Question about DeLonghi DCF212T
DeLonghi DCF212T When I brew my coffee is does not go into the coffe does not go into the pot, it barely hits the hole in the lid and runs down the pot and leaks coffee onto the hotplate and onto the counter .
  • 9 more comments
  • robinsonjoe Sep 21, 2008
    I have the problem of coffee going down the tab in the back that is supposed to stop the coffee when the pot is of the heating element. The coffee goes down the tab at the same time when filling the pot. It is getting worse every day--- help
  • jgrissom Sep 30, 2008
    I have the exact same problem..........I removed the spring-loaded arm and now i cannot sneak-a-cup anymore. I have to wait for the whole
    thing to finish
  • rjao Nov 12, 2008
    Our coffee maker is about 2 months old only and now the coffee is starting to flow down the back side of the pot and down to the warming plate, it seems like it's flowing out of control coming out of the pause and serve mechanism( the spring loaded piece.
  • Anonymous Nov 21, 2008
    Same exact problem (leaks while brewing) - tried to return it at Target but lost the receipt. Even after explaining the defect they would not even exchange it!!! Had a Mr Coffee for years without a problem.
  • anddrea Nov 28, 2008
    same problem
  • casey k Dec 29, 2008
    same problem, coffee all over the burner plate and counter.
  • Anonymous Mar 13, 2009
    Same situation. Coffee leaks all over the burner.
    When I put the coffee pot on the burner, the pot should
    press the long vertical piece of plastic toward the back of the burner. This
    plastic arm should then act as a lever that
    presses on the spring-loaded mechanism that releases the coffee from the coffee-filter basket.
    I noticed there are several problems with this design.
    #1 - The coffee pot doesn't press the vertical arm hard enough so the coffee doesn't drip out fast enough.
    #2 - There is an overflow hole in the coffee-filter basket. My theory is that when the basket gets too full of water and coffee (because the spring loaded mechanism isn't being pressed hard enough to release the coffee) it drizzles out the overflow hole, down the vertical arm at the back of the burner and on to the burner.
    #3 - The lid to the coffee pot also contributes to the mess. As another customer noted, the water doesn't go down to the hole in the center of the lid and into the pot.
    Personally, I think it's just a bad design. My solution has involved
    a) leaving the coffee pot lid in the upright position
    b) making sure I position the coffee pot in such a way that the spout presses against the vertical arm @ the back of the burner
    c) wedging a knife between the coffee pot and the burner to make sure the pot is pressing hard enough on the vertical arm
    The customer who removed the spring probably had the best idea. I haven't tried that yet, but it sounds like the simplest solution.
  • mckeetammi Mar 16, 2009
    Same problem, leaks all over the coffee maker & counter.
  • Anonymous Mar 26, 2009
    Simply a bad design.
  • tom3tone Mar 29, 2009
    Am having the same problem with the overflow and it makes sense about overflow especially when you use the aroma brew will try toremove the spring and see what happens and will post the results have tried to contact delonghi they have no solutions
  • Anonymous Mar 18, 2014
    there is water leaking out of the hole in the back of my coffee pot and when its brewing i i find water underneathit from it pourin out into the pot
Posted on Dec 01, 2008
How do you clean the coffe maker
run hot water with a cup of vinegar mix in it. Once this is done run the machine through a couple of cycles with plain water to remove the sediment
Hope this helped
Dave
Feb 21, 2010 | DeLonghi DCF212T
As coffee brews it spills out everywhere. At first if I made minor adjustments to where the pot positioned under the filter it would help, but it seems to be getting worse. I can't make a pot of coffee...
The two most common reasons for overflow or underflow have to do with the carafe lid and the filter basket - they key to smooth flow with this coffee maker is making sure the filter basket and carafe lid are making the proper contact with each other so that the center knob on the carafe lid pushes slightly up on the filter basket spring. Make sure the carafe lid is completely closed. Make sure the filter basket is pushed all the way down. Make sure you are not using the gold tone filter and a paper filter at the same time. For some reason, I get better results when the handle of the carafe is resting against the right side wall. If everything is in place, I would suspect a problem with either the filter basket being clogged or some problem with the carafe lid - call Cuisinart as they should be able to order these parts for you.
Aug 16, 2009 | Cuisinart DCC-1200 Coffee Maker
Delonghi coffe pot DC312T --can't find a replacement carafe. Sams Club doesn't have them anymore.
I threw out the coffee pot. The replacement carafe was more expensive than the entire coffeepot!
Apr 17, 2009 | DeLonghi DC312T 14-Cup Coffee Maker
Braun Proaroma coffe pot wouldn't brew
I found on online operater's manual for this coffee pot and solved the problem.
Aug 21, 2008 | Braun Aromaster KF 12 Coffee Maker
Brand new, first run, leaking?
You must have the carafe lid ON. The reason is the lid has a dome on top that pushes up to let the brewed coffee come down. With the pot off look in there with a flashlight....you'll see that the 1 inch dome pushes up on the spring loaded stem.
