Question about Samsung Refrigerators
Samsung model number RS20CCSV fridge not working digital display flashing. freezer working
SOURCE: Samsung RCS21DCNS Side by Side
probly the evaporator coil in fridge all frozen up you need to pull all the back out inside the fridge section and defrost with air drier
Posted on Sep 21, 2007
  • 27 Answers
SOURCE: Digital display is blank in GE Profile fridge
Hi. Its either a bad motherboard or control board. I would check the control board for any obvious signs of damage to the board first. I've seen the control board go blank on the GE side by side and it turned out to be the motherboard. The motherboard is located behind a cover on the back of your refrigerator cabinet. You should have a new motherboard on hand at all times because they fail alot. Be sure to put a surge protector on your refrigerator. Good Luck, Mack
Posted on Feb 02, 2008
SOURCE: Fridge and freezer stopped working.Power still on
The double dashes in your display are for one of two reasons. First situation would be would be "you turned the unit off". Press the up arrow on the feezer or fresh food control until a 4 is in each display. Second, if the control is locked out, the board has been scrambled or failed possibly from a power surge. Unplug unit for 30 seconds, and plug it back in and try to set control's for "4". If controls are still locked out, the board (12868513) needs to be replaced.
Posted on Jun 05, 2009
  • 2237 Answers
SOURCE: samsung model rs2577sl. fridge side not working
5 reasons for fridge and/or freezer getting warm: 1- the evaporator coils are icing up and won?t let air circulate. 2- the evaporator fan is not working to circulate air. 3- there is no refrigerant in the system. 4- no power to fridge or compressor. 5- the condenser coils have no air circulation check under the fridge behind the vent. if it is too dusty or the fan isn?t working, it is not getting enough airflow to cool down. replace fan and/or vacuum out the dust. if there is no power to the fridge, the light will be off. if the compressor is not running, there is a defrost timer that cuts the power temporarily to the compressor to melt ice on the coils. it?s located under the fridge behind the bottom vent. If the timer is off and the compressor is not going, the compressor or the main board is bad and needs replacing. there is also a temperature sensor on the evaporator coils that tells the defrost coil to turn on and when to turn off. if the defrost timer is on but the coil is not heating up, replace the sensor. if it still won?t heat up, it?s the timer or the coil. the easiest way to tell if there is no refrigerant- the freezer wall is warm and the compressor is loud. if there is no refrigerant, it may be more cost effective to replace the fridge. if you feel no air coming from the freezer vent, the fan needs replacing. If you feel air moving in the freezer but not the fridge, the channel from freezer to fridge is blocked. if the freezer has air and the rear freezer wall has frost on it, the evaporator coils are iced up and need defrosting. causes: 1. low refrigerant 2. no fan 3. too much humid air in fridge/freezer due to door open or bad door seals 4. the condensate drain tube is clogged if the seal around the door is ripped or not completely sealing, or there is condensation at the bottom or the walls of the fridge, replace the seal(s). no air, no fan. Replace if the refrigerant is low, it just needs a top off. but you need to be certified by the epa to move refrigerant, so get a professional. defrost solutions: unplug the fridge. remove the wall of the freezer that is frosted/icing up. use a hair dryer to melt the ice. do not get too close. you will see a drain under the evaporator coil. make sure it is not blocked. the water should run freely to a condensate pan under the fridge that evaporates the condensation with the hot line from the compressor. once the coil is free of ice, frost, and water, replace the panel and repair any of the problems that caused the icing up. plug the fridge in and turn it on. If it frosts up within a week, there is still an issue that not been taken care of.
Posted on Aug 26, 2009
  • 1891 Answers
SOURCE: My digital display reads 88 degrees for the fridge
reads 88 deg/ ok is frig that warm also .. if so replace the p c control as it has gone bad . in some models they call it a jazz board . / there is a update and it works much better .. mm
Posted on Dec 23, 2009
My samsung control on the freezer is displaying OF OFseems ice maker is off I pushed the power freeze by accident and can't get back to regular display
0F 0F on a Samsung refrigerator display indicates that your unit is in DEMO Mode. In DEMO mode, the lights work, but the refrigerator/freezer, fans, etc. will not operate (this mode is for display/retail purposes in appliance stores). Unfortunately, Samsung does not include any info re: DEMO mode in their user manuals.
To exit DEMO mode and return to operating mode, you will need to push 2 display buttons simultaneously for ~ 3 seconds (you'll hear a small chime, then the display window will display the freezer/fridge temps and will then be out of the 0F 0F DEMO mode). The 2 display buttons that you have to press simultaneously will depend on the model of Samsung refrigerator that you have.
I have a Samsung RF18HFENBSR model (french door, bottom freezer, display at top center of fridge compartment). For this model, you press the Power Freeze & Freezer buttons at the same time to enter/exit DEMO mode).
You might try googling Samsung XXXXXXXXXX Demo Mode, where XXXXXXXXX is your model number, and you may find the display button combo for your model. If not, then you can probably get the combination from Samsung support to return your unit to normal operating mode. Your appliance store may also have that information.
Sep 10, 2017 | Samsung Refrigerators
Samsung fridge freezer SR2028CVW not cooling or freezing
If you have used it since 2004, it probably is worn out.
May 02, 2017 | Samsung Refrigerators
I dont now how to set temperature for samsung rsh1nhmh . All the light in the house vent off and the plugs . Now on the frige screen is only a flashing light. Nothing else
The refrigerator temperature can be set between 7?C (46°F) and 1?C (34°F) to suit your particular needs. Press the Fridge button repeatedly until the desired temperature is shown in the temperature display. The temperature control process for the Fridge works just like the Freezer process. Press the Fridge button to set your desired temperature. After a few seconds, the Fridge will begin tracking towards the newly set temperature. This will be reflected in the digital display.
Nov 18, 2010 | Samsung Refrigerators
My digital display reads 88 degrees for the fridge and the freezer. The 88 display on the right is flashing. None of the buttons work when pressed.
Dec 23, 2009 | Samsung RF265AA Bottom Freezer French Door...
Side by side fridge freezer
Based on your weird display issues I'd lean toward the control board problem. At least that can be "one" of a couple problems...
Feb 01, 2007 | Samsung RS2578BB Side by Side Refrigerator
Refrigerators Logo
130 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
