After replacing the toner cartaridge, the error light comes on. In the little box, it says toner is not set. Insert toner. I have readjusted it several times. It seems to be set solidly. The problem continues. Oh, this is on a :Canon Super G3--model # F149200; serial # JVM47686--a 4 in one machine. Purchased 09/15/07 from Office Max in Asheville, NC Jo Prendergast email-Prendergastw@Bellsouth.net
  • Mike Edwards
    Mike Edwards Nov 13, 2008
    Canon F149200 all in one--says to replace toner. Did so, but message remains
  • Anonymous Jan 16, 2009
    same problem, says to replace toner after one week then 2 hours of printing. No way is it out!
You have to:
1. take paper out.
2. remove the toner
3. place the toner back
4. printer will "initialize" itself.
5. put the paper back.
Totally crazy!!!
Posted on Feb 04, 2009
Toner error
With very few exceptions, modernprinters need a full set of cartridges to even try and print.
the reasons for this are not quite an sinister as you may think. Many printers use a little colour and them finally apply black to create a very deep shade of black. printers also periodically do small cleans, checks and calibrations to keep the printer running as efficiently as possible. In order for many of these to be performed they need a cartridge of each colour to avoid damage etc.
Feb 27, 2014 | Konica Minolta PagePro Office Equipment &...
Kyocera km-2550 check toner container error
Set toner container. The toner container is not set properly. Set the toner container properly. See page 5-5 of the operation guide.
Replace Waste Toner Box The waste toner box is full. Replace the waste toner box with a new one. See page 5-5 of the operation guide.
Jun 13, 2011 | Kyocera Mita KM-2550 All-In-One Laser...
Printing blank pages
First step : Try to pull-out toner cartridge then shake it and insert again test print. if same problem appear.
Second step : change new toner cartridge.
third step : Try to contact HP service center.
http://www.hp.com
Jun 03, 2011 | HP LaserJet P2015 Printer
Hi, My Toshiba E-Studio 3511 color copier has a error message of 'dispose of used toner.' Even if I followed the direction, the error message is still there and the copier can't work. Would you help me...
I am assuming you have emptied the old waste toner "box" and not replaced it with a new box. This is not a problem, just clarifying. If this is the case then you have toner packed into the sensor block which is telling the machine that the waste toner box is still full. Just look behind the waste toner box and look for a little set of wires. They lead to a small black sensor. Now look at the waste toner box where it mates up with the sensor. You will see a small square box area on the waste toner bottle. The sensor looks thru this block and if it is blocked with toner it will tell the machine the box is full. Just tap on the little block and make sure there is no toner in it and re-install the waste toner box and the indicator should go away.
Good Luck and Thank You for using Fixya.
Aug 11, 2010 | Toshiba E-Studio 3511 Color Copier
What is error 357 waste tuner box is full okidata c9800
The printer always puts out a little more of each color toner than is actually needed in printing. The excess gets dumped into the waste toner bottle.
The replacement part number for this printer is 42869401 and should last 30,000 pages. Order one from an OKI service center and it will come with the replacement directions.
I hope this helps.
Apr 18, 2010 | Office Equipment & Supplies
Replaced the waste toner box.
re check for the toner inserted, be sure that protected plastic remove. shake and insert again.
Apr 15, 2010 | Samsung CLP 315 Laser Printer
We have replaced the toner cartaridge but it is loose and the machine is still saying toner is low
If the old toner bottle is good change the toner into new bottle in the old bottle,and perform toner forced supply.
Sep 24, 2009 | Gestetner DSm635 Copier
Konica Minolta BizHub C550 Error Message
TRY THIS
turn the machine off from main switch on bottom right and hold down the UTILITY BOTTON AND TURN MACHINE ON
Jan 15, 2009 | Office Equipment & Supplies
Error light on and toner low/ replace drum light on
I was talking to dell and they said it was because of my toner. Guess I will try a new dell toner.
Feb 21, 2008 | Dell 1710 Laser Printer
Brother 5240 laser printer changed toner still wont work.
This works on several different Brother Printers to get rid of toner/drum empty errors:
1. Open the front cover and leave open while completing the following steps.
2. Turn the printer off.
3. Hold the 'go' button while turning the printer on. All panel lights should be on.
4. Release the 'go' button.
5. Press the 'go' button 2 times.
6. Pause.
7. Press the 'go' button 5 times.
8. The toner light should be off.
9. The paper light should be on or flashing [doesn't happen on all].
10. Close cover. The ready light should be the only light on.
Oct 20, 2007 | Brother HL-5240 Laser Printer
428 people viewed this question
k24674
jasbo
jasbo