You MUST have the lid in place or the brewed coffee won't drain into the pot.
Aug 21, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Revere Ware old fashioned coffee pot
1) Boil the water you’ll need in another pot.
2) Put 1 tablespoon of ground coffee (drip grind, not percolator grind) in the reduced diameter, perforated bottom of the brewing chamber.
3) Put the grind/water separator (the perforated, flat handled plate with cup markings on the handle) in the Brewing Chamber, over the coffee grounds.
3) Put the Brewing Chamber on top of the Holding Chamber.
4) Pour the appropriate number of cups boiling water into the brewing chamber; put the lid with the black knob on the brewing chamber.
5) Let the water drain through the coffee grinds (5-10 minutes).
6) Remove Brewing Chamber, clean out the coffee grounds, and replace the lid on the holding chamber.
7) Enjoy your coffee! Keep it warm on the stove at LOW heat setting.
for the most information on the Revere cookware lines, go to: http://mysite.verizon.net/vzeoywo4/theshineshop2/id1.html
Charlie
Jun 16, 2008 | Coffee Makers & Espresso Machines
Hamilton beach coffee maker Model 49464
Leave the carafe off the hot plate and place the basket in holder with the lip under hinged flange so it sits flat. Then replace the carafe and the basket should not move up when the Pause and Serve button opens. I just bought this pot too and
love it but except for the basket placement problem.
Feb 18, 2008 | Coffee Makers & Espresso Machines
Does not brew a full pot of coffee
I had the same issue, poured in 8 and out came 6. Here's what I did to clean and fix.
1) Unplug the NHB
2) Remove accessories like the pot and basket
3) Bring NHB over to the sink
4) Snap off the entire top cover (not the swing lid) by starting at the front and lifting upward (the top cover is about 1/4" thick). The back of the top cover will pivot a bit and then pop off exposing the pour reservoir. Remove the flow stopper inside the pour reservoir by lifting it straight up.
5) Place the top cover and flow stopper aside.
6) Remove the brew diffuser (located underneath the top where the brew basket goes. Twist counterclockwise gently but forcefully enough to snap it past the lock tabs which hold it in place. You'll know that it you've done this correctly when it just falls out.
7) Still over the sink, tip the NHB in a fashion where the back side is facing upward and the brew side is facing down into the sink. You'll be holding the NHB horizontally by the top and bottom of the unit. This will allow any water in the tank to pour out the brew spout. Begin to tip the unit as if tipping upside down as this will allow any remaining water to drain out. If this does not work the brew spout hose may be clogged and you can just tip the unit entirely upside down to empty it from the fill hole in the pour reservoir.
8) Return the NHB to the upright position in the sink.
9) Using a scotch brite sponge and some baking soda, clean the inside of the pour reservoir and rinse.
10) Using the tool Bunn provided, clean out the brew spout hose which is located under the brew hat. This is the little hole where the water comes out. If you don't have the tool Bunn provided you could use something like a plastic tie-wrap. Don't use anything metal as the hose you're cleaning is made of plastic tube and could become punctured. Clean this hose for just a minute or two to ensure that there are no significant obstructions.
11) With the NHB upright in the sink, pour a slow stream of hot water from the faucet, about two cups, directly into the fill hole located in the pour reservoir.
12) Tip the unit horizontally, as in step 7, and place the tip of your finger over the pour reservoir fill hole covering it completely.
13) Shake the unit back and forth horizontally so the water in the tank splashes around and frees anything which may be built up in the tank. Some water may splash out of the brew spout hose.
14) Tip the unit as in step 7 to drain the tank water out.
15) Fill a 16 ounce glass with hot water and 2tbsp baking soda, mix and pour into the pour reservoir fill hole.
16) Repeat steps 13 and 14 once.
17) Repeat steps 11 through 14 three times.
18) Clean the pour reservoir cover, swing lid and flow stopper.
19) Put the flow stopper back in place.
20) Attach the top cover.
21) Clean the exterior of the NHB.
22) With the boil and warmer switches off, plug the NHB into the electrical outlet.
23) Turn the boil and warmer plate switches on.
24) Fill the NHB with one pot of cold water and close the swing lid. Wait one minute.
25) Fill the NHB with another pot of cold water. Place the pot on the warmer plate and close the swing lid. If water does not yet come out, fill with one more pot of water.
26) Allow water to drain from brew spout until it stops draining.
27) Empty pot.
28) Fill pot to 10 cup line and pour into the NHB. You should find that the NHB now delivers 10 cups back to the pot. Empty the pot.
29) Clean brew spout diffuser and replace back in the brew hat.
30) Clean the pot, pot lid and brew basket.
31) Wait ten minutes for the water in the tank to boil.
32) Brew your coffee as you normally would.
The only issue I experienced during this process was with the warmer plate switch. It appeared that the light in the switch blew although the warmer plate still warmed normally. Shortly after the water in the tank started boiling the warmer switch light started operating again.
Oct 29, 2007 | Bunn NHB Coffee Maker
DeLonghi DCF212T Logo
629 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
