Question about Hitachi 53UDX10B 53" Rear Projection Television
WIll not power up
When power button is pressed you hear a clik but the light will not go on nor will the TV. Sounds like the surge protector. Unplugged the unit for 24hrs and TV went on but this no longer fixes the problem Thanks much
  • jclannen Jul 01, 2008
    I was watching the tv and it popped and went off. I unplugged it like the manual said for 30 seconds, plugged it in heard a click pushed the power button the red light came on for 1 second if that - then went off. Then nothing. Power supply or fuse or what?
  • Hitachi Master
  • 5,568 Answers
The click you hear is probably from a relay that supplies power to the rest of the set.
If it responds to the remote in the same way, there is a power supply problem beyond help here.
Unplugging the set would allow all of the supply to cool down, temporarily alleviating the problem.
Posted on Jun 30, 2008
After power surge panasonic hdtv projection tv model # PT-53WX42F wont come on red light flashes
Bobbie, It dose not sound like surge protector was real effective, the TV will have to come apart to diagnose what has all blown, capacitors, boards etc. Google search can help show how it is done.
Enter all your TV's info, will not power on repair.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Apr 08, 2016 | Panasonic Televison & Video
When I turn on my Sony TV, ti stays on about 30 seconds then shuts off, What do you think is wrong?
Do a Power Reset.
1. Turn off TV.
2. Unplug the power cord of the TV from the electrical outlet.
3. Let the TV remain without power for 60 seconds.
4. Plug the power cord back into the electrical outlet. (If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.)
5. Turn on the TV.
If issue persists after doing the steps, reset the TV to factory default settings.
1. Turn on the TV.
2. Using the supplied remote, press and hold the UP arrow button.
3. While holding the UP arrow button press the POWER button on the TV itself.
4. When the TV goes off, release the POWER and UP arrow button.
5. The TV will turn on by itself and the initial setup screen will be displayed. Just follow the on-screen prompts to finish the setup.
Sony KDL 46V5100 random shut off 15 20 sec
Feb 25, 2016 | Sony Televison & Video
Power surging
sounds like the treadmill is drawing too many amps. try using a larger surge protector.
Feb 19, 2014 | Nordic Track NordicTrack C2300 Treadmill
I was watching my tv when my son hit the reset button on my surge protector..now my tv will not turn on. Any ideas?
Turn everything off, the tv the power and make sure the button is not active at the moment. Some surge protectors do come with a fuse but when you turn the surge protector back on itself make sure it is recieving power, there is usually a red light on the switch while recieving power. Then try again once you know there is power to it.
Feb 06, 2011 | Vizio E370VL 37 in. LCD HDTV
I have a Mitsubishi projection model WS-B55 that is plugged into a surge protector. The power went off for about an hour or an hour and a half this morning, and the power light is flashing. I called...
First, to answer your last question, not all power outages and subsequent surges are created equally nor are all surge protectors. Also, after a power outage where the subsequent surge is so strong that it got past your surge protector and knocks out your TV and it's never done that before... REPLACE YOUR SURGE PROTECTOR.
However, that being said, in my experience it is unlikely that the TV is going to require a technician. Understand that the person that you spoke with in tech Support is not a technician and is reading off of a list of troubleshooting pages that are more extensive then what's in the manual. What the technician is probably not aware of is that your TV, like most home electronics, has a safety failsafe that requires the device to be separated from power completely before doing a system reset
First, after pressing the button it's supposed to flash for about a minute anyway but I'm assuming that after it's done pressing that the TV is still not firing up.
Unplug the TV, let it sit for an hour, plug it back in (to the wall, not the suspect surge protector). If the light is still flashing, press the reset button again and wait for it to stop flashing and attempt to turn it on again. If it doesn't work, unplug the TV, follow the same steps however, let it sit for 24 hours before plugging it back in. That length of time is not common but some sets do require it.
If none of this works, then I would say that it's time to call a technician.
Nov 22, 2010 | Mitsubishi WS-55819 55" Rear Projection...
32 '' CRT won't turn on afer power surge
Follow these steps to troubleshoot the television not turning on:
Make sure the AC power cord is connected securely to a working wall outlet.
NOTE: If the television is plugged into a power strip or surge protector, unplug it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
Press the POWER button on the television.
Press the POWER button on the remote control that was supplied with the television.
NOTE: If the television turns on and off using the POWER button on the television but does not respond to the POWER button on the remote control, troubleshoot the remote control.
Unplug the television power cord from the electrical outlet for 30 seconds.
Plug the power cord back into a known working electrical outlet.
Attempt to turn on the television.
IMPORTANT for the following models only:
KDF-E42A10
KDF-E50A10
KDL-V26XBR1
KDL-V32XBR1
KDL-V40XBR1
Unplugging the above television models from the electrical outlet may only be a temporary fix. The problem may reoccur after several months of use. To completely resolve the issue, a software update is available.
For all other models, service will be required if the troubleshooting steps do not resolve the issue.
Aug 01, 2009 | Televison & Video
No power on Samsung TV after storm
Hello Zkarim,
I'm very sorry to hear about your unfortunate new's. I had the same problem in my own home maybe a week ago.
Basically if your power flickered on and off at anytime during this storm then there was a power surge that probably fried your TV.
* First check the power where the tv was plugged in. Is it a power strip or a surge protector ? Surge protectors typically have an on/off switch and a separate reset push button.
If it is a power strip then the tv fried because there was nothing to stop it from happening (not even the fuse). If it was plugged into a surge protector then it could be quiet a few years old and not as reliable or the surge was to powerful for the limit on the surge protector.
The only thing you can do personally is send it in for repair if it's under warranty, if it is not then you can have it looked at by an authorized repair technician in your area. Troubleshooting should be fairly low, and you will at least be able to find out your options once they find the defected part.
Thank you for choosing Fixya!
Jul 15, 2009 | Samsung LE32A457 32 in. LCD TV
Random turning off/on while watching tv
sounds like it could be a power issue. is the powercord on the back of the tv detachable? make sure its plugged in tightly. also if using a surge protector reset surge protector. if not using a surge protector try a different outlet. also if gfci outlet (has reset button on outlet itself) try resetting the outlet by pushing the reset button
Apr 04, 2009 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Cannot turn on tv
it sounds like the power surge got past the surge protector and damaged one of the boards in the back of the tv. it may or may not be worth fixing depending on what you want to spend on it
Jan 08, 2009 | Televison & Video
Reset Surge Protector
You can fix it by doing this. but first you need to make sure you leave your house for at least 4 hours so you don't have to be hearing that frigging noise, IT CAN BE DONE! i fixed it.
my unit would start beeping as soon as I plug it in wall, and red light come on, the software is telling me the battery is unplugged
this is what i did in order.
1. unplug all cords, connected to the unit, and power cord to the wall.
2. hold the power button
3. still holding the power button, Connect it to wall. (red light would be on but no beep)
4. I watched TV for 6 hours, red light still flashing
5. disconnect from wall
6 connect back to wall
I heard the unit click one time and green light came on, is charging now....
Jan 27, 2008 | Computers & Internet
Hitachi 53UDX10B 53" Rear Projection Television Logo
59 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
