Question about Cameras
Focusing problems,can't get my Fugi A 350 to have a steady green light when focusing to take a pic', so comes out of focus
I used an air line to blast any grit or dust that was stopping the lens from openening properly. First i blasted the camera allover when it was shut down then I zoomed it open and gave the camera a good blast allover, and Bob's your uncle the front of the caerea lens opened properly the focus worked fine and I can now take photo's again as normal! Peter Wilmot.
Posted on Jul 24, 2008
Why won't my fugi finepix s4500 won't focus sharply ?
No good working auto focus can have many causes.
Like the camera is in Macro mode, or manual focus. The best thing to try, is to switch your camera to the auto mode. The camera logo on your mode dial. And then shoot some pictures. There should be enough light and contrast in the frame, on the place you want the camera to focus on. Sometimes you have to chose an object, with enough details and contrast, on the same distance as the object you want to take a picture of. Then press the shutter half way, till the camera is in focus. the indicator lamp next to the mode dial glows green. Then frame the picture like you want it taken end only than press the shutter completely.
If the camera does focus correct in the auto mode, then you can check, why it did not focus before.
Check page 19 of the manual, to see how to use the shutter release button, for correct focus.
Apr 23, 2014 | Fuji Finepix S1500 10.0 Megapixel 12x...
I think that it is the green because i did what you said and it is still there. there is a feature on my tv called magic focus it brings up the colors and the blue and the red are very focused but the...
This tv is a DLP projection tv right?Magic focus button push don't solved the focus picture problems,have colors shadows or 3D pictures problems?The tv have a problems known as a convergence problems,it dead.The tv convergence board.Must have it 2 STK convergence ICS and some or all it resistors to be replaced to solved the tv picture convergence problems.The shop,will cost u $300-$350 for parts and labors.
Oct 02, 2010 | Televison & Video
blurry, out of focus,image fomation,problem of the focusing unit of the lens unit ,while taking a snap,half click the camera button,till u get foucus indicator blinking GREEN light,then click,if not service the lens unit/replace the unit.
Mar 06, 2010 | Canon PowerShot SD550 / IXUS 750 Digital...
Nikon D40 vertical focus problem
Make sure the camera is using the appropriate focus sensor.
Does the problem occur when you focus manually?
Are you handholding the camera? Many people don't hold the camera as steady when holding it vertically. Try putting the camera on a tripod or other steady surface and see what happens.
Jun 11, 2009 | Nikon D40x Digital Camera
I try to turn on camera and first I get green light then red blin
i try to turn the camera...but it seems that hangup,,,,the lights green it blinks blinks,,,,and theres a circle on scren.....i have lotsof pic there that is very important for school...was it gone?waht can i do so that my pic wont lost?pls help..
Apr 10, 2009 | Cameras
2005 Ford Focus - Emmission light on steady
I may want to get an OBD-2 code reader it does run scans on the emission sensors( fumes capture, evap, ehxaust recirculation....). there are too many things going on at once to really pinpoint the exact problem. I tried.
Mar 29, 2009 | 2005 Ford Focus
I need advice on how to take Ice-hockey action pics...
Pictures get blurred because of several reasons:
Low shutter speed - occurs in low lightning conditions.
Auto focus not focused - occurs when pressing the shutter button all the way without waiting for the auto focus ready signal (green box)
To speed up the shutter do the following:
In Camera menu-Quality- Set ISO 100 for outdoor, ISO 400 indoor.
To avert focus problems, set camera menu-Rec- Focus-Infinity, Rec-Quick shutter-On
Hope that helps.
Dec 28, 2007 | Casio Exilim EX-S500 Digital Camera
Picture focus
Low light = long exposure times
There for hand shake - use a tripod or subject movement.
Dec 08, 2007 | Epson PhotoPC 850Z Digital Camera
What am I doing wrong?
This depends on which Autofocus system that particular model uses.  Then manual should tell what is happening there- there is usually a more comprehensive manual on the supplied CD.
Failing that speak to the user support of you particular model
Oct 25, 2007 | GE E1040 Digital Camera
Pictures have come out blurry and out of focus
The most common problems that most new users encounter are: 1. Trying to focus closer than @7 ft. when zooming at greater than 6x. The camera won't do it, and that zoom is tempting. 2. Not waiting for the lens to focus before completing the shutter press. Try holding the shutter at half-press until you see the steady green indicator, then gently press fully to take the shot while holding as steady as you can. 3. Expecting too much from OIS. If you're seeing the "jitter" icon a lot, that means that you're into the range of slower shutter speeds that OIS might not be able to compensate for.You might try switching to a higher ISO speed (or turning on more lights)-- yes there will be more noise, but it'll quicken the shutter speed, and a non-blurry pic that's noiser is better than a clean blurry one. . . and you'll learn a little about what you're camera will do under different conditions. Also, you have to really make the effort to hold the cam steady, even with OIS, especially when using slow shutter speeds.
Sep 07, 2005 | Panasonic Lumix DMC-FZ20 Digital Camera
Cameras Logo
55 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
