Question about InSTEP Ride N' Stride MK750 Twin Seat Stroller
3 month old instep...strap broke
Strap at bottom of seat support broke...it is only three months old and only 1 28 lb child has riden in it thus far. we have used it about 20 times I guess. we also need an attactment for my husbands bike so either of us can pull her. how can I get these parts?
  • annette3022 Aug 17, 2008
    Have had my Ride N' Stride for about 4 months now. The shoulder harnass on the one side has completely torn off. Also, it looks like the strap that hold the seat in place is about to break.
  • tcbeard Dec 20, 2008
    I can't find any place on the web with replacement straps for a Schwinn/Instep jogging stroller. Anybody have any clues?
Instep.com ...provided
Free seat and strap after discussed the problem with it
Posted on Jul 01, 2008
Does the car seat need to be bolted to the car when the harness is removed for a child over 50 lbs?
I have a similar car seat for my 4 year old. You should check your local laws about how long they have to use a car seat. Depending on the situation, if it's leaning around to far you may just go without it. I've never seen a model that is 'bolted' to the car. Most of them at the booster stage are held in by the childs weight and the safety belt in the car. If it has straps for the 'Latch' system, and your car has latch mounts, you might do that to help stabilize it.
Hope this helps! Don't forget to rate!
Gtaplytmpt
Jul 18, 2011 | Graco Nautilus 3-in 1 Car Seat
Tip
How to Install a Child Seat
FOR LARGER KIDS: If the child is over 35lbs, use the belt and shoulder harness as you would an adult and simply extend the belt over the seat. You do not need to install any of the built in straps.
SMALLER CHILDREN (UNDER 35 lbs):
1) If your child is under 35lbs get the locking clip that came with the seat if you have a seat with a shoulder harness attached. Otherwise, it isn't necessary. Pull the shoulder harness down to the base of the waste strap and then use the locking clip to bind it into place.
2) For a smaller child you will need to install the built in straps like so.
3. Set the seat in place running the waist strap through the back of the seat and clipping it on the other side.
on May 06, 2010 | Baby Gear
Hi there. I have a smart trike classic.I would like to change it to 15month+ and have remved the sunshade and backing. However is there a seatbelt for it at this stage I cannot work out how to take the...
  • For 15 months you remover the headrest.
  • The safety rails come off.
  • As for the harness - there is a single strap that will go around your child's lower abdomen and wrap behind the seat. This strap weaves into a hole on a strap that runs from the front of the strap around your child's waist, under the seat itself and up to the waist strap in the rear. So basically the way the harness is set up for 10+ months old your gonna remove the over the should part of the harness and run the two buckles in front behind the seat.
Regards, Tony
Apr 27, 2011 | Toys
Hello, Have used Nania Newfix Solo child seat very satisfacorily for 3 years with harness. Now time to remove harness (leaving back of Childseat in place). Have removed harness as per instructions -...
Right,
After several months of struggle to find written instructions how to attach the central harness adjustment strap (The one with metal anchor at the end) to the red clip (buckle) strap as seems to be shown in instructions. budyn71.jpg
I have found number to temtex uk company that supplies nania products to argos on 01162844910, while emailing them on sales@teamtexuk.com had no result. There's no need to attach the two. Central harness adjuster strap has to be detached and pulled by it's front end as far as it goes. budyn71_0.jpg
While red clip strap threads through the gap between backrest and the base. budyn71_1.jpg
And red clip strap threads through hole (bracket) at the back of the base. budyn71_2.jpg
Sep 26, 2010 | Nania Solo Combination
Instep bike trailer assembly
This is the manual for the model that you have. Pictures included. http://www.instep.net/productInstepPDFFiles/168pdf-1pdf
May 25, 2010 | InSTEP EZ Bike Trailer
The seatbelt seems to rub badly on either side of my child's head
Hi you can get harness extensions from Dorel free a lot of peole have the same problem, I take it you bought it in 2007. If so you can also get the xl seat cover for 18mth + free from dorel
May 10, 2010 | Quinny Buzz Three Wheel Stroller
I have a bittax eclipse si and just cannot adjust
below the strap that comes up between childs legs there is a **** in the fabric, stick your finger in & push the top of metal tab..then hold that down while pulling the shoulder straps, pull the straps from the lower half tho, not up high
Nov 08, 2009 | Britax Eclipse Si - Paris Convertible Car...
The straps have deteriorated on the seat of our InStep trailer. Is there a replacement seat with straps that we can purchase.
you can call the company at (800) 242-6110 otherwise depending on the where the straps are you can goto almost any store - home dep - lowes - target - and make straps. Cut a hole either in the back or under the seat and strap them through.
Aug 23, 2009 | Take 2 Interactive Instep Take 2 Bike...
Latching system for a child car seat honda accord
IF YOU GO TO A HONDA DEALER THEY SELL A SET OF THREE ANCHORS IN KIT.(JUST ASK FOR REAR CHILD SEAT ANCHORS)THEY RUN ABOUT $25 FOR SET. AT THAT POINT YOU CAN HAVE THEM OR YOUR NORMAL MECHANIC INSTALL FOR YOU OR IF YOU CHOOSE TO INSTALL YOURSELF THEY'RE FAIRLY EASY TO DO.IF YOU OPEN UP TRUNK AND LOOK AT BOTTOM SIDE OF REAR DECK(BEHIND HEADRESTS)YOU WILL NOTICE 3 SPOTS WHERE NOTS ARE WELDED TO DECK SPACED EVENLY ACROSS DECK.ONCE YOU HAVE A BEARING OF THERE LOCATION YOU TAKE A RAZOR BLADE AND MAKE THREE SMALL CUTS FROM TOP SIDE IN DECK FELT WHERE THESE NUTS ARE LOCATED. THIS IS WHERE SEAT ANCHORS BOLT TO.THERE ARE ALSO IN THE CREASE OF SEATS SMALL HOOKS TO ANCHOR LOWER STRAPS OF CAR SEAT TO.YOU KIND OF HAVE TO FEEL AROUND FOR THEM BUT ONCE YOU FIND FIRST TIME YOU LL GO RT TO THEM EVERY TIME. GOOD LUCK! JOEL
May 29, 2009 | 1999 Honda Accord
Straps ripped on my Instep double jogging stroller (11-KA200)
Instep does have replacement parts for some of their strollers. For $25 I was able to purchase a new seating pad.
Apr 18, 2009 | InSTEP 10K Double KA200 Jogger
InSTEP Ride N' Stride MK750 Twin Seat Stroller Logo
293 people viewed this question
Top InSTEP Baby Gear Experts
Jennifer Rock
Jennifer Rock
michael vanier
Are you an InSTEP Baby Gear Expert? Answer questions, earn points and help others
