4. Troubleshooting 4-2 4-2. Service Inspection Mode - Press the Delay Start + Normal + Power keys at the same time for two seconds to enter Service Inspection Mode. - "ALL" is displayed for the first three (3) seconds and then "t1" is displayed. - You can change the mode by pressing the Normal key. Each time the Normal key is pressed, the mode changes in the order of t1 → t2 → t3 → t4 → t5 → t6 → t7 → t8. - If you want to activate a mode while operating the dishwasher, the door must be closed (The Door switches are ON.) - If an "oE", "LE" or "tE1" error occur, make sure to enter Service Inspection Mode after resolving it. - Service Inspection Mode is described in the following table. Mode Related parts Symptoms Note t1 Inlet Valve Flow Meter Low Level Sensor 4E 9E If you press the Delay Start key, water is drained for 45 seconds and then the water supply starts. If the pulse count is more than 660, change the mode. Make sure to change the mode when the pulse count is more than 660 in t1 mode. t2 Circulation Motor A nozzle does not inject water. 1. Press the Delay Start key to start or stop the Circulation Motor. 2. If a low water level is detected, water is supplied again and the operation continues. t3 Circulation Motor Heater Thermistor HE 1. Press the Delay Start key to start or stop the heater and the circulation Motor. 2. If a low water level is sensed, water is supplied again and the operation continues. 3. The current temperature is shown on the display. 4. If the water temperature is more than 70ºC, the Heater does not operate. t4 Fan Motor The Fan Motor does not operate. Press the Delay Start key to start or stop the Fan Motor. t5 Drain Pump Low Level Sensor 5E 1. Press the Delay Start key to start the 2 parts. 2. When draining is finished, "t5" is blinking on the Display LED. t6 Low Level Sensor When the Micro Switch is turned on/off, there is no change on the display or a symbol other than On/OFF is displayed. 1. MICRO SWITCH On → The sensing state is displayed as 'On' on the 88 segment display. 2. MICRO SWITCH Off → The sensing state is displayed as 'OFF' on the 88 segment display. t7 Thermistor There is no change in the water temperature. The current temperature is displayed. t8 Half Load Position of Distributor Motor Micro Switch (DMR77 Model) PE 1. If you press the Delay Start key, the parts operate just once. 2. There is no stop function. 3. While the Distributor Motor is operating, its sensing state is displayed as On/OFF on the 88 segment display. 4. When the Distributor Motor stops, the sensing state (On/OFF) of the Micro Switch is displayed. Caution If it has the power problem, you must check the FUSE first.
This dishwasher has the FUSE upon the Base. Refer to the 4-10 page.TRY THESE STEPS AND SEE WHAT HAPPENS THERE IS NO CE FAULT CODE LISTED IN THE MANUAL
Thank you for your inquiry, Carlos!
From the information you have provided your Frigidaire refrigerator is displaying an error code of "SY CE" and you would like to know the meaning. The error code "SY CE" stands for communication error at power up. This could be an issue with your wiring harness, main control board, or user interface board. I would recommend performing a reset on your refrigerator and you can do that by unplugging the power cord for at least ten minutes. If that does not correct your issue I would suggest seeking assistance from a professional technician for proper diagnosis and repair. This will help you to avoid any unnecessary part purchases. Hopefully this information is helpful. -Matt
