Question about Car Audio & Video
I currently have a MK4 VW golf and I cant get any reception on AM channels on my radio! When we first got the car we had no problems! Any ideas?
  • shayman Jul 01, 2008
    Thanks. No there have been no adjustments to the car at all. Also the head unit has not been replaced.
    Any other ideas?
  • 405 Answers
Good Day,
This may sound strange but has any aftermarket parts been put on the car since? If you have put on a fiberglass body kit and or fiberglass doors, this will cut down am reception. Another possibilty is if a high output ignition was installed this too would reduce reception. Was the head unit replaced?
Let me know what has or hasn't been done to the car since you bought it and we can run down the possibility.
Good Luck
Hope this helps
Posted on Jun 30, 2008
VW GOLF MK4 1999 WHERE DO YOU PUT TRANSMISSION FLUID
you need a special tool or take the car to a shop
Sep 07, 2014 | 1999 Volkswagen Golf
Cant get weather on my motorola MH370CR
Setting the Weather Channel
Your should radio receives weather frequencies if you are close enough to a reporting station:
1. After turning weather reception on, press . The current
Turning Weather Channel Reception On and Off
1. To turn weather reception on, press and hold + (plus) for three
seconds.
2. To turn off, press + or turn the radio off and then back on.
Your radio receives weather frequencies:
1. After turning weather reception on, press MENU . The current
channel flashes.
2. Press + or - to select the appropriate channel with good
reception in your area.
3. Press PTT to save the weather channel setting.
Here's a link to the MH user guide.
Best regards.
http://www.motorolasolutions.com/web/Business/Products/ConsumerTwo-WayRadios/Talkabout-MH230R-Two-Way-Radio/_Documents/MH230.pdf
Feb 02, 2014 | Motorola Radio Communications
My radio and cd player was operating good and my power lock doors now all of a sudden they both stop working a the same time
the same problem also happens on the vw golf mostly the older mk4,where the wiring loom ,ie,the main wires coming from the power,battery get cut on the metal body and causes a short/blown fuse find the mains channel ,ie,the main route of the cables and you will find the fault.adrian,,,
Sep 03, 2011 | 2001 Ford Focus
Why wont my mk4 vw golf go into 3rd 4th and 5th gear, but will go into 1st 2nd and reverse?
hiya all can any1 help ive had a new master cylinder and slave because the car would not go into gear. problem not solved. took the clutch apart foubd out that the pressure plate is pused out with a long steel rod and it pushed out the nipple part in the middle of it. same happend with the new 1 it was only in there for 3 weeks what would cause that to happen again carnt figure it out any ideas guys vw golf t reg mk4 sdi 1.9
Jan 23, 2011 | 2001 Volkswagen Golf
What oil should i put in my auto gearbox from a mk4 golf?
The users manual will tell you in the back bro, a good idea is to get it from a VW dealer as on some times using their specific oil is best.
Apr 05, 2010 | 2000 Volkswagen Golf
New code for vw gamma radio vwz1z3w7948647
Sorry...Main VW Dealer or a Radio Decoding Service only for this code
Jan 21, 2010 | 2001 Volkswagen Golf
Mk4 golf 1.6 16v misfire
i had that with my mk3 golf..and i done everything i could then finally i changed the ecu relay fuse. that solved it completely. they are cheap to buy from vw..like £15ish. hope this helps
May 04, 2009 | 2001 Volkswagen Golf
Mk4 Golf radio wont come on after repair work.
check your manual if you dont have it call vw make sure you have the vin number there or they might make you bring it there for a charge
Nov 21, 2008 | 2003 Volkswagen Golf
Vw golf mk4 2.0
If the check engine light is on look at the faults. It could be a defective cam sensor, the timing belt might not be in the place, or a defective mass air flow sensor.
Aug 31, 2008 | 2000 Volkswagen Beetle
Original CD Player in Mk4 Golf Tdi 1999-2000
DID YOU SOLVE THIS PROBLEM IF SO WHERE DID YOU GET THE MAGAZINE FROM I HAVE SAME PROBLEM
Jul 31, 2008 | Car Audio & Video
Car Audio & Video Logo
104 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
