Question about Canon SPEEDLITE 580EX TTL Flash
Canon speed lite 580ex 11
When I turn the flash I get no green or red light, but all the function work on the panel but it won't flash. any one got the anwser?
  • mexner Aug 09, 2008
    I have the 580 ex II for about 2 months now an I have the same problem. Panel works but no flash.....
  • fredobas Oct 06, 2008
    No red or green led but all function seems to work. No flashing.
I just got the 580 and had trouble with it blinking all the time, the bounce card was out about a mm and I did not realize it, once that was pushed all the way back--voila.
Posted on Apr 24, 2009
I had a similar problem and was about to return it. Then i found out that the camera was set to MASTER. once i disabled this feature, the pilot light came and the flash ... flashes.
To enable/disable master settings, you press and hold the ZOOM button for two seconds and the menu settings will appear.
Another method to "reset" you master/slave settings is to open your battery door while the flash is on. Not sure if this is a good way to approach it. but it was HOW i figure it out
Now i have another problem. I WANT to use this 580 ex II as a master to another 550 ex flash. And of course, the 580 II will not fire.
Help
Posted on Dec 13, 2008
Canon Speedlite 580ex ii - won't work with camera
Caroline, you should try to set the camera on "M" and the flash in 2nd curtain flash sync.
Or set flash in ATG wireless IR ETTL Slave modes and pop-up the flash on Canon EOS-70D.
Truly,
atdlee@netzero.com
Feb 08, 2014 | Canon SPEEDLITE 580EX TTL Flash
Canon 580EX II Flash is not firing??
It could be the bad bulb. You need to replace the entire bulb assembly. Canon Speedlite 580EX II MYK Camera Camcorder Repair
Apr 22, 2017 | Canon Cameras
I have a canon 40d and a canon 580 ex, i need to set up the 2nd curtain sync, how do i do it ? respond here or email to mqlimax@gmail.com
There is a button with three arrows pointing to the right on your 580EX. Press this until the 3 arrows appear on your flash LCD. That is second curtain sync. The other function of that button is for High Speed Sync
Jan 08, 2011 | Canon SPEEDLITE 580EX TTL Flash
I bought a brand new 580 ex 11 flash unit. When I turn it on it makes a grinding type of noise and then the zoom in the upper right coner continues to flash. I can't test fire it but the pilot light is...
The grinding noise is the zoom head trying to match the focal length of your lens. A brand new one should NOT grind. It should be silent. It sounds like you got the one that fell off the pallet during shipping. Exchange it for another one.
Oct 28, 2009 | Canon Speedlite 580EX II TTL Flash
Af assist on canon flash 580exii not working
check Custom Functions of Camera and Flash it can be turned off in both locations
Jun 13, 2009 | Canon Speedlite 580EX II TTL Flash
Canon ex580 speed lite
No.
One is IR(infrared) sensor. If this one comes on, you can not see it. It's invisible to the naked eyes. Only animals, snakes and IR cameras can see it.
The red light that you see when pressing lightly on the shutter button is the AF assist light, not a sensor.
You can see that by looking at a mirror.
atdlee@netzero.com
Jul 06, 2008 | Canon SPEEDLITE 580EX TTL Flash
No Green Light and no flash
I got the same problem, I haven't find the solution. Did you?
Dec 27, 2007 | Canon SPEEDLITE 580EX TTL Flash
Canon SPEEDLITE 580EX TTL Flash Problem: Flash will not stay in ETTL mode
u can use the H sync button only with the camera set in semiautomatic or manual modes, it dosent work in AUTOmatic modes
Oct 23, 2007 | Canon SPEEDLITE 580EX TTL Flash
BLURRED PICTURE WHEN USING MOUNTED FLASH.
If you are not using canon lenses then the low light focusing aid will not work correctly. Go into the menu and turn of the flash infra red light
Jun 10, 2007 | Canon SPEEDLITE 580EX TTL Flash
Canon SPEEDLITE 580EX TTL Flash Logo
3,208 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
