Question about Sony VAIO RB30C (VGCRB30) PC Desktop
Won't Start I shutdown my computer and about 8 hours later I attempted to turn it on. The computer will not turn on at all. No fan, no blue glowing Vaio logo, no green power light next to the power button, nothing. The only thing that is on is a small blinking green light next to the power cord on the back of the computer. There is also a smaller green light inside the computer flashing. All cords are firmly connected. The outlet has been checked with other electronics and works. I greatly appreciate any and all suggestions. Thank you in advanced.
  • 1 more comment
  • mailebu Jul 13, 2008
    I have the same problem, so if it is a blown fuse... how do I fix it and why is that green light blinking?
  • Anonymous Aug 24, 2008
    pc runs for about 1 hr, then it shuts down and will no start again.
  • scott0471 Dec 23, 2008
    same blinking light no pc
Look at the fan of ur power supply, if its not working try to replace ur power supply and im sure its fix.
but if the fan is working, check ur reset and power button.
Posted on Oct 02, 2008
    Sergeant:
    Champion:
  • 417 Answers
BLOWN YOUR FUSE NEED NEW FUSE IN THE POWER SUPPLY
Posted on Jul 02, 2008
2 Suggested Answers
CompuFirm
  • 89 Answers
SOURCE: Sony VAIO RB30C (VGCRB30) PC Desktop Won't Turn On After reinstalling ram
Unplug the tower
Remove the ram and turn the tower on wait till it give you fast beeps. (telling you no RAM)
once that happens shut the system down by unplugging it again
Re-install your RAM and try to boot again
Posted on May 27, 2009
Computer shuts down
Make sure Windows Update is turned on. For Windows 7, Vista, and Windows 8 there are Updates that resolve some hardware glitches such as the one you are experiencing.
Apr 03, 2014 | Dell (6F858) Cooling Fan
2003 BMW 325 I won't start. Black smoke from exhaust and stalled
Hi. This is a common fault with m50/52/52tu engines. Engine is flooded because you did not warm it up. Must be out of blue on temp gauge be for you turn off.
Feb 11, 2013 | BMW X3 Series Cars & Trucks
For some reason the heater does not generate heat. the fan works but no heat. Any Ideas?
I've got an easy way for you to check, and then we can help you from there.
First pop open both lids to your furnace (this may require a screwdriver). Turn up your thermostat, push the safety interlock button in if it has one (it's a button that turns off the power when the doors are removed), and watch.
On most modern furnaces (past 20-25 years) you'll hear/see:
1. Inducer fan
2. orange glow (ignitor)
3. Gas valve opening and ignition (flames)
4. Main Fan.
that's normal heater operation.
The most common issue here is a burned out ignitor, in which case you wouldn't see the orange glow but the sequence would attempt to continue anyway (the gas valve will open and hiss gas, but it won't lite, then it'll give up and try again a few minutes later).
On older furnaces there's a pilot light to start with, the click of the gas valve and boom... ignition.
On new furnaces it's
Inducer fan
gas valve opening
spark - ignition
Main fan.
and there are some oddballs in between, particularly the Lennox Pulse. If that's your furnace just back away slowly and call a professional... some guys won't even touch those, so be sure to mention what it is... if you call a pro.
So go ahead and watch it run, then tell me/us what you see.
May 06, 2011 | Bionaire Heating & Cooling
Outdoor lights timer: Intermatic HB851 photo timer with dial. How do I set it for dusk ON then off in 8 hrs.
Intermatic make HB51 timer.
If this is not your timer, then add a comment.
To set for ON at dusk, and off 8 hours later, rotate dial to the number 8.
Timer turns on automatically at dusk.
Timer set to 8 hours will start countdown when timer turns ON > and 8 hours later timer will turn off.
Make sure timer is turned away from lights so photo-eye doesn't receive feedback.
Feedback is when the photo eye gets too much light, and then timer thinks it's dawn, so lights turn off, and a moment later photo eye thinks it's dusk again and lights turn on again.
Feedback from lights will cause timer to reset the 8 hour countdown.
A car pulling in the driveway can cause feedback.
If the timer resets because of feedback, it begins the 8 hour countdown again, so the lights will not turn off until dawn.
You can test timer by putting black tape over photo eye, and then timer will turn on.
Set timer for 2 hours for example and then check if timer turned off 2 hours later.
If timer is not functioning correctly, then timer is defective.
Dec 18, 2010 | Woods Outdoor Lighting Timer
My 1986 F250 with a 6.9 diesel engine will not start on a warm day unless it is plugged in for an hour before. Once it fires up, it will run great and I can turn it off two hours later and it will still...
Sounds like your batteries are not producing like fully charged batteries. You may have to replace them do you have the tool to load check them? Hope this helps you. Darrell S
May 22, 2010 | 1986 Ford F 250
My acer aspire cooling fan is not working properly so it turns off unexpectedly several times a day.
if the cooling works well the fan gonna shutdown automatic. nothing to worry about, but if it does when the computer is still hot then you need to replace the fan.
when it shutsdown, does it later start by it self?
Feb 24, 2009 | Acer Aspire L100 PC Desktop
Computer won`t start
Hello there my friend
There is a easy check, it sometimes MEMORY PROBLEMS, or VIDEO , check your RAMs, and take out one module, if has more than one, and restart the PC, I know you will write me back! :)
tell me!
Open Sky
Sep 19, 2008 | Everex GA3400 Refurbished AMD Desktop...
Sony VAIO RB30C (VGCRB30) PC Desktop Logo
639 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
