Question about Philips Televison & Video
Tv will not stay on channel keeps skiping between the ext channels
  • Steve Allison
    Steve Allison May 11, 2010
    Have you tried taking the remote out of the room? Sometimes they can go crazy.
    If the set stays put, change the remote batteries.
  • 36 Answers
Pull the batteries out of your remote.. If channels stop changing check for stuck button on remote..
Posted on Jun 30, 2008
How can I locate the HDMI channel on my TV without using a remote?
There should be a button on the t.v. itself for input.
Make sure you push on the input button til the desired HDMI input
Apr 17, 2015 | Philips Televison & Video
I don't know what channel to play Dream Life: Superstar TV Plug-In on?
It plugs into the AV (Audio Video) socket on your TV. If you don't have AV sockets (they are usually coloured Yellow for video, and red and/or white for audio) then you will need to buy a Scart to phono (or RCA) adapter, cheaply available on ebay or walmart etc. You then need to switch your TV to the AV channel which will be labeled as ext 1 or ext 2 or sometimes on older sets it is channel zero.I hope
I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply.
Feb 26, 2011 | Hasbro Dreamlife Tv Plug In Electronic...
With my Sony Bravia 46" xbr the screen keeps cutting out. I'm usig hdmi cables and can't find a reason why te tv keeps cutting out. The sound still remains but picture doesn't. Not even out technician can...
Usually this happens to my set when I am in HD cable channel mode after being on a non-digital ANALOG channel.
I basically reset the TV by changing to a DIGITAL cable channel -- stay on that channel for ten-twenty seconds -- then I switch back DIRECTLY to a HD channel (key in channel number directly on remote).
TV works fine -- seems to be a glitch when the TV changes modes from Analog to HD
Jun 29, 2010 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
Need help to program my new T.V. to my remote
hold down code until it stays lit, then press tv then keep hitting channel up or channel down (either one can be used, keep pressing channel button til tv changes channels when it does press enter, or ok if enter is not there, it may take awhile maybe a few channel pushes up to 200 and up times, you use this method when you don't know the code for your tv. Hope this helps.
Nov 30, 2009 | RCA D770 Remote Control
When switiching on the TV and selecting channel 6 (s/b Sky) all I get is a blue screen to get to the sky channel the ext button has to be pressed to take it to ext2. How can I get the TV to remember the...
You must have channel 6 programed to first ext when you turn TV on it seems that it is programed on ext2 instead of ext Go to Menu then do Auto Program when you have it on ext and make sure your inputs are on first ext and not ext2
Nov 22, 2009 | Toshiba Televison & Video
Tobshiba tv stays in one channel.
You might need to go into the menu options and set the input from cable to air or vice a verse. The tv in my kids room is like that if it's set to cable with no input at the cable jack then it only gets one channel even after you try to add channels.
Dec 06, 2008 | Toshiba 36A50 36" TV
42" lcd tv suddenly went black and white on all ext's(menu still colour),now keeps changing channel by itself to ext 5.
you need to take it in for repaits....trying to trouble shoot it on here wont be of any help to you,,,most repair shops know what it is when they see what the tv is doing and will estimate the repair before they do it so that you know the cost before they fix it
Sep 17, 2008 | Sharp Televison & Video
Channel keeps changing
It sounds like a stuck button or switch. What happens when you hit the channel DOWN, does it still keep scrolling down?
Is this with or without the remote?
Have you tried it with the remote and or the TV?
Let me know whether you are changing the channels with the remote or the buttons on the tv and I can try to give you a couple more suggestions.
Mac =)
Feb 12, 2008 | Televison & Video
How to keep TV on digital?
It depends a little bit on your setup but sounds like you may have drifted from an external source to the television's internal tuner.
On my slightly different Aquos model my digital channels are "Ext 5" and "Ext 6".  There is a button next to the digits that is a square with an arrow pointing into the inside of the square.  This can be used to cycle through the external analogue and digital sources.
Push the button and then leave it for about 5 seconds as it can take a while before an image is displayed.  Keep pushing the button until the right digital channel is displayed.
Nov 13, 2007 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp 27" tv
You got the right idea,use the ext.imput on you tv and use the vcr to change the channels,you can check the solder conections in the tuner ,ussually the ground gets loose after a while but if you are not too familiar with tv service and dont want put any money in this set use your vcr.If the quality of the picture is still good then is worth keeping it.Let Us know if you need more information.
Oct 30, 2006 | Sharp 27C-240 27" TV
Televison & Video Logo
54 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
