Whirlpool Thin Twin Heavy Duty Agitator lint coming out of slots along it
Not sure if a problem, but I noticed on the agitator that there was heavy lint type residue peeking thru the slots on the agitator. I took tweezers and tried pulling some of it out, but wasn't real successful. Is this normal, or should I try to get inside the agitator. And If I do have to get inside, how is that done.
I didn't purchase this unit - it came with the mobile home I purchased. So I have not manuals to refer to for this problem.
Thank you for your help
Carolyn Adamson
  • carosue11 Jun 30, 2008
    You asked for the model # - LTE5243D02. I also wrote down the serial #MK3321090. These are the only numbers I have found.
    Hope this helps.
    Carolyn Adamson
  • carosue11 Jul 12, 2008
    I will try this solution. If I have further difficulties, I will contact you.
    Thanks
  • 2,427 Answers
In the machine there should be a lint grabber or filter, Ensure its clean and propperly sealed,
From the best of my knowledge from not being present there to experience the problem it seems as if lint is folding on the agitator, the is a problem with the filter if it has one
Posted on Jul 12, 2008
  • 4,472 Answers
Remove the agitator then you should be able to clean it all out.
Hope this helps.
Thanks,
Lee
  • Lee A.
    Lee A. Jul 12, 2008
    Your welcome and please do. If you have any trouble you can also use the ask me feature. My profile page is www.fixya.com/users/leethedeuce
    Good luck,
    Lee
    Guru:
  • 1,894 Answers
Can you please first mention your model number and make>?
Posted on Jun 30, 2008
  • dewan nafees ahmed Jul 12, 2008
    thanks for the model number.
Whirlpool washer. the agitator just stopped in mid wash. there was heavy towels. . could the heavy towels have caused the agitator to stop.? does the agitator come off.?
the agitator cam be removed but that will not be the problem
if it has a belt drive , probably the belt broke or the agitator solenoid /engagement lever has broken
you will need the model and serial number when you call the technician for a proper diagnosis
May 14, 2017 | Whirlpool Washing Machines
I have kenmore 80 series heavy duty/ super capacity plus washer that after it fills with water,hot or cold and it starts the wash cycle, I noticed that the agitator only moves once in awhile and stops
hum either a bad timer sticking the point contacts close. have u tried this in all cycles? and possibly a motor with bad windings not enough power to run agitation? try running in mild or gentle and see what happens? I was tempted to say the cam dogs in agitator but they dont work then stop then work, when they go out they go out.
Feb 17, 2015 | Kenmore Washing Machines
I have a whirlpool super heavy duty capacity plus top load washer and during the cycle the spindle does not move.. What part would I need to fix it and how would I go about fixing it??
I suspect the agitator dogs are worn out. Remove the cap or sfotener dispenser, remove the plastic cap under neath and remove the 7/16" bolt. the agitator will then come out. Pull the top part of the agitator straight up with a jerking motion to separate it from the bottom. Replace agitator dogs, you will see how they go in once you get it apart. Part available HERE. They run about $5.00 or less....
Jan 13, 2011 | Washing Machines
I have a Whirlpool Heavy Duty-Super Capacity Plus, 7cycle/2 speed. Model LSR7200EQO , the agitator stopped working
My whirlpool heavy duty 2 speed 7 cycle washer machine stopped working, It fills up and aggitates for the first cycle then when it should drain and spin it doesnt drain nor spin
Jun 05, 2010 | Whirlpool LSB6200KQ Top Load Washer
Where is the filter?
To find the filter you need to do the following steps. Find your lint trap. Lint traps in washing machines can be in the agitator (the large plastic piece in the center of the tub), at the top of the washer on the rim of the tub, or attached to the washing machine's drainage hose. Pull out the agitator tube to check for the lint trap. Peel any loose lint from the filter. Scrub away lint that doesn't peel off easily with a heavy-duty paper towel or a wet sponge. Feel your way around the top rim of the washing machine's basin. If you locate a trap, pull it straight out of the machine. Peel away loose lint and follow up with a wet sponge or heavy-duty paper towel. Check your machine's drainage hose for an attached lint trap. Remove the trap and peel the top layer of lint off. Rinse the trap in low-pressure, warm water. Reattach to the drainage hose. Check for and remove any lint or debris that may have dropped into the washing machine basin during the cleaning.
Let us know if you want any further clarification.
Thanks for contacting fixya.com
Dec 06, 2009 | Hotpoint Aquarius WF210 Front Load Washer
Top half of agitator turns free (does not agitate)
You will need a set of agitator dogs. Pull off your agitator cap and look under it, you will see 4(four)small tabs that catch and release the top 1/2 of the agitator.
Good Luck!
Feb 25, 2009 | Washing Machines
Agitator
if its a 2 piece agitator.. the gears in top of agitator is stripped out.. change gears be like new....spin top countor clockwise if it dont grap.. gears bad
Sep 28, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool calypso
Have you checked the agitator? There may be sharp edges on the agitator blades. OR the towels may be getting stuck under the agitator and tub bottom. The agitator is supposed to suck the clothing down in the center and forcibly throw the clothing outwards against the tub. The cycle then repeats.
Sep 09, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
Washing Machines Logo
166 people viewed this question
Top Washing Machines Experts
