Question about Danby DPAC10031 Air Conditioner
The control panel is never illuminated. Now my AC is not working and when I push any boutton it does not show the message because it is dark.
    Novelist:
    Champion:
  • 230 Answers
This is a circuit board problem. If this unit is still under warranty then I would suggest returning. Check your original receipt for any extended warranties that may have been associated with your purchase.
Posted on Jun 30, 2008
My 2005 GMc envoy stopped when I stopped at stop sign the service brake system warning keeps coming on when push brake pedal. Gear shifter won't move out of park and it will not start.
Hello Kammy ,you have electronic problems ! Your best bet would have it towed to a qualified repair shop .
SERVICE BRAKE SYSTEM
Refer to Brake Warning System Description and Operation !
The instrument panel cluster (IPC) illuminates the brake warning indicator when one or more of the following occurs:
• The body control module (BCM) detects that the park brake is engaged. The IPC receives a class 2 message from the BCM requesting illumination.
• The electronic brake control module (EBCM) detects a low brake fluid condition. The IPC receives a class 2 message from the EBCM requesting illumination.
• The EBCM detects an ABS malfunction which disables dynamic rear proportioning (DRP). The IPC receives a class 2 message from the EBCM requesting illumination.
• The IPC performs the bulb check at the start of each ignition cycle. The brake warning indicator illuminates for approximately 3 seconds before turning OFF.
• The IPC detects a loss of class 2 communications with the BCM or with the EBCM.
When there are electronic problems the computers will not allow the vehicle to start , hooking up a factory or professional scan tool to see what the problem is is the first place to start .
Apr 14, 2017 | 2005 GMC Envoy
I have a 2008 Chevrolet Silverado and the warning lights keep coming on telling me AC not working/engine hot ,, ??
ENGINE HOT TURN A/C OFF
Cooling System Description and Operation
ENGINE COOLANT HOT
The instrument panel cluster (IPC) displays ENGINE COOLANT HOT message when the IPC receives a class 2 message from the powertrain control module (PCM) requesting illumination of this driver warning.
ENGINE OVERHEATED
The IPC displays ENGINE OVERHEATED message when the IPC receives a class 2 message from the PCM requesting illumination of this driver warning.
DTC P1258: Engine Coolant Over temperature - Protection Mode Active
Have it check
Mar 03, 2017 | Chevrolet Cars & Trucks
Why aren't lights for center console on the shifter working?
Could have a wiring problem , a wiring pin backed out of a connector ! If you don't know about automotive electrical an wiring diagrams an electrical wiring trouble shooting I suggest you take it to a ASE certified repair shop .
Instrument Cluster and Panel Illumination The instrument cluster and panel illumination is used to provide backlighting to the instrument panel, switches, and control components when the headlamp switch is in either the PARKING LAMPS ON or HEADLAMPS ON position. The level of intensity is adjustable by pushing the instrument panel dimmer switch either up to increase intensity or down to decrease intensity.
The dimmable backlighting components are:
  • Instrument cluster
  • Hazard switch
  • Rear defroster switch
  • Message center switches
  • Parking aid switch (if equipped)
  • Transmission range selector
  • Fog lamp switch
The non-dimmable backlighting components are:
  • Driver front door lock and power window control switch
  • Passenger front door lock and power window control switch
  • Driver rear door power window control switch
  • Passenger rear door power window control switch
Principles of Operation
The instrument cluster sends a signal to the instrument panel dimmer switch. The instrument cluster provides a variable pulse width modulated (PWM) signal to the dimmable backlighting components in accordance with the position of the instrument panel dimmer switch.
  1. Verify the customer concern.
  1. Visually inspect the following for obvious signs of mechanical or electrical damage.
    Visual Inspection Chart Mechanical Electrical
    • Instrument panel dimmer switch
    • Smart junction box (SJB) fuse(s):
      • 7 (10A)
      • 15 (30A)
    • Circuitry
    • Illumination bulbs
    • SJB
    1. If an obvious cause for an observed or reported concern is found, correct the cause (if possible) before proceeding to the next step.
    1. NOTE: Make sure to use the latest scan tool release software.
      If the cause is not visually evident, connect the scan tool to the data link connector (DLC).
    1. NOTE: The vehicle communication module (VCM) LED prove-out confirms power and ground from the DLC are provided to the VCM.
      If the scan tool does not communicate with the VCM:
      • Check the VCM connection to the vehicle.
      • Check the scan tool connection to the VCM.
