Question about Dryers
I need a dimensional drawing showing the back of a Whirlpool WED5790SQ dryer, specifically location of dryer vent.
  • 5,911 Answers
Go to searspartsdirect.com and type in your model number. There are dimensional drawings on the next page under three different headings. I believe the drawing you may need is located under the "Bulkhead Parts" section. I f you require further assistance please let me know. I hope this helps you.
Posted on Jun 30, 2008
What are the examples of line,plane,point
Well I'm not sure why you are asking but these are general terms. These terms are used in geometry.
When printers are printer graphics they are using so called primitives to print graphic objects. The best example that comes to mind is when you use CAD software to print drawings. This is a very involved subject. One could quite easily devote a large book to discussing it.
As to the specifics of the objects line, plane and point. Well you know what a point is correct?
A point is a one dimensional geometric object. If you simply place the tip of a ballpoint pen on a piece of paper and create a dot, that is a point.
You know what a line is correct? A line is a two dimensional geometric object. If you place a straight object on a piece of paper, like say a book. And draw with your ball point pen along it's edge you create a line.
A plane may not be as obvious. A plane is a three dimensional geometric object. Imagine a piece of cardboard floating in the air in front of you. This is a plane.
A plane represented on a two dimensional object, like a plane drawn on a piece of paper (two dimensional) creates either a rectangle or a parallelogram.
If this does not answer your question you will have to be more specific.
Jun 12, 2011 | Office Equipment & Supplies
I need to trouble shoot why my whirlpool dryer will not start. I am getting power to dryer and I lifted the top and the belt is in tact and the drum turns freely. I do not want to take the motor out...
Part number 3392519. Thermal fuse.
Located on the exhaust vent.
Unplug the dryer,remove the back panel.
The fuse is to the left of the main exhaust vent.
About 1 and 1/2 inches long by 1/2 inch wide and white in color.
Aug 08, 2010 | Whirlpool LER4634J Electric Dryer
Dryer does not get hot
Start with the thermal fuse, remove back check switches with a tester to see if power goes through them. I an guessing it is the one on the dryer duct behind back panel. It is small rectangular with two wires attached to it. If dryer overheats this fuse will pop needs to be replaced. Also vacuum out all of dryer and venting, clogged venting will cause dryer to over heat and cause problem you have. Part is around $6-8. Go to www.appliancepartspros.com they have all parts you need. also a schematic of your dryer showing where all parts are located.
May 06, 2010 | Whirlpool LGB6000KQ Gas Dryer
Whirlpool Imperial dryer cyclic thermostate
there is a easyer way to check this put unit back together...put or had on back were vent blows hot exhaust air out...you should feel it get very very hot...then start to cool down..were you could put your had on the vent....if not replaced fixed tsat....please call if need more help..mike..843-384-8474...
Apr 03, 2010 | Whirlpool LER4634J Electric Dryer
Dryer works but the fuses keep blowing
If you are talking about the thermal fuse, then you have a blockage in your airflow path. Clean your dryer venting for the house, clean the dryer hose from dryer to house venting, and then make sure you clean just after the lint trap in the dryer all the way to the blower motor. Lastly make sure you do not kink the dryer hose in putting the dryer back in it's place.
If you are talking about the home's fusebox, check the amp draw on the dryer if it is less than the fuse rating by 80% call an electrician.
Oct 24, 2009 | Whirlpool LER5636P Electric Dryer
Air not heating up in whirlpool dryer
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Jun 25, 2009 | Whirlpool LER8648P Electric Dryer
Whirlpooldryer
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
Jun 21, 2009 | Whirlpool LER4634J Electric Dryer
Whirlpool electric dryer that will not heat up, dryer comes on and turns, but no heat
Check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
3. Thermal fuse
Jun 18, 2009 | Whirlpool Dryers
My whirlpool duet dry isnt heating the laundry.
Jun 15, 2009 | Whirlpool GEW9250 Electric Dryer
I have a whirlpool dryer. Model LER8648LW. Where is located the thermal fuse?
Hi and welcome to FixYA!
That thermal fuse will be located in the blower duct in the back of the machine. Take the back off the machine, look for what will probably light-blue colored wires attached to a white plastic oblong thermal fuse. For your model that part is #
3392519
If this is helpful info please rate me!
Dec 14, 2008 | Whirlpool LEQ9858P Electric Dryer
Dryers Logo
207 people viewed this question
Top Dryers Experts
