Question about Sharp CD-C401 Shelf System
Sharp cd-c472 how do I reset the clock & computer on the sharp cd-c472?
  • Anonymous Sep 03, 2008
    Thanks Imperial Kid! This works on the CD-C422 as well.
I did solve the problem; instead of spending time online looking for a user's book, I tore my house apart and found the original one. Thank you for your response.
To set the clock for the Sharp CD-C472:
1. Power switch off
2. Press CLOCK button.
3. Within 3 seconds, press MEMORY/SET button.
4. Press TUNING/TIME to select time mode (12 or 24 hour)
5. Press MEMORY/SET button.
6. Press TUNING/TIME to select hour.
7. Press MEMORY/SET button.
8. Press TUNING/TIME to adjust minutes.
9. Press MEMORY/SET button.
Please note, your "solution is valid for" choice forced the Sharp CD-C401 selection BUT THAT IS NOT ACCURATE THIS SOLUTION IS SPECIFIC TO THE CD-C472.
Posted on Jul 01, 2008
How do I get a user manual for sharp cd-c472
do a google search for "manual sharp cd-c472" several show up including the service manual.
Sep 27, 2014 | Sharp CD-C472 Shelf System
Can computer reset CD player once it is stuck after clock spring replacement?
The CD player has nothing to do with the clock spring your player failed on its own there is no way this caused it to fail
Jun 14, 2014 | Volvo S60 Cars & Trucks
Setting up the Date & Clock after reset
Follow the instructions on the first page of this manual.
Apr 05, 2013 | Sharp EL-1197PIII Calculator
Error c472
[C471/472/473/474/475] indicates IH power voltage abnormality or IH initial abnormality
Clear the status counter (08-400) to "0". If still occur again, u need to check followings:
1. Check the AC input voltage
2. Check the thermostat
3. Check the IH control board
- Check if the AC input connector on the IH control board, the LGC I/F connectors CN455 is dis-connected?
- Check if the fuse on the IH control board has blown.
- Replace the IH control board.
4. Check the LGC board
Jun 17, 2012 | Toshiba COPIERS E-STUDIO 520 Copier
Set the clock
yes you have to make shure its off and then click the clock button use the tuner buttons to change
May 31, 2010 | Sharp CD-E67 CD Shelf System
Where can I find a manual for sharp cd-c472 shelf system?
Hi you can get manuals here auto.manualsonline.com/ex/thread/view/idThread/399708
Aug 11, 2009 | Sharp CD-C472 Shelf System
Unit will not turn off when OFF button is pushed.
I followed the instruction on how to reset the computer components, but the unit keep flashing Normal, Bypass and Phantom. The clock was flashing, so I resent the clock, and the flashing back and forth stopped. I just tried it again to be sure it was still working properly and it is!
Jan 28, 2009 | Sharp Multi-System Mini Component System...
How do I reset the clock on sharp model no. R242?
Normally you press Clock, then the numbers, then either Clock again or Start.
If that does not work, you can call Sharp USA at 1-800-BE-SHARP (1-800-237-4277) for assistance.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jan 20, 2008 | Microwave Ovens
SHARP ATOMIC WALL CLOCK RESET
I have a sharp 12 inch atomic clock...cant get it to reset and dont have instructions...please help
Oct 13, 2007 | Audio Players & Recorders
Speakers Not Working
Probably not My friend. These self type audio units use an audio output IC and if it blows out you must replace it. Its a soldered in device and is not a consumer replaceable part ,unless you have some know how on desoldering and soldering. This repair should run somewhere around 85 to 125 bucks to repair. Good Luck
Jun 24, 2006 | Sharp CD-C472 Shelf System
Sharp CD-C401 Shelf System Logo
1,343 people viewed this question
Top Sharp Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