      • Refer to Section 418-00 , No Power To The Scan Tool, to diagnose no communication with the scan tool.
    1. If the scan tool does not communicate with the vehicle:
      • Verify the ignition key is in the ON position.
      • Verify the scan tool operation with a known good vehicle.
      • Refer to Section 418-00 to diagnose no response from the powertrain control module (PCM).
    1. Carry out the network test.
      • If the scan tool responds with no communication for one or more modules, refer to Section 418-00 .
      • If the network test passes, retrieve and record the continuous memory DTCs.
    1. Clear the continuous DTCs and carry out the self-test diagnostics for the instrument cluster.
    1. If the DTCs retrieved are related to the concern, go to the Instrument Cluster Diagnostic Trouble Code (DTC) Index. For all other DTCs, refer to Section 419-10 .
    1. If no DTCs related to the concern are retrieved, GO to Symptom Chart .
Symptom Chart Condition Possible Sources Action
  • One or more module-controlled illumination source(s) is inoperative
  • Circuitry
  • Inoperative illumination source component
  • Go To Pinpoint Test A .
A2 CHECK VOLTAGE TO THE INOPERATIVE ILLUMINATION SOURCE
  • Key in OFF position.
  • Disconnect: Inoperative Illumination Source Connector.
  • Key in ON position.
  • Place the headlamp switch in the PARKING LAMPS ON position.
  • Measure the voltage between the inoperative illumination source, harness side and ground according to the following table:
    Illumination Source Connector- Pin Circuit Rear window defrost switch C2340-3 19 (LB/RD) Hazard flasher switch C2039-8 19 (LB/RD) Parking aid disable switch C2339-3 19 (LB/RD) Message center INFO switch C269a-3 19 (LB/RD) Message center SET switch C269b-3 19 (LB/RD) Transmission range selector C2096-4 19 (LB/RD) Fog lamp switch C2341-3 19 (LB/RD)
  • Is the voltage greater than 10 volts?
Feb 02, 2016 | 2008 Mercury Mariner
Find a Diagram for 1989 Lincoln Towncar 4 Door Fusebox
this is for the base model
FUSE PANEL IDENTIFICATION (1983-90 LINCOLN TOWN CAR) The fuse panel is located in the instrument panel to the left of the steering column. To expose fuse panel, remove lower steering column finish panel.
Fuse & Circuit Breaker Identification
· 1 - 15 Amp Stoplights, Hazard Warning Lights, Speed Control Module, Trailer Tow Relays, Cornering Light Relay (1983-89)
· 2 - 8.25 Amp (Circuit Breaker) Windshield Wiper/Washer
· 3 - Blank
· 4 - 15 Amp Taillights, Side Marker, License Light, Parking & Coach Lights, Cluster Illumination, Trailer Tow Relay
· 5 - 15 Amp Turn Signal & Back-Up Lights, Trailer Tow Relay, Cornering Light Relays, Heated Rear Window Relay, Rear Defrost (1988-90), A/C Clutch & ATC Module (1990), Load Leveling (1990)
· 6 - 20 Amp Heated Rear Window Control, Speed Control Module & Clock Display, Illuminated Entry Module, Power Window & Police Accy Relays, Fuel Filler Door Release (1983-87), A/C Clutch & Cornering Lights (1983-89), Deck Lid Release (1987-90), Tripminder
· 7 - 10 Amp Daytime Running Light Resistor (1990)
· 8 - 15 Amp Dome LP-Clock, Key Warning Chimes & Electric Mirrors, Courtesy & Visor Mirror Lights, Autolight & Illuminated Entry Modules, Tripminder, Electronic Radio Memory, Trunk & Underhood Lights
· 9 - 15/30 Amp Heater Blower (15 Amp), AC/ATC Blower (30 Amp)
· 10 - Blank
· 11 - 20 Amp Radio & Power Antenna, CB Radio
· 12 - 20 Amp Door Cigarette Lighters, Power Seats & Door Locks (30 Amp), Tailgate Power Window (1983-89)
· 13 - 5 Amp Illuminated Outside Thermometer, Instrument Panel Lights
· 14 - 20/25 Amp (Circuit Breaker) Flash-To-Pass, Sun Roof, Power Windows
· 15 - 10 Amp Taillights, Parking, Side Marker/Coach, License Lights
· 16 - 20 Amp Horn & Front Cigarette Lighter
· 17 - 15 Amp Electronic Cluster, Message Center
· 18 - 10 Amp Warning Indicator Lights, Throttle Solenoid Positioner, Low Fuel Module & Autolight System, Dual Timer Buzzer & Electronic Chimes, Electronic Message Center
Feb 11, 2015 | 1989 Lincoln Town Car
Cobalt 2009. Traction Control ligh ON Possibles solutions, Please
Traction Control System Indicator
TRAC OFF The instrument panel cluster (IPC) illuminates the TRAC OFF indicator when the following occurs:
The electronic brake control module (EBCM) inhibits the traction control system due to a malfunction in the traction control system. The IPC receives a serial data message from the EBCM requesting illumination.
