Westclox Travel Alarm
I bought a travel alarm clock by Westclox. Have had it 6 months or so. I threw out the instructions, of course. It has a trouch screen that displays the time, alarm, date, and temperature. The only thing I can change by touching the screen is the temperature from C to F. How do I change the time and alarm?
Ck
  • 2 more comments
  • Anonymous Jul 16, 2008
    exact same problem...
  • ffarkas Aug 02, 2008
    Me too. Am unable to change the time or set the alarm
  • Ceegee9 Nov 01, 2008
    Not sure if I have "same" product - a Travel alarm as a gift called "ACU RITE" at the bottom (where yours says "Wesclox"). Not sure if it helps but the "only" touch-sensitive areas I have found are "ALM SET" (near bottom-right), the Snooze and Light (top dead center), and the keystone-shapes that say "DegC/degF DOWN" (on left) and "UP Year/Date" (on right). After that I am pretty Lost. I cannot seem to change Month or Year, and its weird "AUTO DST" and "TIME ZONE" buttons work in ways that are a bit mysterious to me! -ceegee
  • Anonymous Mar 17, 2014
    How do I set the time after clock has stopped
After selecting either TIME, DATE, or ALARM at the top of the screen, use the stylus to touch and hold the large time display. Hold it there for about 5 seconds and the clock will beep and the time display will start flashing. Then you can touch either the hours or minutes and it will increase by either 1 hour or 1 minute accordingly. When the DATE is selected, it shows the year in the large display. Again, holding the stylus on the year diaply for about 5 seconds will enter into the chqange mode. IN all cases, to exit the change mode simply select one of the other selections across the top: TIME, DATE, ALARM.
Posted on Sep 08, 2008
How to set alarm for Westclox 47550 Quartz?
Hi, A 8 year old can do this. On the back of the clock there should be 2 round turning nobs. 1 is for to set time (min...) 2sec is for to set timer for that hour...usually is a smaller hand on face of clock.
select hour to wake up at and set alarm Button. This is only basic set up.
Jan 13, 2014 | Westclox 47550 Quartz Loud Bell Analog...
How do i set year on westclox 70034 alarm clock?
You need to make certain that you have set the year right, otherwise it will show the correct day for say 2011, rather than 2013.
Jul 14, 2013 | Westclox LCD Dual Alarm Clock with...
Set alarm on rm826
Hello
Press the DATE/ALARM key once to show the alarm time.
The ((.)) icon is displayed in the lower left portion of the screen to alert you that the display is showing the alarm time. To return to the month and date display, press the DATE/ALARM key once.
Nov 17, 2011 | Oregon Scientific RM826 Exactset Travel...
Need manual for Travel Companion Model S1500 Alarm Clock
Travel alarm clocks can have varying instructions, depending on the type of clock you are using. Here are some tips for use that will apply to any alarm clock.
  1. Power source
    • Travel alarm clocks will need to have some sort of power source. Depending on the type of alarm clock, it might be battery-powered or it might have a cord that needs to be plugged in. Battery-powered alarm clocks can take mini watch batteries, AAA batteries or sometimes AA batteries. Travel alarm clocks, because of their tiny size, usually have the small batteries that need to be bought from a watch store or a dollar store. Before you leave, make sure you have a working power source and can turn it on.
    Changing the time
    • After you reach your final destination, power the alarm clock on. Now you'll need to set the time and date correctly. Check a watch, cell phone or television to get the exact time and locate the buttons or dials on your alarm clock. On some, there will be a "time" or an "hour" button you need to press and hold to activate the alarm time change. While you are holding it down, turn the dial, press the hour button or press the (+) button until you notice a time change. On others, simply pressing the hour or minute button will let you change the time shown.
    Setting AM/PM
    • The AM/PM option is critical in setting your alarm clock correctly. Make sure the LCD display on your clock has a light beside the correct AM or PM setting, or look for the letters AM or PM on the display. If you get this wrong, the alarm won't go off in the morning!
