My p2 my mp3 battery isn't working correctly because every time i charge the battery it says on the screen fully charged but when i disconnect it and play a song it tells me low battery so i was wondering what to do to fix this problem.
    Sergeant:
  • 250 Answers
Hello minie2008,
It sounds like the battery in your MP3 player is failing. Rechargeable batteries have a limited lifespan. Over time the amount of time you can expect between charges will decrease until the battery eventually does not hold a charge.
Although the battery pack in most MP3 players is not generally considered to be end-user serviceable you should be able to get service on the battery by contacting the manufacturer of the unit. If the unit is out of warranty there would normally be a cost associated with that service. Or, if you have experience repairing electronic devices you may be able to purchase a new battery and replace it yourself.
Hope this helps,
Ken
"Go Ahead. Use Us."
Posted on Jun 30, 2008
My Go gear vibe 4gb MP3 battery is flat and won't recharge.
If the rechargeable battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Apr 03, 2012 | Philips GOGEAR SA6045 MP3 Player
Tip
How do I charge my iPod touch for the First Time
<p>Apple iPod touch is a personal audio player with the ability to store and play MP3 files, digital video and downloadable games and applications. The unit is powered by a rechargeable battery. When charging the battery for the first time, ensure that the battery is fully charged. From there you can turn it on or removing the device from the charger, if desired, regardless of battery level. <br /> <p><br /> <p>1. Enter the main connection for the iPod cable to the socket at the bottom of the iPod touch. <br /> <p><br /> <p>2. Insert the small plug into a USB port on your computer. Turn on the computer. Alternatively, an iPod charger, sold separately, you can recharge your iPod touch with a socket. Connect the wall charger into an AC outlet. Insert the plug on the door of the small wall charger. The battery icon located in the upper right corner of the screen, the battery is charging. <br /> <p><br /> <p>3. Let the battery fully charged. When the battery icon to indicate the device is fully charged, remove the iPod from the cable. <br />
on Aug 09, 2011 | Apple iPod touch
My mp3 isn't turning on even thought it is fully charged but plays music when plugged into USB
There is a Problem with the Mp3 Battery its not Charging get it Replaced!
Dec 29, 2011 | Audio Players & Recorders
After charging my MP3 player it appears fully charged but it will only play for about an hour and the battery runs down. i have recharged it again, same thing. now what?
The very first time you charge your battery YOU MUST CHARGE IT FULLY!!! If you didn't, that is probably the problem.
Also, even if you charge the player for just a couple of minutes it will APPEAR to have a fully charged battery when it actually doesn't.
Most portable media devices require at least 20 minutes to an hour to fully charge whether the screen shows that it is fully charged or not.
Jun 30, 2010 | SanDisk Sansa e250 MP3 Player
I just bought a Jensen smpv-2gbub player. How do
How to charge the Jensen MP3 player - Model smpg-v2bub
Ignore instructions that came with it - they don't work.
Here's how to charge - I discovered this with mine:
1. When computer is on and at windows screen, attach cable from computer to mp3player with mp3 turned player off. It will immediately show you a connect screen on the mp3 player.
2. pressed the left side middle button twice - this will turn it on and go into music like you're playing a song.
3. Now turn the mp3 player on by switching the button on the right side of the device to the on position. It will suddenly show you it's charging - the battery on the front of the mp3 player will have a signal pulsing through it.
4. It will turn off after one minute. It's literally half charged now. Strange I know. Repeat from step 1 and it will fully charged.
If it doesn't fully charge after it turns itself off after 1 minute the 2nd time, then repeat steps from 1, one more time, but this time when it turns itself off after a minute, still leave it connected to the computer for 10 mins even though it looks like it's off. Then disconnect it physically from computer, turn it on with the on button on the right side, press the left side middle button twice and look at the battery on the screen - it should be fully charged now.
Apr 07, 2010 | Jensen Audio Players & Recorders
Jensen SMPV-2GBUB wont turn on or charge
How to get the Jensen mp3 to charge - model smpv-2gbub,
transparent-pixel._v42752373_.gifIgnore instructions that came with it - they don't work.
1.When computer is on and at windows screen, attach cable from computerto mp3player with mp3 turned player off. It will immediately show you aconnect screen on the mp3 player.
3.Now turn the mp3 player on by switching the button on the right side ofthe device to the on position. It will suddenly show you it's charging- the battery on the front of the mp3 player will have a signal pulsingthrough it.
4. It will turn off after one minute. It's literallyhalf charged now. Strange I know. Repeat from step 1 and it will fullycharged.
If it doesn't fully charge after it turns itself offafter 1 minute the 2nd time, then repeat steps from 1, one more time,but this time when it turns itself off after a minute, still leave itconnected to the computer for 10 mins even though it looks like it'soff. Then disconnect it physically from computer, turn it on with theon button on the right side, press the left side middle button twiceand look at the battery on the screen - it should be fully charged now.
Jan 30, 2010 | Jensen Audio Players & Recorders
Sony Walkman NWZ-S618F MP3 Player - Screen display not working
I Have the same problem, but mine has vertical lines running on the display, try contacting sony support
May 12, 2009 | Sony Walkman Video NWZ-S618F MP3 Player
YP-T9 constantly charging?
if you recharg it too much it could be wearing down, I'm guessing. unless oyu just got it.. you should take ti back because that's just messed
Jul 02, 2008 | Samsung Yepp YP-T9 Digital Media Player
Philips mp3 player sa6045
This player shows the "Do not disconnect" message when it is doing something critical such as transferring tracks or updating firmware, which could corrupt the player if disconnected part way through.
The player shows the "OK to disconnect" when it is idle. As the message says, it's ok to disconnect, as the player will not corrupt if disconnected when it is idle.
These messages mean that the player does not need the "Safe to remove" procedure.
It is ok to disconnect part way through charging. Also the player will condition the battery once it is fully charged, so it's ok to leave it charging.
Occassionally batteries can "memorise" when constantly disconnect and reconnected without fully charging and discharging. To help prevent this, fully discharge the player (leave on until dead) and fully charge and condition (leave charging for about 12 hours) every couple of weeks or so.
Feb 11, 2008 | Philips GOGEAR SA6045 MP3 Player
111 people viewed this question
 Grubhead
Grubhead