The body control module (BCM) detects that the traction control switch has been pressed (signal circuit is low). The BCM sends a serial data message to the EBCM in order to disable traction control. The IPC receives a serial data message from the BCM requesting illumination. The BCM sends a serial data message to the radio in order to activate an audible warning.
you need to have the ( EBCM ) electronic brake control module checked fro codes !
Jan 07, 2015 | 2009 Chevrolet Chevrolet Cobalt LT
Some dashboard lights are out
Do any lights in the ac control head work for illumination ?
Jan 23, 2012 | 2002 Chrysler Town & Country
Although I have changed the light bulbs, the lights that illuminate under the microwave onto the stove top will not work. This is a Kenmore over the stove Microwave Oven Model 721.80592402. Have their...
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid with a one-year guarantee.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
The lights can can be inoperable or stuck on or stuck in "night light" mode. Sometimes this will similarly affect the fan operation or inside light, too.
Sep 08, 2010 | Kenmore 80599 Microwave Oven
A MESSAGE KEEPS POPPING UP ON MY SCREEN AUTO CONFIG HOW DO I STOP IT
Think I fixed it.. My monitor kept flashing autoconfig and shaking a little, so I went to control panel - clicked on system - clicked Hardware - clicked on device manager - clicked display adapters - and updated the driver. Re-booted computer..
So far so good... Fingers Crossed..
Oct 23, 2009 | Acer Computers & Internet
2006 Equinox AC/Heater Control Panel light
hI THEGROVE45, did you ever get this problem fixed. I have the same problem, and took it into the dealership, they told me they would have to replace the whole unit, and told me the light inside there was not a light bulb but a wand lit up with LED.
Jun 02, 2009 | 2005 Chevrolet Equinox
I have a 2003 GMC Savana Van. The brake light came on and the brake alarm rings continously but will stop if I hit a bump (and then start again if I hit another one). I'm thinking a loose wire but several...
If someone took the time to look at the electrical schematic you will see several grounds in the circuit My first place I would go would be to check all the Grounds and Connections for the Brake Fluid level control, Brake Warning Indicator
The Instrument Panel Cluster (IPC) illuminates the brake warning indicator when one or more of the following occurs:
  • The electronic brake control module (EBCM) detects a closed brake pressure differential switch. The IPC receives a class 2 message from the EBCM requesting illumination.
  • The EBCM detects an ABS malfunction which disables dynamic rear proportioning (DRP) . The IPC receives a class 2 message from the EBCM requesting illumination.
  • The IPC detects a closed power brake booster alarm switch and closed power brake booster fluid flow alarm switch. The IPC illuminates the brake warning indicator and sends a class 2 message to the radio requesting the brake warning alarm.
Driver Information Indicators and Messages
The following indicators are used to inform the driver of several different factors.
The Instrument Panel Cluster (IPC) illuminates the brake warning indicator when the following occurs.
  • The Body Control Module (BCM) detects that the park brake is engaged. The IPC receives a serial data message from the BCM requesting illumination. The brake warning indicator flashes at a rate of approximately twice per second when the park brake is engaged.
  • The EBCM detects a low brake fluid condition or base brake pressure differential and sends a serial data message to the IPC requesting illumination.
  • The IPC performs the bulb check.
  • The EBCM detects an ABS-disabling malfunction which also disables Dynamic Rear Proportioning (DRP) and sends a serial data message to the IPC requesting illumination.
Here is a description of how the system works But i would check my Grounds and connections
www.aceautomotive1.com
Contact me if you need any more information Ill be glad to help
Aug 01, 2008 | GMC Savana Cars & Trucks
Danby DPAC10031 Air Conditioner Logo
155 people viewed this question
Top Danby Heating & Cooling Experts
coolfelix
Level 1 Expert
Dan Webster
Dan Webster
Dennis Boxerman
Are you a Danby Heating and Cooling Expert? Answer questions, earn points and help others
