow, black/ign constant ground
blue, blue white stripe/rem pwr ant
grays, whites, purples, greens/ front front rear rear
its the same on all headunits except cheap *** wal mart headunits
Apr 11, 2009 | Kenwood KDC-MP438U Car CD/ MP3 Player
Replace the headunit
I have sent you the PDF that you requested.
Let me know if you need further assistance.
Jan 04, 2009 | 1998 Toyota Corolla
Kenwood KDC-W6527 audio trubles
check all the wire connections in the back, you have a short somewhere
Nov 14, 2007 | Kenwood KDC-MP528 CD Player
Kenwood KDC-X590 CD Player Logo
468 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
