Printer nozzel will not clear I have done all the cleaning proceedures including deep cleaning to no avail.
Try this then, Nothing to loose.
OK, Canon will hate me for posting this.
1. Remove ink cartridges
2. Remove print head
3. go to sink or tub (stainless steel, not plastic type), pick up a roll of paper towel on the way.
4. Fold several layers of paper towel and place on flat surface.
5. Run hot water until HOT!
6. Turn hot water back to a dribble.
7. Run the dribbling hot water through print head, be careful not to wet the gold contacts.
8.When water running through print head is clear, place print head on paper towel.
9. Repeat number 7 and 8 until no colour shows on paper towel.
10. Gently DAB print head (DO NOT WIPE) inside and out with dry paper towel until dry.
11. I normally replace print head after drying, but you may wish to let it air dry overnight.
12. Replace print head in printer and install cartridges
13. Start printing.
I do this to all 4 of my Canon printers every 6 months or so.
If any colour fails to print after this process it means your print head probably needs replacing.
Posted on Jul 03, 2008
After doing a deep cleaning for the nozzels it still does the same??? Canon MG2011
Inkjet printers need to be used frequently to prevent blocked print head nozzles. You may have blocked print head nozzles.
Try the printer maintenance to clear the printer nozzles.
After several deep cleaning attempts and there is no improvements in the print then a new print head is required. Also try - Removing the print head, run it under hot water for 2 mins, then let soak for 10 min. then used a can of compressed air to dry thoroughly. It may fix the blocked nozzles.
A new print head maybe expensive and it maybe more cost effective to purchase a new printer.
Sep 23, 2012 | Cannon Office Equipment & Supplies
Yellow ink will not print
You may have blocked yellow print head nozzles.
After several deep cleaning attempts and there is no improvements in the printthen a new print head is required.
A new print head maybe expensive and it maybe more cost effective to purchase anew printer.
The Print head will contain all the nozzels for all the different colors so you cannot just replace a single color print head nozzels.
May 22, 2012 | Canon Office Equipment & Supplies
I have deep cleaned my MP190 twice as per instructions and still I get horizontal lines in my printing.
The printhead has a few blocked nozzels. If deep cleaning does not clear the blocked nozzels then the printhead needs to be changed.
A new printhead is an expensive item and costs nearly as much as a new printer. I suggest you put your money towards a new and better printer that may be a more cost effective solution.
May 09, 2012 | Canon PIXMA MP190 All-In-One InkJet...
I have just replaced the black in cartridge and now, when printing, gaps appear horizontally through the words. Also there is a lack of consistency in the density of black. how do i fix this? Thanks
Inkjet printers do not like being left unused for long periods.
Some of the nozzels print head may be blocked. Try several deep cleaning of the print head to see if it can clear the blocked print nozzles.
If none of this works then the print head needs to be replaced.
A new cartridge will not solve this problem.
NOTE the print head is not a cheap item, you may consider putting the money towards a new and better printer.
Nov 16, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Error message: remove and check cartridge on
If it's a new cartridge one of two possible problems has occured. 1.) The cartidge is not seated fully in the cartridge tray, or 2. when you removed the protective strip from the cartridge a small piece tore off and is stuck to the cartridge. This is a frequent problem. Uder good lighting check for any small stips of clear tape arounf the cartidge nozzels.
In addition, make certain cartifge is fully inserted in tray and locking mechanism is secure.
It sounds surpisingly simple, but I doubt anyone can say it hasn't happened to them at least once.
If it's an old carteidge the nozzel may be clogged. Remove the cartridge an either clean the nozzells with a moist Q-TIP, or dip the entire nozzel section in warm water for a few seconds. Put cartridge back in printer and print a test page. If you cleaned the nozzel with water you may finf you test page smeared with some water, but this will clear up.
Mar 31, 2010 | HP OfficeJet 7410 All-In-One InkJet...
Canon pixma iP8500 won't print, blank pages
The colour cartridge is badly clog. put tissue with warm/hot water below the head, wait for about 30 minutes. If tissue is coloured, the dried ink inside head is out. Is it not, do suction from the outlet pipe of head cleaning mechanics.
May 27, 2009 | Canon PIXMA iP8500 InkJet Photo Printer
IP3000
canon ip3000 & ip4000 the heads get dirty.
if you keep doing cleanings and deep cleanings it will eventually cause an error because it thinks the tank is full.
take out the head - in the sink, with warm not hot water rinse out much ink as possible. then use windex, the ammonia removes the ink. flush good - shake out head, drops will form on the bottom. keep doing it until drops are clear. rinse with water. shake out well. dry contacts.
I use a water pic as a pressure washer to force water thru. replace head and tanks.
do not use clean, instead print a page of 'X's
make every 5 rows a different color. this way you can see what is working and it won't fill up the cleaning tank, causing a code error.
you can use any ink you want as long as it is the proper type- don't have to be canon
Sep 16, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Green tint on photos
perform deep cleaning and nozzel cleaning from the printer properties
May 16, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Canon pixma ip3000
do nozzel clean in software utilty and cheak
Feb 03, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Printing light colors does not work
You RINSED the printhead???
I wouldn't do that again.
Try taking a damp cloth and dabbing it against the printhead nozzels until you get lines forming on the rage from the ink (the nozzels you're having trouble with specifically).
Erice
Oct 29, 2007 | Canon PIXMA iP4000 InkJet Photo Printer
144 people viewed this question
jasbo
jasbo
