Question about Hitachi 53UWX10B 53" Rear Projection Television
Vertical Control Double image
  • 927 Answers
Good Day, tuggle;
Sounds like bad convergence IC’s, chips. Hit recommends using STK392-150’s and replacing the bias resistors.
Good Luck, Big Irish.
Posted on Jul 09, 2008
Lcd vertical yellow line and Black Horizontal Line with Double Image Below
Sounds like you pulled the TV apart, good luck. Hope you earthed yourself. You could try a replacement t-con board. if that was the problem. http://electronicshelponline.blogspot.com.au/2012/06/how-to-replace-faulty-tcon-board.html
Apr 08, 2014 | Vizio Televison & Video
Samsung vertical shadow screen
Does the screen have a double image? or is one side of the screen darker and has a delay? If so, your LCD panel is failing, common problem with older Samsung LCD's. I have the same model in my dining room that had a double image, fixed it by taking the panel apart and applying thermal pads on top of the panel tabs. The set works like a champ to this day!!!
Oct 27, 2013 | Samsung LN-T4665F 46 in. LCD Television
The image is double in two secctions with courvature, why?
If the image displayed in two parts 'Horizontally', the fault is with horizontal phasing. If it is vertically splitted into two parts, the fault is is with vertical sysnchronisation. Both these faults are repairable.
Jul 11, 2012 | Sony KDL52W4100
The screen has lines and double vertical images then horizonal black lines form and no image is there - a virus?
there is no virus. the problem is the screen. you need to replace it with new screen or let if fix by a technician. they will replace the vertical and horizontal transistor. or so.
Mar 05, 2010 | Acer AL1715 17" LCD Monitor
Only get black & white, double images
bad power circuit may cause such problems.
may be power ic or bad capacitors.....
Aug 18, 2017 | Philips 50PFP5332D 50 in. Plasma...
I have a 2006 RCA model R52WH73. The horazonal lines suddenly went to being concave lines and now you see a double image.
horizontal circuit problem .. vertical double image or horizontal.. check screen voltage and focus setting on board. CAUTION: EXTREME HIGH VOLTAGE. QUALIFIED SERVICE PERSONELL ONLY .. serioius high voltage..
Dec 15, 2009 | RCA Televison & Video
Control of vertical TV image projected on the screen
You can try looking for 2 things
1. A button on your remote that says either: ARC, Ratio, 16:9, 4:3.... Some remotes have a picture of a square with arrows pointing out towards each corner..... I'm unfamiliar with this set, but it sounds like a widescreen, so give it a go
Apr 22, 2009 | Televison & Video
Printed lines shift to left and double images
Are the lines vertical? Have you tried to align the printheads? This can be done using your printer's installed maintenance software.
Mar 28, 2008 | Office Equipment & Supplies
Double picture
your problem is in vertical section. 1 any capacitor in vertical section is defective. 2 transistors in output ckt might be defective 3 loose contact in vertical section. 4 problem in feed back circuit(if you are a technical person )
Sep 14, 2007 | Emerson EWF2704 TV
Vertical lines jumping across screen
If the double image is in a differant color, then its your convergence IC's that need replacement. This is not a job for the unexperienced person. If you have no electronic repair experience, please seek out a pro to assist you in this repair. There are two IC's, about 3"X5" that are black in color and have STK with several numbers following them. Good Luck PS please dont forget to rate this thread.
Nov 02, 2006 | Mitsubishi VS-55705 55" Rear Projection...
Open Questions:
See all Hitachi 53UWX10B 53" Rear Projection Television Questions
Hitachi 53UWX10B 53" Rear Projection Television Logo
32 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
