Philips 50PFP5332D 50 in. Plasma Television Logo
Anonymous Posted on Dec 12, 2010
My 50 Phillips Plasma TV will not turn on. It just makes a clicking sound and blinks a blue light.
Anonymous
Level 3:
  • Master 608 Answers
  • Posted on Dec 12, 2010
Anonymous
Master
Level 3:
Answers
608
Questions
0
Helped
125582
Points
1784
I had a similar problem with my 42 in Philips LCD HDTV.
Here was the problem. My Power Supply Board had several bad capacitors. I opened my TV (warranty was expired ofcourse) and found four bulged capacitors. Many electronics companies were sold capacitors that failed in 2-5 yearsinstead of 10-20. The capacitors failprematurely due to a lack of preservatives. Unfortunately, they were installed in allsorts of devices and cause a wide range of failure problems. Here are some options for you.
1. Have it fixed by a professional $$$$$$$???????
2. Open your TV and find PSB. Checkfor faulty caps. If you find some (bulgedor leaking) bad caps replace the entire board. The entire board costs around $250 right nowbecause they are in high demand right now. They can be found at tv-part.com but supplies are limited.
3. Remove and then replace individual faulty caps. This takes some soldering skill. Caps are inexpensive and if you can take care of it yourselfit will save you hundreds.
I have a tip/tutorialon this site that may also help. Itgives step by step instructions for replacing caps on PSB #715t2432-2. If this is your board you are in luck. It's called: Fixing the Philips Turns/shutsoff on its own problem. I'mworking on uploading pictures to help guide people though the process aswell. Let me know if I can do anythingto help. Hope this helps and Good luck. Kaufman605
Testimonial: "Thank you"
  • Anonymous Dec 13, 2010
    No problem. Thanks for using Fixya.
  • Anonymous Nov 15, 2012
    Thanks for the info, I replaced the 4 bad caps, but I still get a squeeking sound coming from the board 715t2432-2 and still no picture. Any other ideas please
Find activation code for pioneer
My pioneer 5020FD Kuro tv. when I plug power to the unit, a blue light blinks 8 times pause 2 sec. and blink 8 times repeating this and if i press power button it clicks red light and makes a clicking sound and goes back to the blue light blinking again, it did this once before and the picture came on fine until i turned it off and now it just blink the blue code.
1helpful
50" Philips Plasma 50pfp5332D/37 won't turn on
I have a 42in vizio led with about the same problem i replaced a 75 cent chip # u33 on computer board problem fixed.
I have a 50" Phillips
Sounds like there is a couple bad caps in the power supply. Check the power supply to see if there is any bubbled caps. Replace with a higher voltage if necessary.
7helpful
My 50 inch Hitachi plasma 1080 tv has a blinking blue light and screen is blank when powered on.
my hatachi hd/1080 tv has a solid blue light on and it wont turn on i push the reset button on the bottom right and it still wont turn on
2helpful
50" phillips plasma wont turn on
I'm having the same problem and am about to try this solution. I truly believe this is going to work. I hope this helps!
http://www.youtube.com/watch?v=OsJSzYVUWVA&feature=related
Tv wont turn on and automatically shuts down
I'm having the same issues with my phillips flat panel. I downloaded the firmware update from phillips and that helped...but only once. I'm back to the same issue this morning. But you might try this download...it may work for you.
2answers
Power light for tv turns on but no picture and no sound comes on tv i have a 50 inch phillips plasma
Check your cables and TV input settings.  Can you get to the on screen menu?  Does anything appear on the screen when the tv is on?
2answers
Phillips Plasma - Model #42PF7320A/37 - 3 flashing red lights
it sounds like you could have a signal board problem they are pretty expensive but there is a web site that sells refurbed parts
Hitachi Plasma TV model P50H401
I think you have problems with the digital main PWB.
If the power PWB failed, turn off and change the pilot ligth to red.
1helpful
4answers
JVC 42 INCH PLASMA POWER LIGHT BLINKING ONLY NO PICTURE
no kidding? what is the problem so prevelant in this unit? obvious design flaw.
Top Philips Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