    Setting alarm time
    • To set the alarm time, look for a button or a switch that says alarm. If there is a switch, move it to the alarm setting. If it is a button, you'll need to hold it down until the time starts flashing, signaling time to change the hours and minutes to the desired alarm time, or hold it down while you press the hours and minutes buttons to reach the alarm time you want.
    Turn alarm on
    • Now double-check that your regular and alarm times are correct by switching the switch back and forth again, or by pressing the alarm/time buttons long enough to read the time set. There should be a picture of a bell somewhere on your LCD display showing that the alarm is set to "on." If there isn't, look for the on/off alarm button and move it to the correct position.
    Music options
    • The last step is finding the alarm wake-up option. Not all travel alarm clocks have this option, but if yours does there will be a switch or button that lets you choose to wake up by a buzzer, the radio, a CD, or another device.
Read more: Travel Alarm Clock Instructions ' eHow.com http://www.ehow.com/way_5250617_travel-alarm-clock-instructions.html#ixzz1YfneKhGw
Sep 22, 2011 | Vacuums
I have Westclox Atomic Clock, Model # 70026. I have lost the instructional manual. I only activate the alarm for 6:00 AM on Sunday, then I silence the alarm by pressing the Alarm on/off button. But...
Greetings.
According to the product manual, press the 'ALARM ON/OFF' button on the back of the clock until the bell symbol and 'Zz' disappear from the display screen. These symbols are between the hour and minute digiits, above the colon ( : ).
If you would like to see the instructions, they are in .jpg format:
Front page of instructions:
http://www.poyntsource.com/New/Pathimages/westclox%2070026%20-%20page%201.jpg
Back page of instructions:
http://www.poyntsource.com/New/Pathimages/westclox%2070026%20-%20page%202.jpg
You might want to save these images on your computer in case the webpage is no longer available.
Good luck from Detroit, MI.
Jun 12, 2011 | Vacuums
Need set up instructions for the KATEC #38 travel alarm clock
I bought one of these for $3.00. I found it in the clearance sale aisle at my local Wal-Mart. The instructions refer to it as being an "Automobile Clock."
In the instructions, "M" refers to the "Mode" button, "S" refers to the "Set" button, and "D" refers to the "Date" button. These are the instructions that came my KATEC #38 travel alarm clock:
1. In normal mode, there will show hour, minute, second and week. Push "D" to show date and push "S" to show alarm-time.
2. Adjust alarm-time: Push "M" two times to enter into alarm mode. Push "S" to choose hour and minute. Push "D" to adjust the right time. Finally, push "M" to return.
3. Adjust real time: Push "M" three times to enter into adjust time mode. Push "S" to choose second, minute, hour, day, week, and month in order. Push "D" to adjust correspondence number for right volume. Finally, push "M" to return to norm-al mode.
4. Sport Function: Push "M" for one time into sport watch function mode. The beginning state is show as 0:00:00. Push "D" to enter into recording time. Push "D" again to stop. Push "S" to return to the beginning mode 0:00:00.
5. Adjust ON/OFF alarm mode. In normal state, push "S" and "D". You can choose alarm on or off. When alarm operates, the alarm symbol will be displayed on.
Jan 09, 2010 | GE 74801 Clock Radio
Casio PQ-50 travel alarm
Hi, I haven't solved th eproblem, but it's such a small thing and I will just perservere - it's not worth taking your valuable time. Thanks, Rob
May 12, 2008 | Casio PQ50S-2 Travel Alarm Clock...
Westclox Monarch Alarm Clock - Model No. 90003
While holding down the snooze bar that says "ALARM" on it, hold down either of the "HOUR" button to set the hour when the alarm should go off or hold down the "MINUTE" button to adjust the minutes for when the alarm should go off.  Switch the "ALARM" to "ON" when done.
Apr 22, 2008 | Westclox Audio Players & Recorders
Alarm
Contact these guys; http://www.westclox.com/control/contactus They sell and support the Sonatina, but don't have a manual online. Hope this helps :)
Sep 01, 2006 | Westclox Sonatina Clock Radio
1,010 people viewed this question
 Grubhead
Grubhead
