Question about Canon NP 6050 Copier
Canon NP 6050 copier Error
In screen : E020
  • 134 Answers
E020 is a toner hopper motor error. This means that not enough toner is being sent to the developer box. It usually is a hard error, meaning that the part has to be changed.
Posted on Jun 30, 2008
E020, developer have no toner. cek ware of tank toner, if connec. $ *4* toner *
Posted on Dec 16, 2008
I have a error that my copies is so light
Posted on Sep 16, 2008
What's your problem?my problem is canon np4050 machin err cod (e020)
just clean the hopper and dp unit then refill the toner ,or remove the dp connector (do not connect it)but after that the hopper dose not work and refill toner directly into dp
Oct 11, 2011 | Canon NP 6050 Copier
I have an error in my machine canon np 6050 error
"E004" Abnormal fuser temp. (fixing heater, dc controller, ac driver)
http://rapidshare.com/files/161024133/NP6050sm.rar
That link above is for a service manual. Copy/Paste that address to address bar..
Apr 23, 2010 | Canon NP 6050 Copier
E020 turn off and then back on
e020 - there is some problem with the toner hopper unit-
. toner sensor
. toner motor
. connectors to the hopper
. or dc control pcb
Oct 14, 2009 | Canon NP 6050 Copier
Er e020
Hello
E020 means :
"Black toner motor" so check it.
Jan 20, 2009 | Canon NP 6050 Copier
Canon 6050 e020
Open the front cover there is a pin hole on the grey cover inside, towards the top and left of center. Poke an extended file clip and you will see a dollar sign on the screen. Then press (*) button, 4, (*) again you should be in service mode. Scroll till you see clear or Err or error. Press OK and the power should cycle. Try that
Jul 07, 2008 | Canon NP 6050 Copier
Canon photocopier
Title : E020 Error Code Problem :
When you have followed all the steps from the troubleshooting guide in the Service Manual and still have not resolved the issue, here are some possible areas that might be related.
Solution :
1) Confirm that the toner and hopper sensors are being wiped completely.
2) Check the Gear Train on the hopper assy it may be locked up.
3) A possible bad hopper unit cable. FG5-5016-000. See The Parts Catalog page 620-2 item # 60.
Canon USA, Inc. Systems & Technical Support Division 1-800-528-2830
Jun 27, 2008 | Canon NP 6050 Copier
Cannon np 4050
The toner is not adding correctly into the developing assembly. 1) If toner hopper is overfilled, the toner motor worm gear splits as a result of the hopper becoming packed tight. 2) Sometimes the worm gear splits under normal use.
Jun 03, 2008 | Canon NP 6050 Copier
NP 6050 Languge
how to fixed canon np 6050 copier because i dont have manual book
May 03, 2008 | Canon NP 6050 Copier
Error code E020
You can reset the code by getting into service mode.
Make sure there is toner in the hopper
*4*
scroll to TONER START
press OK
and wait for the machine to stop (about 6 mins)
if the error comes back and there is toner in the hopper maybe the toner feed motor is not turning
Also check the connecters on the dev tank.
Try these first any problems get back to me
Feb 26, 2008 | Canon NP 6050 Copier
Canon NP 6050 Copier Logo
606 people viewed this question
old marine
old marine
